05-27-2023, 11:01 AM
#1051
Originally Posted by cruisinTX
hmmm, you must be thinking the same thing I am. Find the power wire to the DESS and simply diconnect it.
Sorry, won't work. One of the criteria for the ECM to permit engine start is "D.E.S.S. recognizes the key." If you simply cut power to the DESS module the ECM will not get the key info from it. If the ECM can't get the key info from the DESS it won't give the OK signal to start the engine. That's why the only way to "Disable the DESS" is to use BUDS to change the parameter inside the ECM so it skips the valid key check.
Keep in mind DESS doesn't mean only the module but also the software program. It's Digitally Encoded Security System.
07-03-2023, 07:25 PM
#1052
I thought I had already posted this but guess not. I need to thank James Thorne from Houston, Tx. for having exorcised the DESS gremlins from my 2014 RT-L when we met up in Las Vegas, NM on Friday, June 23rd. Hoping that is the last I ever see of that worthless piece of technology built in by the "oh so brilliant BRP engineers."
Those who say " I can't" will always be right.
07-03-2023, 08:45 PM
#1053
crusinTX,
Thanks for posting!
Deanna
Gremlin Bell
SpyderPops Missing Guard Belt
Ultimate F3 Floorboards
Sway Bar with Links
Rolo Laser Alignment
Half Cover
Show chrome Trunk Shock
07-12-2023, 04:18 PM
#1054
Got my DESS deactivated today one problem i won't have.
07-12-2023, 07:22 PM
#1055
helton61,
What year is your spyder?
What is your spyder model?
Deanna
Gremlin Bell
Sway Bar with Links
Half Cover
07-12-2023, 08:25 PM
#1056
Please tell everyone here who did it ...... EVERYONE wants to know this .... it gets asked a lot here .....Thanks .... Mike
07-12-2023, 08:59 PM
#1057
Wow, 44 pages of this. DESS error twice on my nearly new 2022 F3s.
Vince F in Niagara Falls
2022 Spyder F3 Special Edition
2020 Ryker Rally, sold
2022 F3S , Stock Lamonster black diamond Monolith Black Satin
07-12-2023, 11:24 PM
#1058
Originally Posted by Vincef329
Wow, 44 pages of this. DESS error twice on my nearly new 2022 F3s...
Hopefully " BRP Cares " doesn't read Your post. .... Dis-abling DESS isn't something BRP would tolerate - -JMHO ..... Mike
07-13-2023, 06:37 AM
#1059
Originally Posted by Deanna777
helton61,
Deanna
16 spyder RTL
07-13-2023, 07:01 AM
#1060
If they had half a brain they would do something different! Oh wait, that would mean someone won't make any money, silly me what was I thinking!
07-13-2023, 07:47 AM
#1061
So this is a safety issue, like not being able to start and move your vehicle out of the way of traffic issues, lightning storms , etc. This needs many people to open a NHTSA case as safety issue so that Can Am is forced to not only replace but replace the system with something that actually works , first time every time. This should include the antenna and /or keylock as they are integral on the later spyders like my 2019 RTL.
If 1000 people do this NHSTA will be forced to open an investigation. BOMBARD them people !!!!!!!
2024 RT SEa To Sky ( back at dealer again due to blank screen issues , loss of BT and WIFI :-( :-( .. looking forward to the BajaRon event May 1-5 just with 2023 S2S only)
2023 RT Sea to Sky Shadow Green ( guess what NO errors at all in 9 months of owning....)
07-13-2023, 09:01 AM
#1062
Originally Posted by WRCLVR
Sso this is a safety issue, like not being able to start and move your vehicle out of the way of traffic issues, lightning storms , etc. This needs many people to open a NHTSA case as safety issue so that Can Am is forced to not only replace but replace the system with something that actually works , first time every time. This should include the antenna and /or keylock as they are integral on the later spyders like my 2019 RTL.
BRP HAD a DESS system that worked fine ...... PRIOR TO 2014!!!! .... then some idiot engineer, tried to fix it even tho it wasn't BROKE .... Mike PS read post # 1082 above .....
Reason: Color & ' 's ;-)
07-13-2023, 01:44 PM
#1063
WRCLVR,
Deanna
Gremlin Bell
Sway Bar with Links
Half Cover
08-22-2023, 07:48 PM
#1064
Has anyone had any DESS errors/or problems lately on the new spyder models (2020 +)?
