Page 24 of 44 FirstFirst ... 1420212223242526272834 ... LastLast
Results 576 to 600 of 1100
  1. #576
    Nov 2014
    Alexandria, VA
    .Speaking from experience, once this starts - it doesn't cure itself - it just gets worse. Some here say you need to have a PIC to show your Dealer that it occurred .....BS.... it's in the computer, whether they can find it is another thing ....... You have a PIC, so demand they fix this problem....... OR at some point IT MAY NOT CLEAR ITSELF and you will need to go thru the "tow it to a dealer" nightmare (and HUGE expense . My DESS module is (now) bolted under the right headlight, so changing it is a 5 minute job. Yours will take 2 shop hrs......................Good Luck,...............Mike
    Thank you Mike, I will have the dealer check my bike in the next few weeks.
    2016 Spyder F3 Limited, black, Special Edition, SE6, belt tensioner, Bajaron swaybar, AKARAPOVIC, F4 windshield with vent. Previous 2015 RTS in black and 2011 RT Limited, SE5 with Bajaron Swaybar and Bumpskid
  2. #577
    Mar 2008
    Hesston, PA
    Had my 2014 RTS back to my dealer today and they installed a NEW 4916 module, NEW Ignition Switch with New Keys & locks...
    Leaving Sunday (10/16/16) for my 2000 mile trip down Skyline Drive/Blue Ridge Parkway/Floyd Garretts Muscle Car Museum/Smokey Mountains & visiting a friend in GA...
    A BIG THANK YOU to BRP for stepping up and approving the repairs... Hopefully this will be the end of this problem for me... larryd
  3. #578
    Nov 2015
    Minnesota
    Jerry, *** Temporary fixes that work : Turn on/off immediately, DO NOT LET YOUR SYSTEM SHUT DOWN for 4 to 5 cycles. ***
    t
    The permanent fix is: getting the dess module & switch replaced. I have a 2014 RTS-SE6. The first time I had the ( July 14,2015 ) dess module replaced, the 2nd time was ( on Aug. 28th, 2015) I had the dess module( part # 710004190) & the switch( part # 710004413) replaced, and it has been 1 year & 1 month since I have had the dess error show up. I know the above part #'s are not the current part #'s.
    The current/up to date part # is 710004916.
    Deanna
    Thanks for the help. Dealer heard back from BRP and was told to install a new module in both Spyders. I told them that others were saying that didn't fix the problem and that the ignition switch also had to be replaced. They said they can only do what BRP authorizes them to do. So we will have to go down the route of having the new modules fail again and then hopefully they would replace the ignition switch as well. What seems odd to me is that BRP hasn't figured out exactly what the problem is and then we can all get the same fix the first time around. Jerry
  4. #579
    Quote Originally Posted by jacobsonjerr View Post
    .....Jerry, I think what happens is there isn't a single entity at BRP who makes the decision as to what the FIX for this should be .... So it depends on who gets asked by the dealer as to what the FIX will be ...... remember we are dealing with a CORPORATION here .............. The windshield ARM (breakage) has been a problem since 2010 and the FIX is so simple it's laughable (a new SAND mold) ..... but BRP - REFUSES - to fix it, and they don't care how much it costs them... Mike
  5. #580
    Jun 2016
    Harrington, Australia
    They would indeed care how much it costs them, Mike...... that's what it's all about.
    They would have financial modelling figures from their CFO showing that the cost of tooling up for the new sand mold, thus virtually admitting there is currently a faulty production process and paying for replacing all brackets produced under the old production process, is potentially more expensive than replacing only those that break and self insuring for any damages claims that might arise. Corporate management these days is all about the gamble and the annual bonus if you pull it off...... Hey, even if you don't pull it off and it backfires, you still get your golden handshake and move to another corporation, so what do you have to lose?
    Pete
    2021 RT Limited
    HeliBars Handlebars
    Kenda Kanine rear.
  6. #581
    The windscreen arms are not sand cast. The process is too slow and labor intensive. From a cost stand point if the part was produced by this method, they would easily run away from that type of prodution method. No doubt, like the high quality billet windscreen arm produced in Austrailia, the best arm can be machined from billet. Less labor, with a tradeoff of time on the machining center.
    Recently, I noticed another brand of windscreen arms. For some reason this latest entry costs 30% more than the Australian version and omits the details of the hexagon shaped bore to match and properly support the arm onto the torsion shaft.
    Ironically, I have read many times the cause for failure is the arm is not capable to have the windscreen positioned in the full up or full down position. Myself, this concept of failure does not seem viable, however, I would consider that front tire vibration is absorbed into the arm causing the failure.
    .........If they aren't SAND CAST .... then I'm interested in how you think they are made ??? ...................Thanks ...... Mike
  7. #582
    Idaho
    Die casting. Explained here pretty well. https://en.wikipedia.org/wiki/Die_casting. There's a pretty high up front capital cost and subsequently a low per item cost. BRP isn't going to make a change until there's an overwhelming economical benefit to doing so, like maybe when the rate of part failure and warranty costs exceed the cost of forged parts. There's no question forged parts would be stronger, but cost a lot more to make.
