Results 1 to 16 of 16
    Jun 2011
    Near Lexington, NC
    Default How Difficult is it to Remove the Rear Axle?
    I have Non-OEM trailer hitch mounting plates which are held on
    by the axle nuts. I want to remove the plates. However, the axle "nut" on the left side is welded/part of the axle. The right side has a removable nut, after which the axle is pulled out.
    Doing this will cause the wheel to drop and I have no idea what
    problem this might cause or how difficult it would be to re-install the axle thru the wheel.
    Can anyone tell me what I might be up against if I tried doing this?
    I had the hitch plates done at the shop when a new tire was being put on last year, and I've never removed a rear wheel.
    Sorta doubt its something I want to tackle either, but a local guy wants to buy the hitch and I don't use it anymore. If I have to pay an hour's shop labor, it doesn't make selling it hardly worthwhile.
    Two Wheelers from 1963-2011
    Three Wheelers:
    2011 RT(Red)
    2014 RT(white)
    2016 F3T(red)
    2022 RT current ride(silver)
    __________________
    2016 Slingshot
    2018 Vanderhall
    2019 Slingshot
    I believe that as long as the belt "adjusters" are left alone; you'll be good to go!
    Cptjam and SpyderAnn1 had posted about how to do this... You might want to PM them for more info...
    Active Member ingramsail's Avatar
    Aug 2012
    Oklahoma City, Okla.
    The bolt runs through the center of the axle, just the remove the nut on the right side and slide the bolt out the left side.
    Jun 2011
    Near Lexington, NC
    Quote Originally Posted by ingramsail View Post
    Won't the wheel drop down or something? No parts, washers, etc, to drop off?
    Three Wheelers:
    2011 RT(Red)
    2014 RT(white)
    2016 F3T(red)
    __________________
    2016 Slingshot
    2018 Vanderhall
    2019 Slingshot
    Aug 2012
    When you pull the hitch off you'll see two more larger nuts. Just watch he wires on the right.
    Sent from my VS985 4G using Tapatalk
    Default REMOVAL
    Quote Originally Posted by ulflyer View Post
    There video's on this ......The key is to remove the BOLT that holds the rear shock......People say you can't jack here but you can .....IF YOU PUT A PIECE OF STURDY WOOD across the bracket tabs that hold the bolt/shock assembly to carry the weight......DO NOT JACK THE BOTTOM OF THE SHOCK --- EVER ....By taking out this bolt you are relieving the pressure from the belt , which you can now slip off the sprocket ......DON'T TOUCH THE ADJUSTERS.....just put the wheel back on.....On the RT some have to remove the ARM from the AIR compressor from the swing arm.......FIND the video......Mike
    Aug 2012
    You will not need to pull the axle, the brackets should come off when you pull the bolt. It just pass through the cetera of the axle, also no need to rise the wheel.
    Jun 2011
    Near Lexington, NC
    Wow, now thats something I understand and should be able to do. Would it be useful to put a jack under and take just a little weight off the wheel? Or, is not just not necessary?
    Three Wheelers:
    2011 RT(Red)
    2014 RT(white)
    2016 F3T(red)
    __________________
    2016 Slingshot
    2018 Vanderhall
    2019 Slingshot
    Aug 2012
    When you pull the caps off the rear bolts is there a hole in the center of the axle? If so you will have to pull the axle. You will need to follow blueknights posts.
    Jul 2011
    Mitchell, Ontario, Canada
    Look at the picture again. He does not have a bolt that runs through the axle. As the OP clearly stated in his first post he has a aftermarket hitch that is held on by the axle.
    PS Did not see your last post.
    2018 F3 LIMITED
    Very Active Member Magdave's Avatar
    Jun 2013
    NE South Carolina
    The OEM is much easier to remove. The axel nuts must come off no center bolt. Mike may be right taking the shock bolt ( and air shock feedback arm if so equipped) off and lifting it will take the tension off the belt and make it easier. I would have the shop re adjust the tension afterwards just in case.
    2013 Mag Silver SE5 RT BahaRon Sway bar & Sway bar links, Grip Puppies, Kuryakyn Helmet locks , Ultimate Seat w/Utopia Backrest, Dash power outlet, Spyderpops BumpSkid, Swagman Cup holders, Full size Brake Pedal, Seal DLX Floorboards, Freeway Blaster horns, Sylvania Super Bright fender LEDs, Scotchlite 680 Rear & Fender Reflectors, BRP Fog Light Kit, LED Mirror turn signal strips, 2014 RT grille mod. Outlaw Laser Alignment
    Default Let's see..!!
    if you remove the rear shock lower bolt and support the wheel you will ease the tension on the belt making the removal of the axel easier. You should be able to reassemble without messing the adjustment and alignment...if you do have a laser alignment you might have it checked afterwards...
    ​2012 RS sm5
    Jun 2011
    Near Lexington, NC
    Had the shop take it off today for $50. At my age, thats a
    good deal. Got the belt adjusted and aligned in the process.
    Thanks all, for the help.
    Three Wheelers:
    2011 RT(Red)
    2014 RT(white)
    2016 F3T(red)
    __________________
    2016 Slingshot
    2018 Vanderhall
    2019 Slingshot
    Active Member james danny's Avatar
    May 2012
    stockbridge georgia
    Default Remover of rear axel bolt
    I need to remove rear axle bolt for aftermarket hitch also .if I support tire and jack up body will tire stay in place. I have found no video.
    Take it to ulflyer's dealer... For $50; he'll set you up with what you need!
    Jun 2011
    Near Lexington, NC
    Quote Originally Posted by james danny View Post
    James, no it won't. The belt tension will pull on the wheel and get it out of alignment.
    The only way is to do what Blueknight describes above. That procedure was too much for my old bones so it took it to my dealer.
    I noticed he put a jack under the rear shock and took the weight off the wheel slightly, and the rear bolt appeared to come out fairly easy; however, putting it back took some jiggling and tapping with plastic mallet. After securing the bolt on the right side, he jacked the wheel up enough so that it would easily roll by hand while he realigned the belt. That took several tries, tightening/untightening the bolt and readjusting before he was satisfied.
    In short, unless you can do what Blueknight says, take it to your dealer.
    Three Wheelers:
    2011 RT(Red)
    2014 RT(white)
    2016 F3T(red)
    __________________
    2016 Slingshot
    2018 Vanderhall
    2019 Slingshot
