BajaRon Sway Bar needed on 2014?
I read a lot about how much the BajaRon helps the 2013 ST. Is the 2014 improved as is or are the sway bars still just as important? Anybody put them on a 2014ST? Did it make a big difference?
Uh huh
2014 sway bar
I asked the same question and without a definitive answer recently install Baja Ron's on my 2014 RT Limited. One up I noticed little difference in the feel of the bike and wondered if I had wasted the money. That was until I noticed that, while the bike felt the same - surefooted and stable, I noticed that I was taking the turns significantly faster. Then the real confirmation came when the rear admiral mentioned how much better the bike felt in the turns - not having to hold on for dear life on our country roads. So I would say the bars make a subtle but measurable difference.
This is one item the manufactore should take notice of and change. Makes foramuch better ride.
Do not hesitate it will make a huge difference.
Kenn
Probably not necessary if riding solo on the 14 and 15. If riding two up or you are heavy, yes it does help. Bar does not have the drastic effect it had on the 2013 and prior RT. 2014 and later have a completely different front end suspension and also an enhanced sway bar.
Jack
2015 BMW R1200R LC
2014 RTL SE6 Pearl White
2012 RT-622 trailer viper red
2011 Polaris Ranger green
2016 Can Am Maverick
Jack
I don't know about riding two up. But the sway bar made a huge difference on my 2014 rt s. And I ride solo... Highly recommended them.
2014 RT-S
YELLOW
BajaRon Anti Sway bar
Adjustable handle bars
SpyderPops Skid plate
Jack
We (2 up) just got back from riding all over the Black Hills (Needles Hwy, Iron Mtn. Road, Spearfish Canyon, Nemo Road and all others) with my 2014RT Limited and I do NOT have the overpriced sway bar and DID NOT have any problems negotiating all of the turns etc...
and I kept up with two Spyders that had the bar????
Just an FYI.
BIG F
We have the BajaRon anti-sway bar on both the 2010 RT and the 2013 ST and it made a very noticeable improvement in both.
Its not a matter of being able to negotiate a turn or keep up, but the comfort factor and secure feeling when doing so.
All in all it is the best value for the dollar of any item I have done on the spyders, Not at all overpriced in my opinion.
Don't like my opinion, use your own...
2015 Intense Red Pearl RTS SE6 - Laser Alignment by Precisyon Trac, Tri-Axis handle bars, ? to be determined.
2014 XLR Viper 305V14 Toyhauler (Home)
2015 Ram 3500HD Crew Cab
Former Spyders
2010 Blue RT A&C SE5 53K plus miles - never left us stranded!
2013 Pure Magnesium Metallic ST SE5 11K plus miles - never left us stranded!
I got one and Yes It made a big difference. You will gain a lot mire confidence on the turns and twisties.also make it a piont to get the heim links. When you see those cheap ones that are on the spyder, you will wonder why they did that. They look like something that came out of a cracker jack box.
2017 F3 Limited
Just an FYI.
BIG F
I guess my wife cast's a taller shadow than yours!
Jack
2015 BMW R1200R LC
