Kendra tires vs Kumho tires for the spyders
Anyone have any luck using the Kumho brand ties on the their spyders yet?
Folks have been running the Kumho tire on Spyders for years. You can read for days about the subject, just search on Kumho.
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
Kumho tire
On my 2 kumho rear, I do not like it ,it hydroplanes on small puddles going to install a general altimax hp next
For sure..!!
posted to your other request. GTO (gas tires and oil) are a often discussed subject here. Search it out for days of confusing reading with end result being....choice is yours try and report...
For the last time there is no Kendra Tires. Kendra is bubblehead reality star Kenda makes tires.
Tires
I have over 6000 miles on a Kumho Tire on a 2013 RT Limited. No problems with Riding in the Rain, good Traction, nominal tire wear so far, very satisfied.
Ozzie Ozzie Ozzie
Really happy now I'm running Kumho tires instead of the Kenda Krap!!
Already travelled more distance on the Kumho's than the distance that wore the Kendas to the canvas, & the Kumhos still look brand new!! Of course, they are a heavier tire so they don't need quite as much air pressure in them in order to carry the same load or they'll have less traction &/or hydroplane in the wet, so I'm running 16-17 psi up front & 26 psi in the rear. Ride & handling is phenomenal, they stick like **** to a blanket, & they are much smoother & quieter than the Kendas too - and the look like last double or more distance than the Kendas did!!
Just like fitting the BajaRon Swaybar, my only regret about the change is that I didn't swap to the Kumho's a lot sooner!!
