Thanks Thanks:  564
Likes Likes:  356
Page 28 of 30 FirstFirst ... 1824252627282930 LastLast
Results 676 to 700 of 734
  1. #676
    Very Active Member trikermutha's Avatar
    Sep 2014
    USA
    Yes, the dealer should take care of the issue for you, it is covered" UNDER WARRENTY". Deanna
    Maybe out of warranty unless it was extended??
  2. #677
    Default ADDITIONAL USES
    Quote Originally Posted by rustynail51 View Post
    can hooking power supply cords such as heated clothing cords or trailer wiring harness directly to the battery give a d.e.s.s. code when neither is in use. The dealership asked these questions when trying to figure out why i continue to get the code after they replaced the d.e.s.s. module.
    From everything I know about DESS ( and this is more than most ) ..... I have not heard of extra electrical stuff being an issue..... The DESS module interacts with the chip in the ignition switch ..... Some here have had to get an ignition switch in conjunction with the module ..... I didn't but it isn't clear in the minds at BRP EXACTLY what causes the DESS failure...... there have been 4 different modules since 2014 ...... IMHO some engineer decided to fix a non-existant problem ..... the 2009 to 2013 didn't have a problem .... then the module was changed and BRP has problems up the WaZoo ....go figure ... Mike
  3. #678
    Vermont
    It is Covered under the "Extended Warranty"( B.E.S.T). Ask your dealership.
    Deanna
    2014RTS-SE6 Cognac I am a Happy Spyder Owner!
    BRP Semi-Rigid Rear Side Cargo Travel Bags
    BRP Glove Box Organizer
    Ron-rnet Laser Alignment
    TRIC-LED Spyderpockets
    STV Black Carbon Fiber Windshield Blackout
    WRAPMYSPYDER.COM Sceptor Kit Reflective Decals-Orange
    BLUEKNIGHT911 (Mike) painted Dashboard+ GPS plug-in
    BRP Half Cover
    WRAPMYSPYDER.COM Air Dam Web Decal Black Reflective
    General Altimax RT 43 Rear tire
    BRP Full cover
    TRIC-LEDS Front Fender Marker Lights & Saddlebag Markers Lights
  4. #679
    Houston
    We prefer the nuclear option. Just turn DESS OFF and be done with it. Useless system that only serves to keep the owner from riding. Does not deter theft by any knowledgeable vehicle theft team. Its easily bypassed without the key present.
    Blue Flame Spyder F3-S.
  5. #680
    Jan 2017
    Long Island new york
    Default Bow bypass?
    Jcthorne... how do u bypass? Mine is 2016 f3s e6
  6. #681
    Houston
    Quote Originally Posted by Sweetwater View Post
    Requires MegaTech version of BUDS. Several shops around the country offer it, including ours. Most dealers do not opt for the upgraded version that has access to the security system.
    In BUDS, its a simple toggle of a setting.
  7. #682
    Vermont
    Bump
    Deanna
    BRP Half Cover
    BRP Full cover
  8. #683
    Jax Beach, Fl.
    Well I have an appointment to take my Spyder into the Dealer 2-9-18. So will see how everything goes. I have to get it fixed because I don't want to get stranded out some where. Will let you know how it turns out.
    Cheers
    2014 RTL-SE6 Cognac (Current Love)
    2012 RTS-SE5 Pure Magnesium Metallic (Pre Loved)
  9. #684
    Indiana
    Default 2014 Spyder
    Thank You All. I had consider buying a used 2014, (in year 2016). I am now VERY glad that I went with a NEW 2016 RTL. PS: I did my homework on 'SPYDERLOVERS' Forum.
    2016 RT LIMITED, YES, color 'BLUE'
  10. #685
    Jax Beach, Fl.
    Well I picked up my Spyder this morning from the Dealer 2-13-18. Here is the Dealer comments as written on the work order. No codes stored in (BUDS). But we and BRP have seen this before, BRPS recommendation is to change out the DESS MODULE. If it comes back , then replace the DESS ANTENNA. So the DESS MODULE was replaced and both my keys were reprogrammed. This was accomplished under extended warranty and with no charges to me. I'm a happy camper and hope that this takes care of my DESS issue.
    Cheers
  11. #686
    Vermont
    Quote Originally Posted by A1A View Post
    Cheers
    The 2nd time( On Aug. 28, 2015) my dealership replaced the DESS MODULE, & Ignition Switch, Reprogramed Keys, Changed the trunk lock/and gave me a new trail lock. The above work was done @ 8,740 miles, and since then I have not had the DESS Key code show up on the screen. My current mileage is 22,000. Also I have a 2014RTS-SE6.
