Are all iPods compatible with the 2014 RT?
Are all iPods compatible with the 2014 RT SE6, thanks Dave
Reason: Caps
Originally Posted by dudewilson
Are all iPods compatible with the 2014 th se6,thanks Dave
Thanks Dave New spyder owner
I would say the manual comes up short for all the compatible IPod versions that work.
We got a new IPod Nano 7th gen with the Apple adapter and it works better than I can remember how to hit the buttons on the left grip.
IPod for us was a very solid and worthwhile add on.
PK
IF... I could only get it to change playlists for me!
I STILL haven't been able to "crack that nut"...
But I'm getting closer, with each attempt!
Now; it'll show my playlists; I've just got to figure out how to choose one, get it to accept that command, and then get back to a "normal" display...
Changing playlists in motion or when stopped?
2018 F3 LIMITED
You buy IPOD 4 it work fine ,ipod nano work but new plug in like iphone 5 ,6 or new ipod 5 ,you have to buy adaptor to make it work, down load all the song from itunes to ipod ,you can control forward, backward any song you want while you ride or stop . I bought my ipod 4 with 64GH and put over thousand song in there
You have to be stopped to change playlist.
You can change the playlist while stopped or in motion just different button presses.
2018 F3 LIMITED
Bob, what I have learned is that it is a timing thing. Some things require a short push of the button while others require a long push of the button and others still sometimes need a push and hold.
I get PO'd at it also, for a while I thought the IPod simply just loved Alan Jackson.
Honestly, if they put that Spyder left grip into an aircraft, the pilot would never get a missile launched...
PK
I can bring up the playlists, artists and albums...
I can move the cursor to the right, and then up and down...
Once I get it on what I want; I get lost!
Ok you're trying to change playlists while stopped. Once you have picked what you want move the cursor to the right.
2018 F3 LIMITED
2014 Copper RTS
Thx finless!
Posted this while back fyi. BOB you should know & hope this helps
I upgraded my iPhone 5 to a 6 and now use my iPhone 5 as an iPod.....
just my my two cents....
howard
AAAH waswinger spoiled it. I guess I should have made it clear it was a hint not a step by step.
Now you're going to have to learn how to change playlists on the go.
2018 F3 LIMITED
Originally Posted by WasWinger
While you're riding you do a long press, either left or right, to change to preceding/next album or playlist. That is if you haven't turn off the key and then back on. In that case the long press takes you to the last or first album or playlist in the entire library. This is a bug in the software BRP is aware of but doesn't want to bother to fix.
For some reason this does not always work for me. But if you do a long press. The song will cut out for a split second. Release and then do a quick press it will change songs and the playlist.
2018 F3 LIMITED
Actually it brings up a song list. You select the song, then do cursor right again.
That does not work for me either! A long press puts it in random song playing "shuffle" mode.
Must be some differences in iPods or something.
Bob
Bob
If you have the iPod in playlist mode, then the first long press after starting the bike takes you to the first item in the playlist, which must be All Songs if you have an All Songs playlist. That is a random playback sequence. I have my iPod in album mode so the first long press of the right or left button takes me to the first or last album in the list. After the first long press subsequent presses will step you up or down (right or left button) through the playlist list or album list.
If you select a playlist or album via the screens, then a long press takes you the next, or previous, one in the list. But any time you kill the engine upon restart the first long press takes you back to first/last album or playlist. This is the s/w bug in the cluster that BRP has no plans to fix.
2014 Copper RTS
