Page 43 of 44 FirstFirst ... 33394041424344 LastLast
Results 1,051 to 1,075 of 1100
  1. #1051
    Quote Originally Posted by cruisinTX View Post
    hmmm, you must be thinking the same thing I am. Find the power wire to the DESS and simply diconnect it.
    Sorry, won't work. One of the criteria for the ECM to permit engine start is "D.E.S.S. recognizes the key." If you simply cut power to the DESS module the ECM will not get the key info from it. If the ECM can't get the key info from the DESS it won't give the OK signal to start the engine. That's why the only way to "Disable the DESS" is to use BUDS to change the parameter inside the ECM so it skips the valid key check.
    Keep in mind DESS doesn't mean only the module but also the software program. It's Digitally Encoded Security System.
  2. #1052
    Mar 2015
    Fritch, Tx
    I thought I had already posted this but guess not. I need to thank James Thorne from Houston, Tx. for having exorcised the DESS gremlins from my 2014 RT-L when we met up in Las Vegas, NM on Friday, June 23rd. Hoping that is the last I ever see of that worthless piece of technology built in by the "oh so brilliant BRP engineers."
    Those who say " I can't" will always be right.
  3. #1053
    Vermont
    crusinTX,
    Thanks for posting!
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
  4. #1054
    Active Member helton61's Avatar
    Jan 2023
    Virginia
    Got my DESS deactivated today one problem i won't have.
  5. #1055
    Vermont
    Quote Originally Posted by helton61 View Post
    helton61,
    What year is your spyder?
    What is your spyder model?
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  6. #1056
    Please tell everyone here who did it ...... EVERYONE wants to know this .... it gets asked a lot here .....Thanks .... Mike
  7. #1057
    Aug 2020
    Niagara Falls NY
    Wow, 44 pages of this. DESS error twice on my nearly new 2022 F3s.
    Vince F in Niagara Falls
    2022 Spyder F3 Special Edition
    2020 Ryker Rally, sold
    2022 F3S , Stock Lamonster black diamond Monolith Black Satin
  8. #1058
    Quote Originally Posted by Vincef329 View Post
    Wow, 44 pages of this. DESS error twice on my nearly new 2022 F3s...
    Hopefully " BRP Cares " doesn't read Your post. .... Dis-abling DESS isn't something BRP would tolerate - -JMHO ..... Mike
  9. #1059
    Jan 2023
    Virginia
    helton61,
    Deanna
    16 spyder RTL
  10. #1060
    Durham,Maine
    If they had half a brain they would do something different! Oh wait, that would mean someone won't make any money, silly me what was I thinking!
    2012 RTL , Pearl
  11. #1061
    Active Member WRCLVR's Avatar
    Nov 2022
    Georgia USA
    So this is a safety issue, like not being able to start and move your vehicle out of the way of traffic issues, lightning storms , etc. This needs many people to open a NHTSA case as safety issue so that Can Am is forced to not only replace but replace the system with something that actually works , first time every time. This should include the antenna and /or keylock as they are integral on the later spyders like my 2019 RTL.
    If 1000 people do this NHSTA will be forced to open an investigation. BOMBARD them people !!!!!!!
    2024 RT Sea to Sky screen now working but codes will remain until BRP releases the ACP update.
  12. #1062
    Quote Originally Posted by WRCLVR View Post
    Sso this is a safety issue, like not being able to start and move your vehicle out of the way of traffic issues, lightning storms , etc. This needs many people to open a NHTSA case as safety issue so that Can Am is forced to not only replace but replace the system with something that actually works , first time every time. This should include the antenna and /or keylock as they are integral on the later spyders like my 2019 RTL.
    BRP HAD a DESS system that worked fine ...... PRIOR TO 2014!!!! .... then some idiot engineer, tried to fix it even tho it wasn't BROKE .... Mike PS read post # 1082 above .....
  13. #1063
    Vermont
    WRCLVR,
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  14. #1064
    Vermont
    Has anyone had any DESS errors/or problems lately on the new spyder models (2020 +)?
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  15. #1065
    Has anyone had any DESS errors/ or problems lately on the new spyder models (2020 +)?