    The first time ( on July 14,2015) my dealership replaced the DESS MODULE.
    I hope you don't get the DESS issue Good Luck!
    Deanna
    Last edited by Deanna777; 02-15-2018 at 06:57 PM. Reason: added to post @ 2/15/2018 @ 6:57 pm
    BRP Half Cover
    BRP Full cover
  12. #687
    Sep 2014
    USA
    I am guessing go with the cheaper repair first then the harder more expensive repair next if the module doesn't work out.
  13. #688
    Jax Beach, Fl.
    The 2nd time( On Aug. 28, 2015) my dealership replaced the DESS MODULE, & Switch, Reprogramed Keys, Changed the trunk lock/and gave me a new trail lock. The above work was done @ 8,740 miles, and since then I have not had the DESS Key code show up on the screen. My current mileage is 22,000. Also I have a 2014RTS-SE6.
    Deanna
    Thanks Deanna, I had 18,803 miles on mine when the DESS MODULE was replaced. I also hope you do not get another DESS issue as well.
    Cheers
  14. #689
    Very Active Member irvin48's Avatar
    May 2016
    mt morris il
    anyone close to nw illinois that can deactivate.?-- irv toms
    lamonster fbb foot pegs[modified brackets], doc's
    7 jurock w/shield. brp comfort seat. , fomozas and
    altimax, magic mirror mts, and tricled wide mirrors.
    [joyce & irvin toms]
  15. #690
    Very Active Member PaladinLV's Avatar
    Feb 2015
    Las Vegas
    That DESS "antenna" they are speaking of is part of the ignition switch on a 2014. So the ignition switch is what they will replace.
    AJ
    Cheers
    2014 RT-S
    Akrapovic Exhaust & Cat Bypass
    Bajaron Sway Bar w/links / Sena SM-10/Garmin 660
    Comfort Seat w Adjustable Backrest
    Decals by Purple Harley / Magic Strobe
    Kuryakyn Black Widow Pegs Rivco Highway Brackets
    Rivco Trunk Mounted Double Flag Holder
    FOBO / Spyder Cuff / XM Radio w MC Antenna
  16. #691
    Vermont
    Cheers
    A1A, I hope I don't get another DESS issue either. If I do I'll post on this Thread ( which I started in July of 2015), If I do I know it is covered under the B.E.S.T Warranty.
    Good Luck!
    Deanna
    BRP Half Cover
    BRP Full cover
  17. #692
    Vermont
    Quote Originally Posted by PaladinLV View Post
    AJ
    AJ, Deanna
    BRP Half Cover
    BRP Full cover
  18. #693
    Vermont
    Bump
    Deanna
    BRP Half Cover
    BRP Full cover
  19. #694
    Vermont
    Bump.
    Deanna
    BRP Half Cover
    BRP Full cover
  20. #695
    Default KEYS !~!!!!!!!
    Cheers
    I've had my DESS module replaced .... by real BRP Tech's ...... they told me the keys have nothing to do with the DESS module ..... and they didn't do mine .......... So either your dealer isn't as up on this as they think they are or they just did it anyway for some unknown reason ...... Mike
  21. #696
    Active Member gerald37's Avatar
    Jul 2017
    Woodbine, Iowa
    I placed an order today for a DESS Module #710004916 with Cheap Motorcycle Parts. I am to have it next week sometime. I will switch it out myself. I have a 2015 Spyder RT and have had it little over 10 months and have put over 10,000 miles on it. It now has 20,700 miles on it. I have had DESS Key orange screen about 4 times, once last September and about two weeks ago and all I have ever had to do is remove the key and put it back. I was not much worried about it until BLUEKNIGHT911 tells me I am going to be stranded. I sure hope this is all I need. I only have one key so as soon as I get the module changed I have a blank key and will have it cut and someone program it for me.