    Sand casting is used mostly for iron based alloys for large items.
    2014 Copper RTS
  8. #583
    I read your LINK and agree with the EXPENSE part ..... If they are made this way ??? ....... How's this for a possibility ....3D - carbon fiber ......!!!!!!!.........Mike
  9. #584
    Vermont
    Bump
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
  10. #585
    Apple Valley,Calif.
    Hi there. When I was volunteering to do demo rides here in Victorville Cal. the rep. from BRP's ad company said you can start the bike without waiting for the info screen. He proved it to me on a new 2016 F3, Ok fine. I tried it 2 times on my 2015 RTS and got a DESS fail both times. I went back to waiting for the info screen, hit the mode button, it started right up. I have determined that it is software dependent. At least in my case i have to be patient and let the software do its thing. Also harder to steal that way. Hope this helps everyone.
  11. #586
    Very Active Member Trbayth's Avatar
    Jun 2014
    Schenevus NY
    Quote Originally Posted by Kc6wfi View Post
    Only F3's can do that.
    Trb-- (Roger)
    2014 Cognac STL:Ultimate Seat, Nelson Rigg Tail Pack, Nelson Rigg RS/ST Half Cover, TL fender lights, Squared Away Laser Alignment, BajaRon sway bar and links, Akropovic Sport Silencer
    2022 White Pearl F3T
    Gone but not forgotten: 2019 F3S Special Series Liquid Titanium
    Spyder States Visited
  12. #587
    Mar 2016
    Astoria, Oregon
    I have contacted my Congress Representative about this issue. The DESS ERROR is BRP's problem, not ours. BRP should be held responsible for all costs related to the problem.
    Sent from my SAMSUNG-SM-G890A using Tapatalk
  13. #588
    Nov 2014
    Alexandria, VA
    After sending a second email to BRP, I had BRP approve the parts to be sent prior to my appointment. I took the bike last week to have my bike repaired but the parts were not arrived yet. I asked them why they could not order the parts prior for me getting there, and the answered from the dealer was that if they order parts prior to them to "troubleshooting" the bike and the order the wrong parts, then BRP will not let them return the part. Only time they can return the parts if they get prior permission from BRP. Oh well my bike will be ready next Friday. I ordered the new upgraded BRP rear shock, and the dealer needed the extra days for the order to arrive. I will let you know when I pick up my bike next week.
  14. #589
    Vermont
    Quote Originally Posted by wengerda View Post
    Good luck! Keep us posted! Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  15. #590
    Nov 2014
    Alexandria, VA
    The dealer called me this morning to pick up my bike, the Dess module was replaced, now cross my fingers that I wont have the same issue again.
  16. #591
    Jun 2016
    Only the DESS module, Wengerda? Aren't they supposed to replace both the DESS module and the ignition switch to cure it completely? Or is that what you mean by the "module"?
    2021 RT Limited
    HeliBars Handlebars
    Kenda Kanine rear.
  17. #592
    Jun 2016
    The F3 and the RT are indeed different at startup, Kc......The F3 will start immediately, the RT won't start without waiting, so there was nothing untoward there
    2021 RT Limited
    HeliBars Handlebars
    Kenda Kanine rear.
  18. #593
    Vermont
    What is the dess module part #?
    I hope the dess module that was replaced was under warranty.
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  19. #594
    Active Member ndspyderlover's Avatar
    Dec 2012
    fargo, north dakota
    My 2016 rtl will start right away with no wait necessary.
  20. #595
    Jun 2016
    Quote Originally Posted by ndspyderlover View Post
    Yes, but Kc is talking about a 2015 RT.
    2021 RT Limited
    HeliBars Handlebars
    Kenda Kanine rear.
  21. #596
    Nov 2014
    Alexandria, VA
    Deanna
    710004916
  22. #597
    Nov 2014
    Alexandria, VA
    They only authorized the module #710004916.
  23. #598
    Sep 2013
    Houston
    2015RT
    will do the same. It was new for the 15s.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
  24. #599
    Vermont
    Sent Pm. Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  25. #600
    Mar 2016
    Astoria, Oregon
    After a week of sitting with the cover on, I went out this morning, and fired up the bike just like normal, no DESS ERROR!!!! Fixed itself!!!
    One great thing that has come of this, I've found out that I have towing coverage in my State Farm Comprehensive coverage, I have towing coverage from my AMA membership, and as long as my BRP Warranty is in place, I have $200 per incident towing coverage from BRP. I don't recall that ever being mentioned by the salesman, but after sending a nasty gram to BRP, that was the reply I got from them! I also don't recall ever seeing that mentioned in any of the threads on this forum, but I could have easily missed it!
