Results 1 to 6 of 6
    Active Member Moosemanj's Avatar
    Pensacola FL
    Default 2012 RT SE5 Parking Brake
    Went to start my Spyder and I have a ! point where the P normally is for the parking brake. I can't get the brake to disengage. I have tried rocking the bike and it will not disengage. Any help would be appreciated, can't even get it out of the garage to take it to the shop.
    Lancaster CA/ Oak Harbor WA
    Default parking brake release
    Check your battery voltage. My 2011 RT did that a while back, the battery was strong enough to light the panel but wouldn't release any thing or allow it to start.
    Pensacola FL
    Default Parking Brake Release
    Quote Originally Posted by sharbill View Post
    It starts and still will not release.
    Very Active Member spyderbirds's Avatar
    Apr 2011
    Bowling Green, FL
    Quote Originally Posted by Moosemanj View Post
    Actuate the brake on and off and watch the pulley on rear wheel (muffler side)
    See if it is rotating while the actuation of brake happens. Had my cable go bad and in that case I had to "help" the release by assisting the clockwise rotation of the pulley by hand to release.
    The cable may have also came off the pulley up front under the tupperware mid way forward on same side.
    2015 Intense Red Pearl RTS SE6 - Laser Alignment by Precisyon Trac, Tri-Axis handle bars, ? to be determined.
    2014 XLR Viper 305V14 Toyhauler (Home)
    2015 Ram 3500HD Crew Cab
    Former Spyders
    2010 Blue RT A&C SE5 53K plus miles - never left us stranded!
    2013 Pure Magnesium Metallic ST SE5 11K plus miles - never left us stranded!
    RT-S PE#0801 timeless's Avatar
    May 2010
    Punta Gorda, Florida
    Default happened to me also
    Quote Originally Posted by spyderbirds View Post
    I had the same thing happen to me and a little helping hand to make the lower pulley rotate to release parking brake. You will probably need to lubricate the pulley mating surfaces & operate it several times to get consistent release.
    Jul 2010
    Las Vegas, NV
    Default Cable
    There are 2 jam nuts on the cable where it goes into the parking brake assembly. Loosen both, remove cable from bracket. The pulley on the brake should rotate around, releasing the brake. Before you do that, chock the wheels so it does not roll. If you can, remove the side panel, inspect the cable and remove it. It should slide in it's sleeve (cover). If not, it is either ruined, or, needs to be lubed. Try lubing it first. Make a funnel out of tape, around one end of the cable. Put the other end in a bucket, and hang the cable up. Pour in a light oil, and let it work it's way through. Takes a while. Once you see oil dripping out of the cable into the bucket, try sliding the cable back and forth. If it still won't slide, it needs to be replaced. Get a new one. if it slides properly, put it back on, and test it. Call if you get stuck. Joe
    Joe Meyer
