Page 1 of 44 1234511 ... LastLast
Results 1 to 25 of 1100
    Vermont
    Default DESS Key code again!!!!!!!!!!!!!!!!!!!!!!!
    Today, I was doing some errands - after I left the store went to start my Spyder & I got the D.E.S.S KEY CODE "AGAIN" I put a key into the ignition, got the above error, put the 2nd key into the ignition, got the same message, (and of course I didn't have my camera so, sorry, but no picture) & the Spyder did not start.
    Put both keys in their holders (plastic) and walked away about 50 to 60 feet, and waited for about 1/2 hour (in my mind I was thinking of calling Roadside Assistance if the Spyder did not start the 2nd time) I did not have to call Roadside Assistance because it started. Then I went on my way.
    Thank god!
    So tomorrow I will call my dealer and tell them I got the D.E.S.S KEY CODE again. I had the D.E.S.S. Module replaced last month (7/17/15) and both keys reprogramed. I will post here when I can on what the dealer says. My Spyder is a 2014 RTS-SE6. I know this happens a lot.
    I did start a Thread last month on the above subject. I was wandering if anyone else has had this recurring problem?
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
    Jun 2010
    Las Vegas
    Somebody posted today on Facebook that she got the DESS error on her 14.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Vermont
    Last month I had the D.E.S.S. Module replaced and both keys reprogramed. Sent pm. Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
    I'm not sure they have a good handle on this problem. You are not the first to have it more than once after the change of parts. The replacement parts may be defective as well. This new system seems a bit flawed even if it is safer as far as ignitions go. They are all being done as they fail... of a way to find the defective parts. They should replace them all with new ones and send those back to the manufacturer... jmo
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    I wonder if re-programming the keys may be the source of it?
    Good Luck! Please keep us informed...
    Yup! I once had a Chevy Silverado that got into it's head, that I was trying to steal it!
    Mar 2015
    Sault Ste. Marie , mich
    2nd time for me too... trailered to dealer 100 miles away... they took a module off a 2015 while I waited... tech said he is not sure if it will happen again. 2014 TT Limited.
    got 1000 miles on my rear new v rubber... stock tire only lasted 4000 miles. everything looks and feels good.
    Aug 2015
    St Paul, MN
    Post
    Today, I was doing some errands, after I left the store went to start my spyder, I got the D.E.S.S KEY CODE "AGAIN" so I put a key into the ignition, got the above error, put the 2nd key into the ignition, got the same message, ( and a coarse I did not have my camera so no picture) the spyder did not start.
    Put both keys in their holders ( plastic) and walked away about 50 to 60 feet, and waited for about 1/2 hour ( in my mine I was thinking of calling Roadside Assistance, if the spyder did not start the 2nd time, I did not have to call Roadside Assistance,) because it started. Then I went on my way.
    Thank god!
    So tomorrow I will call my dealer and tell them I got the D.E.S.S KEY CODE again. I had the D.E.S.S. Module replaced last month ( 7/17/15) and both keys reprogramed. I will post here when I can on what the dealer says. My spyder is a 2014RTS-SE6. I know this happens a lot.
    I did start a " Thread last month on the above subject. I was wandering if anyone else has had this recurring problem?
    Deanna
    Aug 2015
    St Paul, MN
    I have a 2014, RT, LTD with 7000 miles. DESS error message is a reoccurring problem, bike won't start. Very intermittent. Very annoying. Bike is now at the dealer in Brainerd, MN for service. They have ordered parts but I don't believe that either the dealer or CanAm has any idea of what is going on.
    I've been told by a member in here who's opinion I value; that BRP has a problem getting decent-quality parts from their outside vendors...
    This must be one of them!
