Results 1 to 8 of 8
    GOS member (Girls On Spyders) ruthie's Avatar
    Feb 2011
    Collinsville, Mississippi
    Default Angle Rotation Sensor
    What does the Angle Rotation Sensor do on the Spyder?
    2014 RT SE6 Limited
    rYding Safe = Having Fun
    Ruthie
    Mar 2012
    NJ
    It tells the spyder what gear its in.
    It's also called a gear position sensor.
    Default Interesting..!!
    Have also seen GPS refered to as GBPS (gear box postioning sensor). But would check that they are not referring to the CAPS (cam positioning sensor) or the CAP (cranckshaft position sensor) both of which are rotational markers.. where or why did this come up..??
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Feb 2011
    Why I asked about this, well my 2014 RT went into limp mode 3 times so I asked my dealer about it. The dealer hooked up my Spyder to BID nothing showed up but said that they would send the information to BRP. Well a week later BRP had sent them the senor and installed it yesterday.
    I did not remember to ask what this senor does so thought I would ask the next best source.
    2014 RT SE6 Limited
    Ruthie
    Drew knows the sensors... he's either tried, or has managed, to disconnect most of them!
    Active Member obiwanbill's Avatar
    Apr 2009
    toledo ohio
    read your post about angle rotation sensor. I have same issue with my 2008. I got the part, but the repair side of dealer blocked up for 2 more months. when the stuck in the new one (looks simple enough for me to do on own), did they have to hook up the computer also?
    Former Navy LT, Retired Chemical Dependency Therapist, Retired Widower, "Do, or do not, there is no try"... Jedi Master Yoda.
    Proud member of AA, PGR, and a Navy Shellback!
    2020 RT Limited Chrome , matte black trim, Green/gray Charcoal? depends on the lighting
    Apr 2009
    toledo ohio
    I'm ignorant. who's drew? Need to ask him ?? about angle rotation sensor. Shop booked up 2 months from now. mechanic buddy pulled it out said it was shot. 7 weeks later get part, but mechanic quit, gone. Looks simple enough to replace. after that, do I have to get it plugged into the canam master computer at the dealer (also a 2 month wait)
    Nov 2015
    Chardon, OH
    Hi Bill. Just in case you hadn't noticed, you tagged on to the back end of a 6 year old thread. So, it makes things a little harder. Yes, that's a picture of the Gear Box Position Sensor. And, if I understand you correctly, your mechanic buddy has already removed your Gear Box Position Sensor and you just got the new part. So, you know where it goes. There's not much to it, just align the sensor with the flat on the shaft and reinstall. A lot of folks that have done this as a DIY job, have gotten by without having to do the Reset procedure with the dealer computer. It all depends. Once you get it installed, take it out and go through all of the gears and see what happens. Good Luck.
    Doug
    ”Freedom is not a loophole”
