Page 2 of 3 FirstFirst 123 LastLast
Results 26 to 50 of 54
  1. #26
    Invalid Emails
    Jun 2013
    Fair Oaks, Ca.
    We have 2 dealers in our vicinity. Both dealers refused to mount a car tire on a Spyder until about a year ago. Now both dealerships will do it. Basically, they were watching many members of our Sac Chapter club pay a local motorcycle shop to mount them. Now not only do both dealerships perform the service ( 1 requires a waiver be signed), but one of the dealerships stocks and sells the Kumho. The dealerships in our neck of the woods have come a long way with their progressive thinking in the last couple of years...and I commend them for it!
  2. #27
    Invalid Emails
    Dec 2007
    Belmont, CA
    Default Installing dealer
    Spyder Tony, can you be more specific as to which dealers in your area install Kumho tires. My service dealer will not go near a non OEM TIRE.
  3. #28
    Registered Users 109spyder's Avatar
    Jul 2015
    Australia
    Question: What is a "stretched" tire?
  4. #29
    Active Member johnwinslow's Avatar
    Jul 2011
    Waterboro, Maine
    Quote Originally Posted by 109spyder View Post
    BOB ! google it
  5. #30
    Jul 2015
    Australia
    Quote Originally Posted by johnwinslow View Post
    BOB ! google it
    No need, I just did
  6. #31
    Very Active Member kep-up's Avatar
    Nov 2014
    Mountville, PA
    Well now, ain't thay just absolutely dumb?!
  7. #32
    Nov 2014
    Mountville, PA
    Quote Originally Posted by kbwitt View Post
    My dealer will not install the Kumo car tire. He said it heats up and rubs on fender. Sounds like a bad excuse to me. I told him that on a internet forum, many people have done it with great success. Plus he says it is an hour and half labor charge to do any rear tire. Is that true 1-1/2 hours labor.
    Thanks Kenn
    I replaced my rear tire two weeks ago. Never changed a spyder tire in my life. From start (setting up the machine on the garage floor) to finish, including balancing and a test ride (and a couple of beers in between) 2 hours.
  8. #33
    Jul 2015
    Australia
    Has anyone run an actual bike tyre on the back of a spyder?
  9. #34
    Very Active Member DR Buck's Avatar
    Apr 2012
    Fauquier County VA - Virginia's most carefully pronounced county.
    Did it myself. Took the tire off and took it to a small motorcycle shop and had them remove the old and mount the new tire. Cost me $25. Reinstalled it on the Spydrr myself. About 2 hours, only because I screwed up the belt tension and had to retension it.
    2012 RT Limited - Pearl White
    My Mods -
    http://www.spyderlovers.com/forums/showthread.php?39494-DR-Buck-s-2012-RT-Limited-Mods
    2012 RT Limited , Full size brake peddel White w/Red Highlights
  10. #35
    Jun 2014
    ny
    Quote Originally Posted by cuznjohn View Post
    when i bought my hand brake my dealer wouldn't even install that, but i installed it and it was easy. when i was upstate and stopped in at arctic adventures they said they will install whatever you wanted to install and they just have a waiver to sign saying they are not responsible for any problems, if all dealers did this i wouldn't have a problem signing it
    the problem with waivers is they may not hold up in court if they are doing something that knowingly may be dangerous or illegal.
    dangerous can be something manufacturer says is a no no. i know i am not allowed to disable the tpms light on the dash of a car.
  11. #36
    Yeah... The OEM Kenda!!!
    Seriously; what advantage would it have? The typical motorcycle designed with a rounded design to aid in cornering...
    ...You sure don't need that on the flat-cornering Spyders!
  12. #37
    Jul 2015
    Australia
    I know that and you know that, but there are some strange people out there lol
    They put car tyres on two wheelers
  13. #38
    Yes... The Dark Side!!
    This happens to a fair amount of GoldWings and Valkyries...
  14. #39
    Invalid Emails
    Jun 2014
    Green Lake, WI USA
    Default Which dealer
    Quote Originally Posted by Machinegunner View Post
    My dealer has Kumho in stock. Along with Kenda.
    in Wisconsin do carries the Kumho in stock? Thanks - I would like to have an option to go to a dealer here in WI that I can work with on tires, etc.
