Page 2 of 2 FirstFirst 12
Results 26 to 34 of 34
  1. #26
    Sep 2017
    Durham,Maine
    It should; they haven't changed too much thru out all the years!!
    2012 RTL , Pearl
  2. #27
    Bossier LoUiSiAna
    Quote Originally Posted by Centurion View Post
    There are a few threads on this topic. I would first try having someone push on the lid surface up by where it latches while you attempt to open it.
    & maybe simultaneously trying all 3 latches at same time for hopefully lil extra movement If no work has been done to the trunk that would make it out of square or anything, overstuffed would still open with helping hand pushing down otherwise can try looking at parts layout on cheap cycle parts & get idea of what else may hang upgood luck
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
  3. #28
    Aug 2019
    WI
    Post
    I am glad that you got that handled. Gl 1500 Goldwings had a similar issue. I was trying to decide if it would be too mean to send this.
    I hope you have a sense of humor.
  4. #29
    Active Member Old Prof's Avatar
    Sep 2015
    Columbus, Ohio
    I saw this conversation about rear trunk stuck closed & you noted the "fix" suggested did not work on your '16 RTY. I am having the same problem with my '16.
    How did you get yours open? Thanks!
    2016 RTS SE6
    '64 Honda CA95 "Dream"
  5. #30
    Jun 2016
    Harrington, Australia
    Quote Originally Posted by Old Prof View Post
    Old Prof, Fuzz only ever made one post on this in 2019, and I have not seen a post from him since, so he may not even log on any more. You would be better served starting a new thread with your question, if a search doesn’t turn anything up.
    Pete
    2021 RT Limited
    HeliBars Handlebars
    Kenda Kanine rear.
  6. #31
    Sep 2015
    Columbus, Ohio
    Back panel tab not seated. Raised panel puts tension on latch. Trunk won't open.
    Take a standard 2" putty knife, the flexible kind. Slip in the center of the gap above the latch and below the trunk lid. Insert until you can press the black inner panel with the hole in it for the back panel tab to drop into. Remove putty knife. Open trunk.
    from cptjam
    2016 RTS SE6
  7. #32
    Sep 2015
    Columbus, Ohio
    from cptjam
    WELL...it sure sounded like it should work. Tried it this morning on my '16 RTS...no luck!
    I think I'm going to start a new thread (link below) & see what comes of that. At least it doesn't prevent me from riding!!!
    https://www.spyderlovers.com/forums/...ition-Solution
    2016 RTS SE6
  8. #33
    Jun 2016
    I think I'm going to start a new thread & see what comes of that. At least it doesn't prevent me from riding!!!
    Unusual for cptjam’s solutions not to work, Old Prof. Hopefully your new thread might get a few more answers for you……at least you can ride, as you say
    Pete
    2021 RT Limited
    HeliBars Handlebars
    Kenda Kanine rear.
  9. #34
    Oct 2020
    Arizona
    Took this picture with installing my home brewed flashing third brake light with timer to turn it steady on after 5 or 6 second. It shows more detail of the latches.
Tags for this Thread