    Deanna
    Read post #1057 ..... Mike
  16. #1066
    Very Active Member Hawk's Avatar
    May 2011
    Dacula, GA
    2014 Starting to get the error on mine now. Out of warranty. Anyone have an idea what the cost is to fix this? I am sure my local dealer here in GA will not disable it.
  17. #1067
    Durham,Maine
    This thread is the gift that keeps on giving!! Good job girl, I think it's the all-time longest right up with, what did you do to your Spyder today!
    Quote Originally Posted by Hawk View Post
    Go back to the first post and read down through them one more time. Then find some one that has BUDS and get it unhooked! Good luck my friend!! Technology you got to love it, and hate it at the same time.
    Last edited by Peter Aawen; 08-23-2023 at 09:05 AM. Reason: Merged immediately consecutive posts...
    2012 RTL , Pearl
  18. #1068
    May 2011
    Dacula, GA
    I have read the entire thread. It has been a long morning, lol. More info, this has been happening for a bit off and on. I can get by it, sometimes quickly, sometimes not (turning key on/off, waiting, etc). Does anyone know someone in the Atlanta area that can turn it off? If you don't want to post it, PM me. Thanks.
  19. #1069
    Very Active Member PaladinLV's Avatar
    Feb 2015
    Las Vegas
    The DESS error was covered by an SB!
    Sorry no longer remember number - look it up.
    An SB should mean (it is COVERED) by BRP and should not need to worry about cost.
    So "maybe" to save $$$ the Dealership will just disable via BUDs; then again maybe not.
    But the cost should be on BRP, not you.
    Check it out.
    AJ
    2014 RT-S
    Akrapovic Exhaust & Cat Bypass
    Bajaron Sway Bar w/links / Sena SM-10/Garmin 660
    Comfort Seat w Adjustable Backrest
    Decals by Purple Harley / Magic Strobe
    Kuryakyn Black Widow Pegs Rivco Highway Brackets
    Rivco Trunk Mounted Double Flag Holder
    FOBO / Spyder Cuff / XM Radio w MC Antenna
    2014 RT/S , Black
  20. #1070
    May 2011
    Dacula, GA
    RECORD_ID: 2917249
    Bulletin Number: A104494
    Replacement Service Bulletin Number: N/A
    NHTSA Item Number: 10185868
    Date Posted: 11-05-2015
    Component Name: 110000 ELECTRICAL SYSTEM
    Make: CAN-AM
    Model: SPYDER RT
    Year: 2014
    Date Added: 01-25-2021
    Summary: Intermittently, the ignition key may not be recognized causing the unit not to start.
    Found that. So if it has a SB, it is covered, even though it out of warranty??
  21. #1071
    RECORD_ID: 2917249
    Make: CAN-AM
    Model: SPYDER RT
    Year: 2014
    Since you are on the "DESS" thread, you think you have a DESS Failure issue ..... (ie. orange screen of Death). Contact your Dealer and see if they know about the SB and IF they will honor it? ..... As far as cancelling it, I seriously doubt the dealer will or even can do that ..... good news .... I'm pretty sure the "Netzley boys" will be selling at "Maggie Valley" in the beginning of Oct. (check the dates posted on the Home page) .... they now have the capability to CANCEL the DESS module. I would contact them and ask and or set up an appointment .... good luck .... Mike .... I just discovered that BAJARON (in Tenn.) can cancel DESS also ..... M
    Last edited by Peter Aawen; 09-08-2023 at 08:16 AM. Reason: Caps; ' 's; colours... ;-)
  22. #1072
    May 2011
    Dacula, GA
    Thanks BLUEKNIGHT911!! Will see about going to MV!!! Have not been to a Spyder function in some time!!
    Last edited by Peter Aawen; 09-08-2023 at 08:17 AM. Reason: Fixed quote display ;-)
  23. #1073
    Vermont
    Hawk,
    I don't know what the cost would be to fix it. The dealerships wont fix the disable DESS.
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  24. #1074
    Vermont
    Mikey,
    Yes, this thread has a lot of excellent info. Thank You!!! Yes, this thread is very long. Thanks
    Good luck!
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  25. #1075
    Vermont
    RECORD_ID: 2917249
    Make: CAN-AM
    Model: SPYDER RT
    Year: 2014
    Hawk,
    Where did you find the above info?
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
