Results 1 to 14 of 14
    Active Member Geosik's Avatar
    Culpeper, VA 22701
    Default Harbor Freight Tag Along
    Two Trailer Questions.....
    I have a New 2015 RTS with a dealer installed BRP trailer hitch and wiring harness.
    I am getting ready to purchase a Harbor Freight Tag Along trailer.
    Question #1 -
    The wiring harness od the Spyder ends a 4 prong square plug under the left luggage compartment and the trailer has is a 4 prong flat connecter... What do I need to put them together, I do not want to upset any "applecarts"??????
    Question #2 -
    is for those who removed the trailer hitch when they are not using it.... Exactly where and how do you remove it?????
    Thanks in advance for any guidance......
    Living Life, Loving Life
    2017 F3T - Monolith Black Satin
    2015 RTS - Intense Red Pearl
    2013 RTL - Lava Bronze - Retired
    Regarding Question #1:
    But for #2; your dealer should have given you the installation instructions that came with the hitch kit. Give them a call, and track that paperwork down.
    Mar 2013
    Maumelle, AR
    Quote Originally Posted by Geosik View Post
    Question #1 -
    Question #2 -
    #1. When I had an after market trailer, I made a "jumper" that had a square four pin plug one one end (bike side) and a flat four pin (trailer side) that I used to connect the two. I didn't want to cut into the trailer harness.
    #2. Although it's pretty easy to remove the hitch, it's definitely more convenient to leave it on. I bought a black, ball cover ( from an RV dealer) for two dollars and it dresses up the back end.
    2020 RT Limited , Chalk
    Jul 2011
    Mitchell, Ontario, Canada
    Making an adapter as explained above is easy enough. Someone posted the other day that they cut the flat 4 connector in half. Zip tied the 2 halfs together and it fits in the square 4 connector.
    Active Member TexAmRider's Avatar
    Jul 2013
    Coahoma, Texas
    Default Buy an adapter on Ebay and make your own connector
    Question #1 -
    Question #2 -
    Got this info from another spyder rider. You can build your own with the parts found on ebay. The website was lionparts_powersports They called it Hopkins 11147975 4 Pole Square Set With shipping was less than 10 bucks. This worked very well.
    2016 RTS Special Triple Black, BRP Freedom Trailer, Spyder Pops Rear Lighting Kit, Spyder Pops Full view Turn Signals, Trunk Light, Rivco Highway Pegs. Doc's Spring Tensioners, Trunk Organizer, Magic Mirrors, Foam Grips, back to Stock Windsheild, Lamonsters cat delete, Bajaron sway bar, More Farkles to come !!
    Oct 2013
    Wood Village OR
    Default Tag Along
    #1 ) I made a jumper that converts the 4 square to a flat 4 , the parts are easly found at a NAPA store.
    #2 ) Easer to just leave the hitch on.
    BTW we have 3 trailers, the most recent purchase was a Tag Along and after a few modifacations worked really great for us on a 4 day trip with 3 adults and a child , hauled all our gear needed including sleeping bags as we stayed in KOA camping cabins this time around. We usualy pull a Aspen tent trailer.
    2014 RTL , Black Currant
    Jul 2013
    Coahoma, Texas
    Default Better deal click on link.
    http://www.ebay.com/itm/Hopkins-1114...-/381245701863
    You can buy the other 4 pin adapter at walmart or auto store and build your own.
    Very Active Member rogerb's Avatar
    Jul 2010
    Waterboro,ME
    You can do one of two things Replace the four square female plug on the wiring harness that comes with the kit with a flat four wire female plug or replace the flat male end on the trailer with a square male plug. The four square plug is available on Amazon Hopkins #11147975 four pole square set for $6.40. I replaced the female end on the wiring harness because I have the Harbor Freight trailer and also have a tent trailer that I haul. This way I can change trailers with fewer problems. Most trailers are wired with the flat plug. I had to do some quick changes coming home from Spyderfest. I picked up a trailer for a friend with messed up wiring to bring back. Ended up buying a set of magnetic trailer lights and spliced into the wiring harness on the bike. Now I can hook-up either way. Your choice on what to do.
    Default I'M THINKING THIS IS AN IDEAL SOLUTION
    Quote Originally Posted by rogerb View Post
    .....With the Amazon plug as He got........But I would just ADD IT to the trailer wiring END and leave the FLAT FOUR there also......This way you can tow it with the Spyder or your CAR ....................just a thought........Mike
    Very Active Member retread's Avatar
    May 2008
    Bargersville, IN
    One more thing on the TagaLong, replace all the incandescent bulbs with LEDs, they'll lower the currant draw, and probably last ten times as long. Also, check the wiring on the tagger, I ended up soldering and heat shrink tubing everything on mine, the Scotch lock splicers it came with caused a lot of shorts to ground.
    john
    Active Member jimnsusie's Avatar
    Oct 2014
    The Dalles, Oregon
    Quote Originally Posted by Copperman View Post
    That's exactly what I did. Works great
    Default LED's
    Quote Originally Posted by retread View Post
    john
    .......This is really important !!!!........The Nanny is very FUSSY about the power load .......So to prevent an issues ....Switch over to an ALL LED lighting system.............It's not expensive nor difficult........Mike
    Jul 2011
    The OP has the BRP harness. No issues with power load it is power isolated.
    Very Active Member Magdave's Avatar
    Jun 2013
    NE South Carolina
    2013 Mag Silver SE5 RT BahaRon Sway bar & Sway bar links, Grip Puppies, Kuryakyn Helmet locks , Ultimate Seat w/Utopia Backrest, Dash power outlet, Spyderpops BumpSkid, Swagman Cup holders, Full size Brake Pedal, Seal DLX Floorboards, Freeway Blaster horns, Sylvania Super Bright fender LEDs, Scotchlite 680 Rear & Fender Reflectors, BRP Fog Light Kit, LED Mirror turn signal strips, 2014 RT grille mod. Outlaw Laser Alignment