    2015 RT Roadster
    Perl White
    Show Chrome Driver Beachcomber Floor Boards
    Show Chrome Driver Backrest
    Penstripping
    Lamonster RT Spyder Cuff For Phone
    Sena SMH-10 & SM10 Blue Tooth TransmitterW/ Daves Cable
    Doran Tire Monitoring System
    Magic Mirrors
    Doc's Belt Vibration Damper
    Set of Centramatic Balancers From Lamonster Garage
    Bajaron's Sway Bar
    Gold Drain Plugs
    K&N Air Filter
  22. #697
    Member gmctech's Avatar
    Aug 2016
    Antigonish, Nova Scotia
    Thumbs down
    My buddy had a 2018 out for the weekend to test drive... guess what? it went back on a tow truck! 772 km on it, parked it overnight at a resort we were all staying at (20 some bikes) and the next morning CHECK KEY error.... needless to say he was spun off into a new dimension of pissed off, especially when the Honda guys, the Kawi guy (that's me) and the Harley guys were all able to finish our ride and his tester s-h-i-t the bed. In the very short future I will be offering (for a reasonable price) DESS deactivation to any and all that never want to experience this stupid UNFIXED engineering flaw; this deactivation will be good for all BRP products..... I'm and automotive Red Seal GM Grand Master Technician with SET (specialized electrical training/certification) so I'm pretty sure if I couldn't get it running nobody could... I even tried a redundant ground ESD/EMI drain wire to the casing of the ignition switch housing in case there was a static charge in the pickup coil all to no avail.
    I do A LOT of work on local Spyders... I'm in no way shape or form crapping on them.. I'm just pointing out the cold hard obvious truth... they're actually a great bike except for this potentially hazardous flaw. Imagine getting caught somewhere on your Spyder or quad and extreme weather is barrelling down on you and you're not prepared for it or there's some other life threatening situation rapidly deteriorating (like an angry bear hot on your heels) and you hop on your ride only to experience CHECK KEY.... funny my bikes don't have any security like this, so I put on a simple $30 security systems and it is just as effective or actually even more effective than the DESS as my bike starts to scream bloody murder if you so much as look at it wrong and my security system cuts out the fuel injectors and spark; whereas a set of side cutters and your Spyder is quietly being pushed into a trailer and carted away even with DESS working. BRP REALLY needs to do as Ducati, Harley and Indian do and provide a means for a quick PIN code input and you're up and running (but I guess that would take away from the thousands of dollars of so called fixes they get to sell you outside of warranty).... or give you the option as it's your property to damn well deactivate it!
    Another one of my Spyder customers just spent $4500 getting this "fixed" on his Spyder that was 28 days outside of warranty and guess what he called up the other day saying he had the key error AGAIN (he had the DESS module, the ignition switch and the cluster replaced by a dealer I've never dealt with in a different province).... I know two Spyder owners that are now getting so fed up with this situation and water intrusion issues in fuse boxes etc etc... that they are actively looking for really nice used GL1800 Goldwings and will be having me install the Sturgis R18 kit on them.... The dealer they bought their spyders from is AWESOME, FLAT OUT AWESOME but BRP corporate are a bunch of arrogant jerks at best (well that's been our experience) .... end rant
    One last word of advice is if you experience the CHECK KEY error IT WILL LEAVE YOU STRANDED at some point.... the fiddling with the key, rapid ignition cycling, removing the ground for a period of time etc etc is all snake oil remedies and placebo effect... if your bike starts after one of those it's pure coincidence... we worked on this Spyder for well over an hour and tried everything short of sprinkling holy water on it and it still left on a flat deck.
    Last edited by gmctech; 06-30-2018 at 01:42 AM. Reason: factual typo, a bit more info
  23. #698
    Aug 2016
    Thumbs up
    Good afternoon.... I thought I'd chime in here with some personal experience. I've have had two times where accessories 100% interfered with the factory DESS to the point it initaiated no start conditions. First was on a New BRP snowmobile and i had installed an auxillary RCA style plug for power for heated gloves too close to the DESS knob... moved it to the other side of the sled and never had another issue problem solved.... second was on a 2011 Spyder RT Limited that I had installed AFTERMARKET HID headlights and fog lights and we were getting a a DESS induced intermitent no start.... re routed all the wiring, added relays for every light and installed EMI drain wires on the HID relay harnesses and that issue was resolved permanently. Just some food for thought from personal experience that there are some very weird isolated incidents that can induce DESS malfunctions and unintended DESS activation and no starts.
  24. #699
    Aug 2016
    Hello again... I'm not sure what they meant but the key has the excited transpoder chip inside thats part, parcel and an integral part of the DESS system.. if you cut a regular key blank, or the top breaks off your key, without that transponder chip, the DESS system cannot read the encrypted security code therefore it wont crank...
  25. #700
    Dec 2015
    Oakley Utah & Hurricane, Utah
    Requires MegaTech version of BUDS. Several shops around the country offer it, including ours. Most dealers do not opt for the upgraded version that has access to the security system.In BUDS, its a simple toggle of a setting.
    Any suggestions on how I can locate someone with the ability to disable DESS should I decide to do that?
    2014 RTL Magnesium & 2014 RTL Cognac
    Northern Utah in summer; Southern Utah in winter
