Page 1 of 2 12 LastLast
Results 1 to 25 of 31
    Active Member purplepig's Avatar
    Sep 2011
    webster,ny
    Default How to slide rear end over in garage?
    Tried a few different searches and couldn't find any info on this one. I need to slide the rear end of my RT over after I park it in the garage.When pulling in I end up leaving almost 20" of wasted space between left saddlebag and wall. Much needed space I might add to walk thru. I can see a lazy susan type gizmo that slides side to side instead of around and around, but have no idea what to use. I can even see a pin into the cement floor to hold the "plate?" in place till it is parked...a quick push and viola it is bumping up against the padding I put on wall. Where are the engineers when I need one??!! Thanks all!
    Member Stranger1759's Avatar
    Apr 2015
    Tonganoxie, Kansas
    Default Hydraulic Wheel Dolly.
    How about one of these?
    2014 RT S Cognac
    Spyderpops skidplate and belt guard. Squared Away Alignment. Bajaron Sway Bar. Show Chrome Smart Mount Large Backrest. BRP Adjustable Air Deflectors. Hopnel net and saddle bag liners. Lamonster NBV Highway Bracket - Trident Large Foot Peg. Rivco Cup Holder Mount & Kruzer Kaddy Kustom Kaddy Drink Holder - Leather. Tricled saddlebag, fender side & rear, 3rd & 4th brake light, and mirror turn signal LED's.
    Very Active Member Bam Bam and Pebbles's Avatar
    Nov 2014
    Rural Hall NC
    Cool
    Back it in and put the rear wheel exactly where you want it.
    Current Ride
    2015 RT-S SM6 Cocaine
    Pearl White
    Diamond R Web Armrests
    Shorty Windshield
    Previous Ride
    2012 RT SM5 The Beast
    Pure Magnesium Metallic
    Default THIS WORKS
    Two pieces of galvanized sheet metal about 1 ft X 2 ft .....place them on top of each other....put a stick where you want the rear tire to stop......you should be able to slide the Spyder over because the metal sheets are slippery........Mike
    Default Try this..!!
    the blue one under the shock mount up an inch or two over and down...the yellow one to move the whole thing around...
    ​2012 RS sm5
    Very Active Member Orange Spyder Man's Avatar
    Sep 2014
    3rd ROCK FROM THE SUN !
    buy this jack from Amazon... jack it up and put your Spyder where ever you want...
    Very Active Member Dan McNally's Avatar
    Jun 2013
    Lots of choices, but a jack and a set of wheel dollies would let you put it anywhere. http://www.amazon.com/s?ie=UTF8&page...0wheel%20dolly
    "Topper" is my Pearl White 2013 RT-LTD
    Professional Retiree - liked it so much when I retired from the USAF, that I started another career so I could do it again!
    Happy to be a member of the Maryland Spyder Web - find us at
    http://www.meetup.com/MarylandSpyderWeb/
    Active Member Richardv's Avatar
    Oct 2014
    Montreal north shore, QC
    Default Easily moving heavy stuff...
    Quote Originally Posted by purplepig View Post
    Just use 2 pieces of a 'crazy carpet' (that is the sheet of nylon they sell to slide on snow) . Place one on top of the other, and just push the rear towards the wall. If you want it even easier, spray a bit of silicone between the 2 pieces, but be careful. It will be very slippery... voila!!! 😉
    Jul 2014
    St. Charles Mo.
    I use a strap through the tire and pull it where I want it.
    Very Active Member Vader's Avatar
    Jul 2014
    Hudson Valley
    Default What I use
    Alot less, but you will need a jack or a strong buddy.
    http://m.harborfreight.com/18-in-x-1...lly-61899.html
    IT IS, WHAT IT IS...
    Sep 2011
    webster,ny
    Default great ideas
    Keep them coming folks. Some great ideas here. I will add that it would be nice if it was quick and easy as it will have to me moved over/in every time I ryde. Backing in will only be worse as front end is wider. Crazy Carpet idea is in the works. Just ordered 2 on line! But would welcome any more choices! Thanks again, Dan
    Central Oklahoma
    Default when I have to do this to my wife's RT-S
    I just grab the trailer hitch, pull up a bit to ease the traction then pull it over where I need it to go.
    I think the crazy carpet idea sounds easy and great.
