Page 37 of 44 FirstFirst ... 27333435363738394041 ... LastLast
Results 901 to 925 of 1100
  1. #901
    Idaho
    Quote Originally Posted by JonYiong View Post
    Hi, I have a 2013 STL. Lately I’m not able to start after pressing the mode button, and I need to wait for about 10secs before I'm then able to fire-up.
    Now it doesn’t fire-up after waiting for about 10secs. I have to off/on the ignition then wait about 10secs to fire-up and sometimes have “BAD KEY” appear on screen.
    Wonder will it work by changing the DESS antenna?
    Sounds like a bad battery.
    2014 Copper RTS
  2. #902
    Sep 2014
    USA
    Check for loose hardware at the battery posts. Or could be a battery issue as suggested. Those are the simple items to check first.
  3. #903
    Active Member JonYiong's Avatar
    Oct 2016
    Singapore
    Battery are change less then a year, all hardware connections are tight.
  4. #904
    Sep 2014
    USA
    Can you get the battery tested to be sure? Maybe module acting up too?
    Explain more on the mode button comment you posted??
  5. #905
    Very Active Member PaladinLV's Avatar
    Feb 2015
    Las Vegas
    In the beginning, before the Engineers could pinpoint the problem, both Module AND Ignition Switch were replaced to GUARANTEE a fix!
    MUCH later, AFTER updating to a new production Module, they found the most probable cause which was the antenna coiled around the ignition switch.
    BRP may have been able to save themselves some money, had they actually LISTENED to the EXPERIENCES of the Riders. That being that the key was SATURATING the module and should check it's antenna. But the problem with troubleshooting is when you have TWO areas. In this case the Module on some and antennas on others OR both. It wasn't until after a new module came out and problems continued, that BRP realized, they also had two modify the antenna and that did not occur until 2016.
    My Module and Ignition Switch were swapped out in the summer of 2015 and since that time has never experienced a failure, except for one time when I layed my smartphone right next to the ignition switch. I moved my phone to it's proper location and all cleared immediately.
    AJ
    2014 RT-S
    Akrapovic Exhaust & Cat Bypass
    Bajaron Sway Bar w/links / Sena SM-10/Garmin 660
    Comfort Seat w Adjustable Backrest
    Decals by Purple Harley / Magic Strobe
    Kuryakyn Black Widow Pegs Rivco Highway Brackets
    Rivco Trunk Mounted Double Flag Holder
    FOBO / Spyder Cuff / XM Radio w MC Antenna
    2014 RT/S , Black
  6. #906
    Jun 2015
    Hampton Roads, VA
    I'm sure this has been mentioned - find someone local that has BUDS and can DISABLE that module. I can do it in 10 minutes. You also can then buy $2 keys that will work as spares to hide. I have BUDS 1 & 2 and can do any year now. Even if 1 in a 1,000 bikes have this happen, it's too much!
  7. #907
    Quote Originally Posted by stevencovert View Post
    ....mostly,.... however the person with the BUDS needs to have an ADVANCED program to do it ..... most dealers don't, and won't do it anyway for legal reasons ..... Mike
  8. #908
    Vermont
    Quote Originally Posted by PaladinLV View Post
    AJ
    I had the Module and Ignition Switch replaced in 2015( which was covered by Warranty). Since then I have not had the D.E.S.S failure. I carry my cell phone in the trunk.
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
  9. #909
    Jun 2021
    arkansas
    Wife has a 2014 RTS that is showing DEES code, is there a way to get her running maybe a bypass method? She is stranded right now. Have heard this has been a problem with these. Can it be programed out of the system? Thanks so much for any and all help.
  10. #910
    Vermont
    Quote Originally Posted by totalcomfort View Post
    totalcomfort,
    Suggestion/advise, Have your wife take the key with her, and wait about 20 minutes than try key again. The spyder should reset it's computer system. Also have your wife try turning the key 5 to 6 times on/off and DO NOT LET THE SYSTEM SHUT DOWN.
    Question : Does your wife have the 2nd key with her?
    Is there anyone near you that can disable the DESS for you?
    Does the 2nd key give her the DESS code?
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  11. #911
    Jan 2021
    Descanso, CA
    Lightbulb
    Search for DESS and D.E.S.S.
    2014 Can-Am Spyder RT-S SE6 Freeway Commuter Pod
    2016 Royal Enfield Classic 500 Fair-Weather Mountain Bike
  12. #912
    Vermont
    Look back thru this "D.E.S.S KEY CODE AGAIN!!!!!!!!!!" thread - I started posted this thread on 8/13/2015. This thread has a lot of excellent info.