Deanna
Gremlin Bell
Sway Bar with Links
Half Cover
08-22-2023, 08:59 PM
#1065
Has anyone had any DESS errors/ or problems lately on the new spyder models (2020 +)?
Deanna
Read post #1057 ..... Mike
08-23-2023, 06:16 AM
#1066
2014 Starting to get the error on mine now. Out of warranty. Anyone have an idea what the cost is to fix this? I am sure my local dealer here in GA will not disable it.
08-23-2023, 07:19 AM
#1067
Reason: Merged immediately consecutive posts...
08-23-2023, 09:45 AM
#1068
Originally Posted by Mikey
This thread is the gift that keeps on giving!! Good job girl, I think it's the all-time longest right up with, what did you do to your Spyder today!
Go back to the first post and read down through them one more time. Then find some one that has BUDS and get it unhooked! Good luck my friend!! Technology you got to love it, and hate it at the same time.
I have read the entire thread. It has been a long morning, lol. More info, this has been happening for a bit off and on. I can get by it, sometimes quickly, sometimes not (turning key on/off, waiting, etc). Does anyone know someone in the Atlanta area that can turn it off? If you don't want to post it, PM me. Thanks.
Reason: post.... :-/
08-23-2023, 10:38 AM
#1069
The DESS error was covered by an SB!
Sorry no longer remember number - look it up.
An SB should mean (it is COVERED) by BRP and should not need to worry about cost.
So "maybe" to save $$$ the Dealership will just disable via BUDs; then again maybe not.
But the cost should be on BRP, not you.
Check it out.
AJ
2014 RT-S
Akrapovic Exhaust & Cat Bypass
Bajaron Sway Bar w/links / Sena SM-10/Garmin 660
Comfort Seat w Adjustable Backrest
Decals by Purple Harley / Magic Strobe
Kuryakyn Black Widow Pegs Rivco Highway Brackets
Rivco Trunk Mounted Double Flag Holder
FOBO / Spyder Cuff / XM Radio w MC Antenna
08-23-2023, 10:47 AM
#1070
RECORD_ID: 2917249
Bulletin Number: A104494
Replacement Service Bulletin Number: N/A
NHTSA Item Number: 10185868
Date Posted: 11-05-2015
Component Name: 110000 ELECTRICAL SYSTEM
Make: CAN-AM
Model: SPYDER RT
Year: 2014
Date Added: 01-25-2021
Summary: Intermittently, the ignition key may not be recognized causing the unit not to start.
Found that. So if it has a SB, it is covered, even though it out of warranty??
08-23-2023, 11:28 AM
#1071
Originally Posted by Hawk
RECORD_ID: 2917249
Make: CAN-AM
Model: SPYDER RT
Year: 2014
Since you are on the "DESS" thread, you think you have a DESS Failure issue ..... (ie. orange screen of Death). Contact your Dealer and see if they know about the SB and IF they will honor it? ..... As far as cancelling it, I seriously doubt the dealer will or even can do that ..... good news .... I'm pretty sure the "Netzley boys" will be selling at "Maggie Valley" in the beginning of Oct. (check the dates posted on the Home page) .... they now have the capability to CANCEL the DESS module. I would contact them and ask and or set up an appointment .... good luck .... Mike .... I just discovered that BAJARON (in Tenn.) can cancel DESS also ..... M
Reason: Caps; ' 's; colours... ;-)
08-23-2023, 01:26 PM
#1072
Thanks BLUEKNIGHT911!! Will see about going to MV!!! Have not been to a Spyder function in some time!!
08-23-2023, 03:56 PM
#1073
Hawk,
I don't know what the cost would be to fix it. The dealerships wont fix the disable DESS.
Deanna
Gremlin Bell
Sway Bar with Links
Half Cover
08-23-2023, 04:06 PM
#1074
Mikey,
Yes, this thread has a lot of excellent info. Thank You!!! Yes, this thread is very long. Thanks
Good luck!
Deanna
Gremlin Bell
Sway Bar with Links
Half Cover
08-23-2023, 04:08 PM
#1075
RECORD_ID: 2917249
Make: CAN-AM
Model: SPYDER RT
Year: 2014
Hawk,
Where did you find the above info?
Deanna
Gremlin Bell
Sway Bar with Links
Half Cover