  15. #40
    Very Active Member AMTJIM's Avatar
    Jun 2008
    Vail, AZ
    The irony is that a Kenda seems like a downgrade that dealers would not be allowed to install, they are good for immediate shredding and use on a jogging track. Harbor Frieght trailer tires are probably better.
    In the twisties I was playing the tart...
    2009 GS SM5 , Red/Black
  16. #41
    Everybody keeps forgetting one VERY important fact...
    The Kenda and Vee tires are currently the only ones that come in the size that we need, AND is rated for use on a motorcycle.
    I'm not a fan of the Kenda; but only due to the short lifespan.
    It handled well, and never sent any nasty surprises at me!
  17. #42
    Vermont
    Quote Originally Posted by Marker View Post
    Your dealer will not install your rear tire because he does not want to assume any liability. Some dealers in our area will not install aftermarket tires, dealers say its a liability issue.
    In my area, ( in Vermont) a can-am dealer did install my new rear tire, on the "repair order invoice it says"*** THIS IS NOT THE CORRECT DESIGN OR SIZE FOR THIS UNIT, CUSTOMER ASSUMES ALL RESPONSIBILITY.*** I had to initial and " the customer states: Mount and balance rear tire, purchased elsewhere. Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
  18. #43
    Vermont
    Thanks Kenn
    I had my local can-am dealer install a new rear tire on spyder, and it took only 1 hour @ the rate of $79.00. Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  19. #44
    Very Active Member NautiBrit's Avatar
    Jun 2008
    Buckeye, AZ
    Kenn, our local dealer, RideNow Peoria has installed 2 car tires for me without a question. Just make sure you check the rims for scratches as he can be a little careless.
    George
    2017 BMW R1200R
  20. #45
    Vermont
    Quote Originally Posted by Lou View Post
    My Dealer installed with a disclaimer statement on the bill - Customer supplied tire, not recommended by BRP. Or something to that nature......
    A can am dealer that I used
    ( did install a new rear tire that I brought up with me, I called a week before to make an appointment)
    did a install and also had a disclaimer on bill that said** Tire is not the correct design or size for this unit, customer assumes all responsibility.** I had to put my initials. Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  21. #46
    Active Member TEHelms's Avatar
    Sep 2014
    Indian Trail, NC
    Default The never ending story....
    Since my OEM Kenda is almost at the end of life (12,000+), I'm now doing "the search". So, called my dealer and asked if he would install other than the Kenda and he said yes. He asked about my mileage on the tire and how much pressure I had been running (29). He also asked if the wear was pretty much in the middle and said he has been recommending 25-26 on the Kendas since more than that and they tend to wear out faster in the middle.
    He said he had mounted regular automobile tires on an RT before and just to make sure they weren't designed to go on one side of the car or the other. He asked if I was considering the Kumho and I told him I was. He said no reports back to him either good or bad. I asked about his price for the Kenda and he said in the $150 range and he knew I could get the Kumho for about $80. He also said he believed the composition of the Kendas had been changed to more adequately work on the RT as opposed to the softer compounds before.
    So, my decision is still in the air. I can buy two Kumhos for the price of one Kenda but I don't have stellar reports on either tire. I don't know if the price for the Kenda has to do with the specificity of the tire or not but it seems to me I'm still between the devil and the deep blue sea unless suddenly a reputable manufacturer starts to sell what fits my RT.
  22. #47
    The cost of the Kenda seems unusually high... and I also have wondered if it's due to them playing to a captive audience.
    It's your bike, and your money; none of us can really tell you what you should do...
    But I put a Kumho on mine!
  23. #48
    Registered Users Gray Ghost's Avatar
    Sep 2013
    Harper, Texas
    A tire that has been previously mounted on a rim. In other words, a used tire.
    Clifford Fargason
    2013 Spyder RTL
    2007 Royal Star Venture
  24. #49
    Thanks!
    I don't think that anybody mentioned putting a used tire on their bike...
  25. #50
    Sep 2013
    Harper, Texas
    Thanks!
    He responded with what his insurance would not allow him to do. And while it has not been mentioned here I have had people come into the shop and ask us to put used tires on a bike rim. We don't do it either.
    Clifford Fargason
    2013 Spyder RTL
