Page 22 of 44 FirstFirst ... 1218192021222324252632 ... LastLast
Results 526 to 550 of 1100
  1. #526
    Idaho
    Quote Originally Posted by wanderingman View Post
    I do not know if this is correct or not, but I was told that if two chipped keys for different products, such as my Toyota and my Spyder are stored together, it can cause them to mess up the coding on each other. I was told that this information came from an auto manufacturer. I was not told which one. Just a thought.
    I don't think that is possible as the electronics in each key are not powered up until they are in the vicinity of the ignition and receive an electrical signal from the antenna. However, if a second key is next to the first key when the ignition is turned on both keys MAY get activated and the digital signals from each get mixed up and cause an error. You can do with your Can Am keys and get a DESS error most every time. I have gotten the DESS error by having a Nissan key next to the Spyder key when I turned it on, but not every time.
    2014 Copper RTS
  2. #527
    Very Active Member PaladinLV's Avatar
    Feb 2015
    Las Vegas
    BULL****!
    Can I be3 any plainer
    AJ
    2014 RT-S
    Akrapovic Exhaust & Cat Bypass
    Bajaron Sway Bar w/links / Sena SM-10/Garmin 660
    Comfort Seat w Adjustable Backrest
    Decals by Purple Harley / Magic Strobe
    Kuryakyn Black Widow Pegs Rivco Highway Brackets
    Rivco Trunk Mounted Double Flag Holder
    FOBO / Spyder Cuff / XM Radio w MC Antenna
    2014 RT/S , Black
  3. #528
    Feb 2015
    Las Vegas
    Negative.
    The key MUST be in the ignition switch in order to be activated. IF the/a key is merely in the vicinity (even on your rocker switches) it will not activate and if it were to activate, BRP has much bigger problems then a DESS module.
    AJ
    2014 RT-S
    2014 RT/S , Black
  4. #529
    Idaho
    Quote Originally Posted by PaladinLV View Post
    Negative.
    AJ
    Are you suggesting the DESS errors I saw during my experimentation were a figment of my imagination?
    Try it. Put Spyder key #1 into the ignition.
    Hold Spyder key #2 next to key #1.
    Turn ignition on.
    I'll bet you get the same DESS error I saw!
    2014 Copper RTS
  5. #530
    Feb 2015
    Las Vegas
    REPEAT
    NEGATIVE
    AJ
    PS
    Will be happy to once again repeat and provide photos.
    Turn ignition on.
    2014 RT-S
    2014 RT/S , Black
  6. #531
    Idaho
    REPEAT
    NEGATIVE
    AJ
    PS
    You mean a couple of photos like these? The first shows the key error when the second key was next to the first key when ignition was turned on. The second photo shows the bike running with a non-chip key in the ignition and the chip key next to it.
    2014 Copper RTS
  7. #532
    Vermont
    Technical Explanation" When the D.E.S.S. module sends its signal to the antenna to read the key chip, the radio frequency produced by the antenna is too strong and the key chip is saturated. The saturated changes the data transmitted back to the D.E.S.S. module causing a bad lecture of the key chip".
    Also, a quote from a BRP Tech " We have had cases where a cell phone or magnetic card, placed near the ignition switch cause this. This includes any device that may emit some type of frequency". ( end of 'quote).
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
  8. #533
    Active Member SpyDerSts's Avatar
    Aug 2015
    Columbus,Ohio
    Well,looks like we get to go pick up wife's Spydey again from repair in Springfield Ohio. (DESS replaced) Hopin of all hopes its Fixed fer good. I'm sure sumpthin else will (electronically) need repair eventually. It just seems that way....for now I want her to have her Spydey back so we can ride together and enjoy what's left of this warmer weather.
    '15 F3S SE6 Pearly White (Hers)
    '16 F3S SE6 Special Series Triple Black (His)
  9. #534
    Jun 2016
    Harrington, Australia
    Deanna
    Hi Deanna.....forgive my ignorance, but what initiates the DESS module sending its signal to the antenna? Is is simply the key being close proximity, or does the key have to be inserted?
    Pete
    2021 RT Limited
    HeliBars Handlebars
    Kenda Kanine rear.
