Page 1 of 3 123 LastLast
Results 1 to 25 of 63
    Jun 2011
    Columbus, Ohio
    Default Help! Stranded in Alabama with frozen ignition.
    I checked into a hotel last night here in Daphne Alabama. I'm riding my 2014 Spyder on a tour of both coast. This is day 13 of a 27 day ride.
    This morning my ignition is frozen. I can insert either of my keys but neither will turn. I tried WD40 with no luck. No sign of damage to the lock, and the cover was still in place this morning so I don't think it was tampered with.
    Here are my questions:
    1. Dealer recommendations in Mobile area?
    2. Is there a way to manually disengage the parking brake so I can get the bike on a tow truck?
    3. Any other quick remedies I could try?
    Thanks
    Rod
    2014 Spyder RT LTD, 2010 RT-622
    Very Active Member Jim&Teresa's Avatar
    Jun 2013
    Woodbury, MN
    Default Question
    Quote Originally Posted by Cyclist922 View Post
    Thanks
    Rod
    Did you lock your steering? If so, it maybe jamming the lock mechanism....IF you did lock your steering, pull your handlebars one direction (or the other) to help the lock loosen so you can turn the key.
    My thoughts - good luck and be safe!
    Happy and safe rydin'
    2014 Spyder RT Limited - January 2014, Cognac/Black Seat, #958, born on 1-8-14
    2014 RT Limited , Cognac
    Jul 2014
    Mint Hill, NC
    Is the Spyder completely locked, i.e., handlebars turned hard left or right. If so trying applying pressure farther into hard over position as you attempt to turn key.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Jun 2015
    Madisonville, KY
    Did you lock your handlebars? I am new to the spyder, but on my gold wing this could be the cause. If so try turning the bars toward the locked position. Just a guess. Good luck. I will pray for you. Poppy1144
    Jun 2011
    Columbus, Ohio
    Good advice. It feels like the handlebar is locked but no, they are pointed straight ahead. I've tried turning hard left and right with no luck.
    This was an issue for some of the earlier 2014 models; was yours ever replaced?
    Jun 2011
    Columbus, Ohio
    Bob,
    No. I've had it into the dealer a few times but they've never mentioned the service bulletin.
    I'll see what I can find about it for you...
    Jul 2014
    Mint Hill, NC
    The only way I know of safely trying to disengage the parking brake would be to completely back off the brake cable adjustment nut. You will need a 12 mm open end wrench. The nut is just forward of the brake cable support. Turn the nut toward the front of the Spyder as far as it will go and you should get enough slack in the cable to remove it from the support but I am not certain of this. The nut will turn hard as you start but should become easier as you create slack in the cable. Be certain the cable housing doesn't turn with the nut. Since you're going to a dealer they can readjust after solving your key problem.
    Cognac 2014 RT-S
    Very Active Member bruiser's Avatar
    Eastern North Carolina
    You can disengage the brake by pulling the pin at the rear caliper. You have a DESS failure. The security sensor does not recognize you keys. Sensor must be replaced.
    USAF '69-'89 E7
    Thailand/Vietnam 1972
    Here's a link to that thread about the TSB...
    http://www.spyderlovers.com/forums/s...rvice-Bulletin
    Registered Users wiredgeorge's Avatar
    Apr 2015
    Mico TX
    Isn't there someone in the Mobile area who can recommend a reputable dealer who could help this guy?
    wiredgeorge Mico TX
    2010 Can-Am Spyder RT SM5
    Active Member cyclekid58's Avatar
    Sep 2014
    Post Falls Idaho
    Default Locked Key
    I had that same issue, I sprayed some lock graphite into the keyhole and by jiggling the key for a bit got it to unlock and start the bike, then drove straight to the dealer where the ignition switch was replaced under the TSB, it was a known problem and my dealer replaced a number of them on the early 14's.
    Greetings from Idaho
    2014 RT-S,
    Barjaron swaybar, chome luggage rack, Ram Mount GPS, 12 volt dash outlet, spyderflap mudflap, Rivco flag mounts, drink2go and custom handlebar drink holders,Driver Backrest,Tri-Axis Handlebars, TRICLed turn signal lights. Custon Dynamic Magic Strobe Brake Modulator, Triple Dash Pouches, "Squared Away" Laser Alignment, Spyderpops Bumpskid, TricLed "Knightrider" LED
    2014 RT , White (Mine) Cognac (wifes)
    Default Curious..!!
    could you have the wrong keys..?? most commonly it is a chip communication failure but it would seem you have stuck tumblers. Releasing the cable and having the bars free will let you load her up. Do you normally lock the bars..?? Could be the bars were forced snaping the locking pin and damaging the ignition. If they were intending on rolling it away park brake would be the stopper..hopefully just a bad switch warranty work and you'll be on your way...let us know..
