Results 26 to 50 of 63
  1. #26
    Vermont
    The list of affected keys...
    gain, this is just to help out. It seems some have received incorrect info. There are a lot of key tags on the list. If you lost or discarded of your key tag and your vin is on the list you still need to have it checked. Here is a list of the key tags that are affected. 1656 1750 1800 1900 2009 2163 2200
    1657 1751 1801 1901 2010 2164 2202
    1658 1752 1802 1902 2011 2165 2203
    1659 1754 1803 1903 2013 2166 2204
    1661 1755 1805 1905 2014 2167 2205
    1662 1756 1806 1906 2015 2169 2206
    1663 1758 1807 1907 2017 2170 2208
    1665 1759 1890 1908 2018 2171 2209
    1666 1760 1891 1909 2019 2173 2211
    1667 1761 1892 1910 2020 2174 2212
    1668 1762 1893 1912 2021 2175 2213
    1669 1764 1894 1913 2023 2176 2214
    1670 1765 1896 1914 2024 2177 2215
    1671 1766 1897 1915 2025 2178 2217
    1673 1768 1899 1917 2027 2180 2218
    1674 1769 1918 2028 2181 2220
    1676 1770 1920 2029 2182 2221
    1677 1771 1921 2030 2183 2222
    1772 1922 2031 2184 2223
    1773 1923 2032 2185 2224
    1774 1924 2033 2186 2226
    1775 1926 2034 2187 2227
    1777 1927 2036 2189 2229
    1778 1929 2037 2190 2230
    1780 1930 2039 2192 2231
    1781 1931 2040 2193 2232
    1782 1932 2041 2194 2233
    1783 1933 2042 2195 2235
    1784 1934 2043 2196 2236
    1785 1936 2044 2198 2237
    1787 2046 2199 2239
    1788 2047 2240
    1789 2048 2241
    1791 2050 2242
    1792 2051 2243
    1793 2052 2244
    1794 2053 2245
    1795 2054 2246
    1797 2056 2248
    1798 2057 2249
    2059 2251
    2060 2252
    2061
    2062
    2064
    2065
    2066
    It appears that 1760 is on the list.
    Bob, Where can I find a complete list of " Key Tags #'s? Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
  2. #27
    Vermont
    That's correct Bob.
    The 2014's have 2 different problems with the ignition and keys.
    Problem one. Ignition switches with a certain series of key codes will get stuck and need to be replaced. The code is on the rubber tag that came with the keys.
    Problem two. The spyder is unable to communicate with the transponder key. The DESS unit needs to be replaced.
    They are two unrelated and separate problems with two different solutions. Over time they have been mixed up and confused. The result is people like the OP get lousy and confusing advice.
    Billy, The D.E.S.S. unit is under warranty I had the D.E.S.S unit replaced on my 14RT-SE6 last week. Also, the dealer had to reprogram the both sets of keys. Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  3. #28
    HI Dee,
    Your dealer could bring it up for you. This list was posted back late in the Winter of 2014, when this issue popped up.
    Your keys came with a small "tag with them. It's probably on the keyring that holds your spare key and sheath.
    It'll have a four digit number on it. If it's on this list; you should have your dealer take action.
    (This is completely unrelated to your recent warranty work...)
  4. #29
    Default UNDERSTANDING WHAT YOU READ
    Mike,
    I'm pretty sure that the TSB was dealing with a mechanical issue with the switch. the "KEY" error (I think!) would seem to be more a case of the computer and the key not speaking quite the same language...
    One probably has very little, to do with the other.
    Apparently you read my Post #15.................and as usual you didn't understand it ...........but that fact is not UNUSUAL, because you have extreme difficulty understanding anything I post..... ..............Mike
  5. #30
    One problem is unrelated to the other; I just don't know why you'd ask about it?
  6. #31
    Vermont
    HI Dee,
    Hi Bob, The next time I visit my dealer I will ask. Is this a separate problem? Should I wait ? Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  7. #32
    If you've had no problems with your ignition switch appearing to "jam"; I would say that it's not a critical issue. It'd be more just for your peace of mind!
    If you can look up that number on the tag, and compare it to what I posted above; that'd give you a good idea of if your bike might be affected.
  8. #33
    1760 was on the second list.
    Jun 2011
    Columbus, Ohio
    The service desk is telling me the VIN/key tag combination is NOT on the service bulletin. Right now they are pulling the switch out. They believe something is physically preventing the key from being fully inserted.
