Results 1 to 9 of 9
    Jul 2015
    Australia
    Default Motorcycle dolly
    Anyone seen one of these to suit the spyders ? RS.
    I'm pushed for space I need to jack up the rear and swing it around into my shed so I can fit my other toys in .
    http://www.ebay.com.au/itm/Motorcycl...item339f27c0fa
    Very Active Member Vader's Avatar
    Hudson Valley
    Default What I use
    Here's what I use..a pair of car dollys for the front tires and a small wooden furniture dolly for the rear tire. Total cost was about $50-60.
    http://http://m.harborfreight.com/2-...not%20provided
    The wooden dolly is also available from the same site.
    Hope this helps
    IT IS, WHAT IT IS...
    Default Here's what I do...
    Though not lacking space when I need to move more into the light... but the one your looking at will work nicely if you don't have a trailer hitch. Run a rod through the axel with enough out each end to be able to clip onto...
    Aug 2013
    Winnipeg, Manitoba
    Quote Originally Posted by 109spyder View Post
    I use a snow machine dolly.....they come in three's....only issue is when you go to move it you have to have someone on machine with brake on as front wheels move when you push machine .
    http://www.amazon.com/Extreme-Max-58...owmobile+dolly
    Jul 2015
    Edmonton AB Canada
    Default Snow machine dollys
    Quote Originally Posted by Steve67 View Post
    Do do you have to jack up each wheel to put the dolly under the wheel?
    Oct 2015
    Orange City, FL
    Yes, the dolly instructions state to safely jack the vehicle.
    The rear motorcycle stand, if you could find one wide enough, would lift the rear tire but it does not move around, unless you pick the rear of the motorcycle up.
    Jack and the dollies should work nicely.
    Active Member nightcruiser's Avatar
    Feb 2019
    Indiana
    bad link.
    Quote Originally Posted by Vader View Post
    Hope this helps
    Durham,Maine
    Quote Originally Posted by nightcruiser View Post
    bad link.
    Hope this helps
    The post was started in 2015 that may have some thing to do with it not working!! Sorry,, these old post some time crack me up, people hall the things out of the library of knowledge, and start helping some one out that has had four more bikes sence then!!
    2012 RTL , Pearl
    Hudson Valley
