Anyone notice this on their RT
When reversing on my RT SE6 2015 Model I select the 4 way hazard flashers to give extra safety
I notice when you do this the R icon in the cluster also flashers
If you don't put on the hazard flashers the R icon remains steady
Just interested if others have found this as well
Eddie Sheppard
Poole Dorset UK
Get a Spyder - See the World
I haven't noticed this, but I will check it out this weekend on our ryde.
Kent.
Ride Safe All
2014 RT Limited (Charlotte) in Cognac, Kuryakyn Grips,Tri-Axis Handle Bars, Rivco Armrests, a "finless" BT Dongle, TricLed Fender, Saddlebag, 3rd & 4th brake Lights, Custom Dynamics "Magic Strobes Brake Flasher", BajaRon Sway Bar & Spring Adjusters, Lighted Bumpskid, Rivco Highway Pegs, Rivco Cup Holders and Baker Built Air Wings. 215/60R-15 General Altimax Rt rear tire. 155/60R15 Kumho Solus front tires.
My 2014 RS does the hazard lights automatically when reverse is selected
All the great movements in the world began with a cup of coffee!
2018 F3-T
My mods: Can am Trailer hitch, USB and 12 volt power outlets, Gustason windshield, Bead rider seat cushion, battery harness for electric gear and battery tender, Time out trailer.
As I see it..!!
All the ones I have seen turn on the four way automatically when you shift into reverse and the indicator flashes on the dash. This, unless you have backup lights, is the indication you are backing up and gives you some light if dark...
When I had my 2012 RS the flashers would come on when in reverse. Not sure if this is because they aren't as visible as the RT or not. I haven't noticed it on my 14' RTS yet.
My 12' RS and my friends 11' RSS both flash in reverse.
Sent from my SCH-I545 using Tapatalk
Originally Posted by MisterP
i believe this is standard in Canada and other countries. I wonder why yours is configured that way?
It's not a standard in Canada. Only RS are configurated that way. Another engineer bright idea....
My 2014 RTL doesn't flash the hazard lights when in reverse...
Had to run an errand right after reading first post so I checked. My SE does not activate hazard lights when I shift into R but I have backup lights. I normally push R button with left thumb and shift into R with a left finger so I even did a two handed shift to make certain I was pushing the reverse button down far enough to make complete contact. If I push hazard switch R flashes in addition to lights. The 14 operator's guide addresses the hazard lights flashing when shifting into R on the SM model but not on the SE. It says in the info on the reverse button that backup lights turn on when vehicle is in reverse. In Basic Procedures section it explains the hazard flashing only when discussing operating in reverse on SM model. A quick look as the '15 operators guide shows explanations are the same as '14 manual.
otherwise be a vulgar brawl.
Cognac 2014 RT-S
From what JayBros says above, the 2014's do this as well. My 2013 RT SE5 does not. You can, of course, turn on the flashers in reverse, but the "R" does not flash.
Nor mine.
Jack
2015 BMW R1200R LC
2014 RTL SE6 Pearl White
2012 RT-622 trailer viper red
2011 Polaris Ranger green
2016 Can Am Maverick
On my 2014RTS-SE6 my hazard lights do not flash, when I am in reverse either. Deanna
Gremlin Bell
SpyderPops Missing Guard Belt
Ultimate F3 Floorboards
Sway Bar with Links
Rolo Laser Alignment
Half Cover
Show chrome Trunk Shock
my 2014RTS-SE6 the "R" does not flash. I will have to check the next time I go riding. Deanna
Gremlin Bell
Sway Bar with Links
Half Cover
The RS does not have a rev.Light,so it uses the hazard lights in rev.,the RT have a Rev.(white) light so it does not use hazard lights. did no one notice this?
Flashing Hazard lights
I have an 2013 ST and when in reverse the hazards have always flashed from day one.
Just to clear up any confusion
When using reverse. the twin rear reversing lights come on and the R in the display remains steading
It's. when I operate the hazard switch manually when reversing that is when the R in the display flashes or course both the Green.arrows in the display also flash as well
It maybe a safety feature to warn you that the Reverse is selected whilst you are dispylaying the Hazards as most would assume you are not moving due to a breakdown. etc
Eddie Sheppard
Poole Dorset UK
Please remember when you put a '14 SE in reverse two Rs display, one on the analog speedometer and one in the digital cluster. If you push the hazard light switch it's the R in the analog speedo that flashes, not the R in the digital cluster.
Cognac 2014 RT-S
I don't think my hazard lights flash on my SM. I was going to go out to the garage to check but no one is here to tell me if they flash. I know for sure that the front hazard lights do not flash in reverse.
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
I checked on our 2014 RTL and the hazards do not come on in "R", however if I turn on the hazards while in "R" the "R" does flash!
Ride Safe All
Check your manual. This may be a UK requirement. My 2013 RT does not flash the R regardless of which, reverse gear or hazard lights, I turn on first.
2014 Copper RTS
