Need Help
Today I'm installing the JT's GPS/ Power outlet bracket that mounts to the top of the dash. Along with the bracket I'm running the power cables down to the battery for my GPS and a UBS/ 15 volt power outlet. Here's my question, What is the correct procedure when I go to connect the positive or negative cables up to the battery. Should I connect the positives first or connect both negatives first?? I just don't want to cause nanny to give me any fault codes if I do something wrong. Thanks for all who reply.
2008 Triumph Rocket (SOLD)
2002 Honda VTX 1800 C ( SOLD)
I assume you will have ignition switch off until you have completed the hook ups. Positive first, negative second.
Yes switch will be turned off. Thanks
If you are powering them directly from the battery, you should have a fuse in the line.
2008 GS SM5, Full Moon Silver
2007 Piaggio MP3 - 250cc
Connection sequence
Good electrical practice dictates the the ground (negative) should be first connected and last removed. That provides a path to discharge any static electricity that might be present without damaging the device being worked on.
Larry
2012 RT Limited Pearl White
Baja Ron anti sway bar, BRP trailer hitch, BRP Comfort seat and Back rest,
SpyderPops Bumpskid, Vertika Floorboards, High mount Stop/Run and Turn signals,
SM10 Dongle and SMH10 headset, ISO Handgrips
More to come.
Yes the power cables are fused. Thanks for everyone that replied. This forum is great.
Here's what I do...
I always disconnect the negative first. If you touch it to any part of the metal parts there will be no sparking or ground causing shorts or messing up things. Once the negative cable is secured remove the positive. The unit is no longer grounded so if the positive should touch any metal parts nothing will happen. When reinstalling connect the positive first then the negative. If you do it the other way....make sure you, your tools or the positive cable is insulated..
Gene and Ilana De Laney
Mt. Helix, California
2012 RS sm5
One tells me the negative first and then another tells me, no the positive first. Well everything is hooked up and powered up and all is working so I guess I did it correct. Plus I didn't get any codes. Went for a ride and all is well.
Chupaca is correct. In the automotive world you always disconnect the ground wire first and connect it last. If you do not follow that sequence and the tool you have on the hot terminal touches metal you will gain a real understanding of why you should not do it that way. It is likely that you will also teach any bystanders some new words.
Sent from my XT1045 using Tapatalk
Clifford Fargason
2013 Spyder RTL
2007 Royal Star Venture
When connection - positive first, when disconnection - negative first!
2015 an Am Spyder RT Limited
2013 Yamaha WR250R - Sold
2011 Can Am Spyder RT-S SE5 Limited - Sold
2011 Aspen Sentry Trailer
2003 BMW K1200LT - Sold
2007 Unigo Trailer - Sold
2001 BMW K1200LT - Sold
2001 Honda 750 NightHawk - sold
2015 RT Ltd , Canamspyderaccessories Brake pedal ext. Red