    Vermont
    Yes, I will keep everyone posted as soon as I can about the problem. (I am a busy lady) Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
    Vermont
    Quote Originally Posted by mikej View Post
    2nd time for me too...trailered to dealer 100 miles away...they took a module off a 2015 while i waited..teck said he is not sure if it will happen again 2014 rt limited
    got 1000 miles on my rear new v rubber..stock tire only lasted 4000 miles .every think looks and feels good
    Your last sentence is off the subject. Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
    Active Member KJWEB's Avatar
    Jun 2015
    Midland, TX
    My 2015 RT Limited.....Good luck
    www.sasspyders.com
    2016 F3T
    2015 Freedom Trailer
    Sypderpops BumpSkid Plate
    Lamonster ISP Key Cover
    Lamonster F3 Bar Clamp and Power Port
    Lamonster RIP floorboards and frame caps
    Lamonster Chevron Highway Pegs
    BajaRon Swaybar & Heim Links
    F4 Custom 21" tinted windshield
    BRP Cannonball Seat
    BRP F3 Idler Pully
    FOBO TPMS
    LidLox (dual)
    Garmin 660LM GPS
    Cat Delete Performance Pipe
    F3T Top Case
    PPA Black Widow Wheels
    Custom Frunk Wrap
    NE Illinois
    Sorry this is happening to folks even once, much less twice. I was hoping that some sort of pattern would emerge, providing a clue as to the affected units, but that doesn't appear to be happening.
    MEP
    ​2019 F3 Limited
    Vermont
    Quote Originally Posted by KJWEB View Post
    Thanks for the pic. I will be calling the dealer this afternoon. I hope to get this fixed before I go to Spyderquest next month. Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
    Active Member SailnDive's Avatar
    Jul 2015
    WV
    Just another reason that I hate computers being in control of our equipment!
    Vermont
    It is happening with the 2014 RT-SE6's, and the 2015RT-SE6's, Limited's. I hope BRP gets a grip on this! Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
    Vermont
    I did not get this picture:
    when I started the Spyder yesterday. After I got the D.E.S.S Key Code I did get the above picture and it started. I will keep everyone posted on this. Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
    Jun 2014
    Schenevus NY
    2014 ST's as well.
    Trb-- (Roger)
    2022 White Pearl F3T
    Spyder States Visited
    Vermont
    Here is the newest up date that I got from my Can-Am dealership( in Vermont) they said " they( Dealership) will open up a case with BRP and they( Dealership) will be in touch with me on what they will do next.
    Stay tuned on what happens next. As soon as I know I will post. Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
    Vermont
    Quote Originally Posted by Trbayth View Post
    2014 ST's as well.
    I just updated this thread. I had the D.E.S.S Module replaced + keys reprogramed on July 17th with 6,994 miles. I have a 2014RTS-SE6.
    Does anyone know if the Manufacturer's Warranty still covers this, even it is the 2nd time that has happened?
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
    Active Member Ex Winger's Avatar
    Apr 2015
    Brockville ONT
    Good luck.Hope they get to the root of this problem
    Bill
    2018 RT Anniversary , Brake pedal extended
    Very Active Member JerryB's Avatar
    May 2014
    Beaverton, Oregon
    Hi Bob,
    Re: BRP has a problem getting decent-quality parts from their outside vendors...
    Having spent 30 yrs overseeing the implementation of QC programs, that is rarely the vendor's fault. But, sometimes it is.
    It is usually the failure of the buyer's QC proogram, the specs for the parts, incoming inspections, etc, etc.
    Jerry Baumchen
    'I'll never forget what's her name.'
    'Things are more like they are now than they ever have been before.' Dwight Eisenhower
    2008 GS SE-5
    Active Member krazykat's Avatar
    Feb 2013
    Cape Coral, Florida
    Deanna
    DESS module replaced twice so far on my 14 RT Ltd.......both times covered by warranty.
    2014 Cognac RT Limited #185 (destroyed in T-Bone wreck 3/21/2014)
    2014 Cognac RT Limited #5333 (replacement 5/16/2014)
    2018 Champagne RT Limited #1002 (traded 1/31/2018)
    Jun 2015
    Midland, TX
    Add to the known problem, I only get the D.E.S.S Error on one of my keys. At least for now anyway.
    www.sasspyders.com
    2016 F3T
    BRP Cannonball Seat
    BRP F3 Idler Pully
    FOBO TPMS
    LidLox (dual)
    Garmin 660LM GPS
    F3T Top Case
    Custom Frunk Wrap