    2020 RT Limited , Petrol Metallic Dark
    Active Member sledmaster's Avatar
    Sep 2007
    Minnesota
    Personally I just lift up on the grab handle at the rear (RS/ST/F3 but not RT) to reduce the pressure and simply slide the rear end over, but I am a big guy so it is fairly easy to do. Anything that reduces the friction and pressure between the rubber tire and the floor surface will make the chore easier. Like a furniture slider under the tire. You should be able to back right onto it and slide the unit with relative ease if I can do it without one. If that isn't enough of a friction reduction then wet the floor in the direction you need to move the slider. Or, try a furniture slider on top of something like a slippery chunk of plastic. We use a rolled-up kid's toboggan to move sleds. It's just sheet plastic. This is how we move dead snowmobiles, put the kid's toboggan under the rubber track and it slides with ease. It shouldn't be very difficult to find some easy method of friction reduction. No need to get fancy and expensive!
    2021 RT Limited - Deep Marsala Red – 4,200 miles
    2013 ST-S SE-5 - Circuit Yellow – 56,000 miles
    2015 F3-S SM-6
    - Can-Am Red Solid Gloss – 2,000 miles - SOLD
    2008 GS SM-5 Premier Edition #659
    - Full Moon – 34,000 miles - SOLD
    2008 GS SM-5 Premier Edition #006
    - Full Moon – 34,800 miles - SOLD
    Default There's always This Option
    SoFlo
    Never seen or used those crazy sheets. I was going to suggest either a lawn garbage bag or some sheets of heavy plastic visqueen.
    I use the visqueen on a smooth concrete floor when I align the front end of my Tacoma. Few layers is real slippery.
    PK
    Jun 2013
    queens ny
    my shed is so small i have a hard time moving my own rear end over
    NO BIKE AT THIS TIME
    Very Active Member granpa in Cincy's Avatar
    Oct 2010
    Cincinnati Ohio
    some goldwingers used to use a piece of carpet.
    2014 RT S SE6 Cognac. Built on 12/20/13.
    2014 VW EOS 2.0 TSI replaced the RT S 5/22/2017
    Active Member tnhoover's Avatar
    Jul 2010
    York Pa
    Saw a guy at an event last year loading 2 Spyders in a trailer. Pulled the first one in with the back wheel on a furniture slider (you can get them at Lowes for a few bucks) and then slide it over pretty effortlessly.
    Sep 2011
    webster,ny
    Cool Thanks!
    All your advice is much appreciated!
    Rockin Member Macca's Avatar
    Sep 2011
    Lake Zurich, IL
    I have a bike slyder to move the spyder around in my garage.
    I don't believe these are available anymore.
    https://youtu.be/FtUBsf39CaQ
    Sent from my SAMSUNG-SGH-I467 using Tapatalk
    2011 Pearl White RT Limited
    HMT Brake Light, Fender Tips Kit, Mudflap Lights, GloRyders, Seal Floorboards, Powerlet 12V, Garage Door Momentary Button, Bump Skid, Elka's Stage 1, Ultimate Sea, Air Wings
    Member of the Woodstock Spyder Ryders (Illinois)
    Very Active Member pitzerwm's Avatar
    Nov 2014
    TriCities, WA
    Here is a perfect case where necessity was the mother of invention. Sad if he is "gone"
    One of the hardest decisions you'll ever face in life is choosing whether to walk away or try harder.
    Registered Users Bumblebee67's Avatar
    Jul 2011
    Heflin,Alabama
    I found this on eBay. It's a Can-Am Spyder dolly.
    http://www.ebay.com/itm/301675223875...%3AMEBIDX%3AIT
    Sep 2011
    webster,ny
    Default Wow did this work!
    Quote Originally Posted by Richardv View Post
    Thank you so much for this idea. It works perfectly! My wife thanks you as now she can get of her car in the garage! Dan
    Invalid Emails
    Jun 2008
    Augusta, GA
    That would definitely work Just don't forget that it's under the back wheel when you back out. I could see that sheet stuck in the wall, or in one of the front tires if you got a little heavy handed with the clutch and throttle. Just saying.........
    Nov 2008
    Edmonton / Alberta
    cheap and easy, a peice of round wood doweling cut to your size dimensions, drive /back up on it and a kid could push it sideways, even 2 or 3 peices are better, WORK SMARTER NOT HARDER. Rember to place lengthwise with the tire or you will be moving front and back.
