Results 1 to 17 of 17
    Active Member remark2013's Avatar
    Sep 2014
    Los Alamos, New Mexico
    Default How much Ride On
    I am about to install a new rear tire on our bike, a 215/60R-15 GENERAL ALTIMAX RT. Looking on the "Ride On" web sight is suggests 13-14 oz. is that what everyone is using?
    Kent.
    Ride Safe All
    2014 RT Limited (Charlotte) in Cognac, Kuryakyn Grips,Tri-Axis Handle Bars, Rivco Armrests, a "finless" BT Dongle, TricLed Fender, Saddlebag, 3rd & 4th brake Lights, Custom Dynamics "Magic Strobes Brake Flasher", BajaRon Sway Bar & Spring Adjusters, Lighted Bumpskid, Rivco Highway Pegs, Rivco Cup Holders and Baker Built Air Wings. 215/60R-15 General Altimax Rt rear tire. 155/60R15 Kumho Solus front tires.
    Pragmatic Member Pampurrs's Avatar
    Mar 2015
    San Tan Valley, AZ
    Quote Originally Posted by remark2013 View Post
    Kent.
    I've always used the recommended amount, and then some on all the motorcycles I've owned and all the tires I've had mounted. More is better than less. On my Spyder, I emptied (4) 8 oz bottles into the three tires.
    Pam
    • 2015 RT-S Special Series / Red & Black
    • Baja Ron Sway Bar
    • Utopia Backrest
    • F4 Customs tall and wide vented windshield
    • Stebel Super Loud Air Horn
    • Baker Built Air Wings
    • LaMonster Highway Pegs
    • SpyderPops Exhaust Block Off Plate
    • SpyderPops KOTT Grill
    • SpyderPops Belt Guard
    • Cat Bypass
    • Laser Alignment by Squared Away
    • TricLED Fender Lights
    • General Altimax RT43 rear tire
    • Dual flag holder
    • Mud Flap
    • A$$hole seeking missile system
    Very Active Member Big Arm's Avatar
    Jul 2008
    Sioux City, Iowa and Tucson, AZ
    Quote Originally Posted by Pampurrs View Post
    Pam
    I think the 13 to 14 oz. seems like what I used on my first tire.
    Pam......sounds like you could use a little more in each tire. 3 into 32oz = 10.6 oz.
    ....and we're gonna ride, we're gonna ride.....
    ride like the one-eyed Jack of Diamonds, with
    the devil close behind,.....we're gonna ride....
    2008 GS.....PE # 2888
    western Colorado
    Kent.
    are you doing car or motorcycle formula? I just talk to customer care at ride on & was told they are working on better new formula & to wait till 1st of August to order. I run car type. You get more for money
    Sep 2014
    Quote Originally Posted by happyspyder2039 View Post
    Thought I purchased the "Car" formula, but just looked at the bottle and it's the Motorcycle formula.
    Guess I need to order another bottle because all I have is 8oz.
    Ride Safe All
    Very Active Member Jim&Teresa's Avatar
    Jun 2013
    Woodbury, MN
    Default Here's some info from the Ride On website - fyi
    Looked this up for the Can AM Spyders ....FYI....
    Not currently using this, however, considering it the next change in tires!
    http://www.ride-onshop.com/Trikes_Ca...m_Spyders.html
    Happy and safe rydin'
    2014 Spyder RT Limited - January 2014, Cognac/Black Seat, #958, born on 1-8-14
    2014 RT Limited , Cognac
    Aug 2007
    Greeneville, TN
    Since the Spyder runs a car tire. The car tire Ride-On works better than the motorcycle version. They are different formulas and the car tire version is less expensive too.
    Nov 2008
    Edmonton / Alberta
    Been a while for me since I did it, but pretty much followed the mfg recomendation and maybe a smidge more. It has saved my bacon and well worth it in my opinion.
    Dec 2008
    Syracuse, NY
    Default Here's Lamont's chart for ride on
    Sep 2014
    So wheres the best place to purchase Ride-On from? Amazon only lists the motorcycle formula and I had to return the one I bought because the bottle was damaged and leaked.
    Kent.
    Ride Safe All
    Invalid Emails
    Jun 2015
    quinlan, tx
    Kent.
    I just bought some from the "Ride-On" website. No problems and fast shipping. I ordered the automobile formula, but haven't installed it yet. Spyder is in for service, but I'm going to install it as soon as I get it back.
    Very Active Member IWN2RYD's Avatar
    Apr 2010
    Puget Sound, WA.
    I followed the instructions. So far so good. I do believe that this product helped us at least twice so far. And like mentioned above, it is not slimy for when the tire needs to be removed from the rim.
    This also works great in our portable generator tires, dolly and wheel barrel. The added benefit we enjoy, less wheel vibration...
    BlUe SpYder RT-S SE5 #303I don't suffer from insanity; I enjoy every minute of it ... Proud Member of A.S.S. (Average Senile Spyderryder)
    Our 2010 RT-S Mods... *Warning* If you can read this, it is already too late and there is no known cure. You have Spydervirus.
    Mar 2015
    San Tan Valley, AZ
    Quote Originally Posted by Big Arm View Post
    You don't put as much in the front tires as you do in the rear. If you look at the chart on Ride On web site, look up our tire sizes you will see. I put just the right amount in each of the front tires, and in the rear tire.
    Pam
    • Baja Ron Sway Bar
    • Utopia Backrest
    • Cat Bypass
    • Dual flag holder
    • Mud Flap
    Mar 2015
    San Tan Valley, AZ
    I put the motorcycle formula in mine. I'm under the impression my Spyder came with motorcycle tires from the factory. It's working just fine.
    When I switch over to car tires, I'll use the car formula of course.
    Pam
    • Baja Ron Sway Bar
    • Utopia Backrest
    • Cat Bypass
    • Dual flag holder
    • Mud Flap
    Very Active Member Silvervette05's Avatar
    Sep 2012
    Maynardville,TN
    What does that stuff do to the in side of the wheel?
    Mar 2015
    San Tan Valley, AZ
    Quote Originally Posted by Silvervette05 View Post
    It provides dynamic balancing just the same as Dyna Beads does. The extra advantage of Ride On is its puncture protection.
    Check out the info on their site. http://www.ride-on.com/
    Pam
    • Baja Ron Sway Bar
    • Utopia Backrest
    • Cat Bypass
    • Dual flag holder
    • Mud Flap
    Active Member johnwinslow's Avatar
    Jul 2011
    Waterboro, Maine
    yes, watch the video http://www.ride-on.com/