  10. #535
    Sep 2013
    Houston
    Pete
    When you insert the key and turn on the ignition, the DESS module activates the chip in the key via the coil near the ignition lock cylinder.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
  11. #536
    Vermont
    Pete
    Pete, See/read post #535 on this thread for the answer. Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  12. #537
    Very Active Member irvin48's Avatar
    May 2016
    mt morris il
    cant remember if it was discussed, but when the ignition switch is replaced,
    what happens to the rear lock ? do i get a new barrel? didnt have one put in
    in wisconsin, so as a precaution my dealer is gonna do it when the new h/l's are installed.
    that way everything is new again. have to buy another key blank now to cut,
    for an uncoded rear spare too. thanks for any info.
    did the ign switch get an upgraded part # too? irv
    2015 rts-white pearl- mods- '16 F3 fat 6 chrome wheels,
    and some little stuff. setback utopia backrest, baja ron
    sway bar, oem adj. air deflectors, marlin gps compass,
    lamonster fbb foot pegs[modified brackets], lamonts
    vibration damper, rock guard, and side case stiffener kit,
    . brp comfort seat. , fomozas and
    altimax, magic mirror mts, and wide mirrors.
    [joyce & irvin toms]
  13. #538
    Vermont
    Quote Originally Posted by Joyce47 View Post
    Joyce47, I posted ( on page 6 post # 126 title " new DESS module + Ignition switch fixed update 8/28/15" ) on what happened when I had my New dess module + Ignition switch replaced.
    My dealership " replaced the rear trunk key lock". Also, get from your dealership a new trailer lock.
    Keep us updated on what happens. Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  14. #539
    Jun 2016
    Ahhhhhh. Thanks JC and Deanna. I was just curious as both my phone and chipped credit cards are within a foot of the key when I turn the ignition on.
    Pete
    2021 RT Limited
    HeliBars Handlebars
    Kenda Kanine rear.
  15. #540
    .... ...Not crying or whining about it........... but it just happened AGAIN and Yes, I have the newest Module ...... Got the orange box with Key flash... then the Engine symbol!!! .... BUT NOT the "ENTIRE ORANGE SCREEN THING" ...... and the Spyder did re-start ............ I didn't have my spare key, No cell phone, No power lines, rural area yada yada........ This is way beyond my pay grade ......I posted this for info purposes only............... Mike
  16. #541
    Very Active Member Sam Mac's Avatar
    Dec 2015
    Galax VA
    5 gals of gas and a match, problem solved.
  17. #542
    Quote Originally Posted by Sam Mac View Post
    . I expected better from you Sam ........ Mike
  18. #543
    Vermont
    Pete
    Pete, When I am on the road, I have my cell phone, camera and other items in my trunk, and my spyder starts.
    Also, I have the dess module part # 710004190 ( was installed on Aug. 28th 2015) and I know my dess module part # is not the latest.
    The current/latest dess module part # is 710004916.
    You are welcome for the info. Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  19. #544
    Vermont
    It is "year" today since I have had the 2nd D.E.S.S. module + Switch replaced. WOHOO!!!!!!
    I hope I did not jinx my self.
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  20. #545
    Feb 2015
    Las Vegas
    I don't know how many times I must say the same thing before this sinks into everybody's mind.
    The ONLY way to be reasonably sure the error gets fixed is:
    Have the DESS Module replaced
    AND
    Have the Ignition Switch replaced.
    Be proactive and TELL your Dealership these are the parts that need to be replaced and give them the Part Numbers!
    DO NOT accept any other solution!
    OR
    Disable the system entirely!
    I'm not going to post the part numbers again. I've done it and so has Deanna multiple times.
    Believe, don't believe me, that's your choice.
    AJ
    ......Not crying or whining about it........... but it just happened AGAIN and Yes I have the newest Module ...... Got the orange box with Key flash .. then the Engine symbol !!! .... BUT NOT the " ENTIRE ORANGE SCREEN THING " ...... and the Spyder did re-start ............I didn't have my spare key, No cell phone, No power lines, rural area yada yada........ This is way beyond my pay grade ......I posted this for info purposes only...............Mike
    2014 RT-S
    2014 RT/S , Black
  21. #546
    Dec 2015
    Galax VA
    Mike
    If you have the latest and greatest module and it is still acting up then it sounds like they don't have the problem solved. That sucks.
  22. #547
    Vermont
    AND
    OR
    AJ
    AJ, yes, I have posted the Part numbers several times for the D.E.S.S. module, and the IGNITION switch( part # is 710004413).
    I posted the part number for the D.E.S.S. module/ and the ignition switch
    when I had the D.E.S.S. module and the ignition switch replaced the 2nd time, in Aug 28th, 2015.
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  23. #548
    Active Member RudyB's Avatar
    May 2016
    Abbotsford British Columbia Canada
    So how do you disable the system
  24. #549
    May 2013
    Indiana
    AND
    OR
    AJ
    AJ,
    Even if you haven't had the problem in 18 months?????
    2021 Marsala Red Metallic RT Limited
  25. #550
    Sep 2013
    Houston
    Quote Originally Posted by RudyB View Post
    Connect an Engineering licenced version of BUDS (Mega Tech) to the bike and select the option on the Security screen.