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  13. #913
    Nov 2016
    Upstate NY
    The DESS can be turned off permanently by someone with the proper diagnostic hardware. Most dealers will not do it for you. If you get it running and get it home. Ask on here to find someone near you that can disable it. I can do it, but live in NY state. A bit too far away. I would not waste the time and money to have it repaired. Get it turned off and never worry about it again. Most people charge a very small fee or free to turn it off.
    2021 Sea to Sky RT , Highland green
  14. #914
    Idaho
    If you have the stamina go back to Post #1 of this thread and read the whole thing, all 900+ posts! Probably every question you can conceivably come up with has been answered here somewhere.
    2014 Copper RTS
  15. #915
    ... I was lucky enough to have Joel turn mine off and I am forever grateful .... however I dis-agree about Not getting it fixed ..... The part cost about $ 140.00 and once you get the frunk off ... it is a very simple ( plug & play ) fix, ... I still have old DESS module ( The new one that a BRP Tech installed ) ... if you are interested in fixing yours you can PM me and I'll walk you thru it ..... Mike
  16. #916
    Mar 2008
    Hesston, PA
    I DIS-AGREE with this post...I had 3 DESS modules replaced and 1 complete ignition switch with antenna...AND still had DESS issues...Only after having a forum member turn it off did my issues disappear...
    SO MY RECOMMENDATION IS; HAVE THE PIA TURNED OFF AND LIVE HAPPILY EVER AFTER...larryd
  17. #917
    Mar 2015
    forrest above Reno, Nv
    If you can't find anybody who can turn off the DESS for minimal$ or even free there is another choice as mentioned above. ( with a big benefit ) Monster EFI can flash the ECU for more horsepower, torque, and RPM ( at your discretion) for less than replacing the DESS unit.
    You'll be happy with the result.
    Lew L
    2014 RTS , Circuit Yellow
  18. #918
    Feb 2022
    very southern tip of Texas
    Just bought a 2015 F3S. Haven’t got a chance to look it over really well. Only ridden it once. But we have read the “Spyder Do’s and Don’ts” thread from end to end several times!
    My question now - any way to tell if previous owners have disabled the DESS system? Think I want it off ...
    White 2015 F3-S SE6 - “Gypsy” (hers)
    Yellow 2017 F3-S Daytona 500 SM6 (his)
  19. #919
    Quote Originally Posted by larryd View Post
    Larry, I don't understand why you " Dis-agreed " with my post ???? .... My orig. DESS module failed and was then re-placed with a newer model .... it lasted 4 years and still works as far I know ....case closed - period .... Mike
  20. #920
    Sep 2017
    Durham,Maine
    Quote Originally Posted by BCNewell View Post
    I would not worry till you have a issue!! Just my thoughts!!!
    2012 RTL , Pearl
  21. #921
    Mar 2008
    Hesston, PA
    Case Reopened...There were some of us that a $140.00 module did NOT fix the DESS issues...In my case it was 3 times $140.00...Plus when the key and antenna was replaced and ALL the locks had to be rekeyed the was a significant amount of extra $$$$...And the bottom line was I still had intermitten DESS errors...BRP was telling my dealer it could be caused by another chipped key in my pocket or I'm parking to close to some type of RFI...
    But this I do know for sure; When the forum member turned off my DESS the problem has NEVER reoccurred...larryd
  22. #922
    I agree turning the DESS off is IDEAL ..... however finding someone who will or can do it is not IDEAL.... And I'm sorry you had sooooo many Modules that failed ..... I'm thinking your Dealer may be the real problem .... I've been here since 2011 and have heard waaaaaaaay to many stories about Horrible dealers and how they have ripped off other Spyder owners. Remember " checking the valves on the V-twin engine ". Just syin ..... good luck .... Mike
  23. #923
    Mar 2008
    Hesston, PA
    I have a GREAT dealer...Everyone of the repairs were BRP approved...larryd
  24. #924
    Vermont
    I'll let the people who have had the DESS systems disabled chime in on that question.
    I have not had my DESS system disabled. I will not do that.
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  25. #925
    Vermont
    larryd,
    When I had my first and 2nd DESS error/code failures,and the the DESS/antenna replaced ( under warranty) I was not near any RFI sources. The first one (DESS) error/code issue i was in a parking lot( which I posted in Post # 1 on this thread), the 2nd DESS error/code issue the spyder was on my front lawn.
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