    ​2012 RS sm5
    Default YOUR ISSUE
    Quote Originally Posted by bruiser View Post
    Due to more frequent problems with the D.E.S.S. , I agree with Bruiser and think this may be the cause.........however some of the very early production Spyder Rt's had Ignition switch problems ........how old it your's ???????....................and have you ever had the " KEY " symbol flash on the instrument screen ????........................good luck.......I think the Dealer should provide the TOW on this ............Mike
    Jul 2011
    Mitchell, Ontario, Canada
    He is not going to get a key symbol on the screen when the ignition switch can't be turned on!!!!!!!
    2018 F3 LIMITED
    Active Member hillrider's Avatar
    Nov 2014
    White GA
    Try
    Hall's Motorsports
    1520 W I-65 Service Road
    251-666-7000
    addy from spyder zumo
    '15 RTS
    Default huh
    I meant in the PAST........I didn't think I had to say that to Him, I figured He would realize this !!!!!!!................Mike
    Mike,
    I'm pretty sure that the TSB was dealing with a mechanical issue with the switch. the "KEY" error (I think!) would seem to be more a case of the computer and the key not speaking quite the same language...
    One probably has very little, to do with the other.
    Jun 2011
    Columbus, Ohio
    Thanks all. The truck is in the way. I'll have it towed to Halls. My key tag number is 1760. Not sure if that number was in the service bulletin. I've never had a DESS error. The bike was delivered in February of 2014 so it's relatively early in the production run.
    The list of affected keys...
    gain, this is just to help out. It seems some have received incorrect info. There are a lot of key tags on the list. If you lost or discarded of your key tag and your vin is on the list you still need to have it checked. Here is a list of the key tags that are affected. 1656 1750 1800 1900 2009 2163 2200
    1657 1751 1801 1901 2010 2164 2202
    1658 1752 1802 1902 2011 2165 2203
    1659 1754 1803 1903 2013 2166 2204
    1661 1755 1805 1905 2014 2167 2205
    1662 1756 1806 1906 2015 2169 2206
    1663 1758 1807 1907 2017 2170 2208
    1665 1759 1890 1908 2018 2171 2209
    1666 1760 1891 1909 2019 2173 2211
    1667 1761 1892 1910 2020 2174 2212
    1668 1762 1893 1912 2021 2175 2213
    1669 1764 1894 1913 2023 2176 2214
    1670 1765 1896 1914 2024 2177 2215
    1671 1766 1897 1915 2025 2178 2217
    1673 1768 1899 1917 2027 2180 2218
    1674 1769 1918 2028 2181 2220
    1676 1770 1920 2029 2182 2221
    1677 1771 1921 2030 2183 2222
    1772 1922 2031 2184 2223
    1773 1923 2032 2185 2224
    1774 1924 2033 2186 2226
    1775 1926 2034 2187 2227
    1777 1927 2036 2189 2229
    1778 1929 2037 2190 2230
    1780 1930 2039 2192 2231
    1781 1931 2040 2193 2232
    1782 1932 2041 2194 2233
    1783 1933 2042 2195 2235
    1784 1934 2043 2196 2236
    1785 1936 2044 2198 2237
    1787 2046 2199 2239
    1788 2047 2240
    1789 2048 2241
    1791 2050 2242
    1792 2051 2243
    1793 2052 2244
    1794 2053 2245
    1795 2054 2246
    1797 2056 2248
    1798 2057 2249
    2059 2251
    2060 2252
    2061
    2062
    2064
    2065
    2066
    It appears that 1760 is on the list.
    Jun 2011
    Columbus, Ohio
    Thanks, I'll point this out to the dealer when I get there. The service manager said they have not seen this issue before.
    Jul 2011
    Mike,
    That's correct Bob.
    The 2014's have 2 different problems with the ignition and keys.
    Problem one. Ignition switches with a certain series of key codes will get stuck and need to be replaced. The code is on the rubber tag that came with the keys.
    Problem two. The spyder is unable to communicate with the transponder key. The DESS unit needs to be replaced.
    They are two unrelated and separate problems with two different solutions. Over time they have been mixed up and confused. The result is people like the OP get lousy and confusing advice.
    2018 F3 LIMITED
    Billy,
    When you explain something: it always sounds so much better, than when I try to explain something...
    Jul 2014
    Mint Hill, NC
    What pin are you speaking of? There is no pin on my '14 Brembo brake. The cable is connected to the brake tensioner arm by an oblong loop that is swaged to the cable. The tension on the loop must be released by loosening the tension nut before it can be lifted off the tensioner arm. At least that's the way my brake is.
    Cognac 2014 RT-S