    2014 Spyder RT LTD, 2010 RT-622
  10. #35
    Quote Originally Posted by Cyclist922 View Post
    See list on post #26. 1760 is there.
    Default OMG
    My post # 29 applies here also .......Mike
  12. #37
    My curiosity is killing me. How'd you get the parking brake released?
  13. #38
    Jun 2011
    Columbus, Ohio
    The tow driver used my crescent wrench to loosen and then release the cable at the rear wheel.
  14. #39
    Jun 2011
    Columbus, Ohio
    I know. They are telling me both the tag number and the VIN need to match.
  15. #40
    Active Member PaSpyderRyder's Avatar
    Jun 2013
    Carlisle, PA
    When the recall happened back in early 2014 my key tag match but the vin did not . I was having the same problem as you and my dealer got it replaced under the recall.
    Bob
  16. #41
    Very Active Member finless's Avatar
    May 2013
    Stanton, ca
    The back and forth he said she said arguing is not helping the OP!
    Just say'in....
    Bob
    2011 RT-S SM5 - Black
  17. #42
    Active Member ndspyderlover's Avatar
    Dec 2012
    fargo, north dakota
    I agree . There are two separate problems. 1. the dess code and the computer chip. this is the recall that fixed mine. 2. the fact that he key does not turn is a whole new issue and they are not related.
  18. #43
    Jul 2011
    Mitchell, Ontario, Canada
    I cannot find a copy of the TSB but if I remember correctly it has nothing to do with the VIN. It's key code only. Maybe someone could find a copy of the TSB and post it.
    I hope they get you on your way soon.
  19. #44
    Invalid Emails
    Jun 2008
    alabaster al
    Default KEY
    My 2014 RT did the same thing and was not on their list.Got it dealer he took the key and filed the bottom tip off on both sides of the key.Has worked perfect for over a year.That is what BRP had on their computer as one of the fixes.
  20. #45
    Tennessee
    I checked into a hotel last night here in Daphne Alabama. I'm riding my 2014 Spyder on a tour of both coast. This is day 13 of a 27 day ride.
    This morning my ignition is frozen. I can insert either of my keys but neither will turn. I tried WD40 with no luck. No sign of damage to the lock, and the cover was still in place this morning so I don't think it was tampered with.
    Here are my questions:
    1. Dealer recommendations in Mobile area?
    2. Is there a way to manually disengage the parking brake so I can get the bike on a tow truck?
    3. Any other quick remedies I could try?
    Rod
    This is why I now ride a Yamaha. No flames please - I'm not trying to be nasty - just telling it like it is.
  21. #46
    Active Member NorCalBud's Avatar
    Feb 2013
    Northern California
    Quote Originally Posted by dndfindley View Post
    Not attempting to flame ya, but I'm not sure I'm following you....
    Are you saying that you ride a Yamaha because they are trouble-free? Yours might be the first....
    ~'12 RT Limited, Pearl White~
    BajaRon Anti-sway Bar
    Squared Away Laser Alignment
    Custom Dynamics HMT Brake Light, Front Fender Tips & Kit, Front Mud Flap LEDs, Amber & Red Brightsides, Tri-color Magicflex Channelz
    Lidlox Grip Tip Helmet Locks
    TricLED Mirror Signals, RGB Multi-color Halo Underground Effects Kit, LED Headlights
    Palmer Signs Custom "Captain America" frunk graphics
    Twisted Chrome Pinstripes
    Overland Australian Sheepskin Seat Cover
  22. #47
    It seems a bit rude of you to rub salt in this guy's wounds.
    I guess that manners weren't high on your parent's list of priorities...
  23. #48
    Jun 2011
    Columbus, Ohio
    I'm back on the road. The tech from Hall's Motorsports worked through the afternoon to replace the switch. I'd like to thank them for making me a priority and thanks to all of you who contributed to this thread. I'm 1/3 of the way through my trip. Now it's on to California, up to Washington, and back to Ohio!
  24. #49
    Very Active Member bodymanpainter's Avatar
    Dec 2009
    Yulee, Florida
    Congrats, glad you are back on the road and hope you have a safe and enjoyable trip.
    Toby
    2020 RTL
  25. #50
    Yes, congrats on getting back on the road. Be safe!
