Results 1 to 14 of 14
    Active Member KJWEB's Avatar
    Jun 2015
    Midland, TX
    Default Pitbull Motorcycle Jack
    Anyone using a Pitbull motorcycle Jack to lift your RT? I have the air over hydraulic standard lift. According to Pitbull, I need the Dyna lift because the standard size jack will make contact with the exhaust.
    Any pictures of the lift under the trike is appreciated.
    www.sasspyders.com
    2016 F3T
    2015 Freedom Trailer
    Sypderpops BumpSkid Plate
    Lamonster ISP Key Cover
    Lamonster F3 Bar Clamp and Power Port
    Lamonster RIP floorboards and frame caps
    Lamonster Chevron Highway Pegs
    BajaRon Swaybar & Heim Links
    F4 Custom 21" tinted windshield
    BRP Cannonball Seat
    BRP F3 Idler Pully
    FOBO TPMS
    LidLox (dual)
    Garmin 660LM GPS
    Cat Delete Performance Pipe
    F3T Top Case
    PPA Black Widow Wheels
    Custom Frunk Wrap
    Default Here you go..!!
    though this is an RS same lift is used on RT's...
    ​2012 RS sm5
    Very Active Member bmwlarry's Avatar
    Mar 2012
    Beaverton, Oregon
    I have a full size Handy lift but also often use a J&S Jack.
    2015 an Am Spyder RT Limited
    2013 Yamaha WR250R - Sold
    2011 Can Am Spyder RT-S SE5 Limited - Sold
    2011 Aspen Sentry Trailer
    2003 BMW K1200LT - Sold
    2007 Unigo Trailer - Sold
    2001 BMW K1200LT - Sold
    2001 Honda 750 NightHawk - sold
    2015 RT Ltd , Canamspyderaccessories Brake pedal ext. Red
    Apr 2014
    Indiana
    Default Pittbull Jack
    I use a Pitbull jack to lift my 2014 RT with no problem. I did put a piece of 1/2" board (4" Sq +/-) on the on lift bar side toward the rear wheel on the frame and the front went across the main frame and the bars that run to the outside from the main frame. I did not take a picture but with me that is part of the course.
    Very Active Member Orange Spyder Man's Avatar
    Sep 2014
    3rd ROCK FROM THE SUN !
    I have this 1700lb motorcycle jack from Amazon.. it works perfect for my 2014 RT spyder.
    May 2013
    Stanton, ca
    Using the Harbor Freight ATV jack. Been using it since day one. Works fine on my RT.
    http://www.harborfreight.com/1500-lb...ift-60536.html
    Bob
    2011 RT-S SM5 - Black
    Jun 2015
    Midland, TX
    My Pitbull air over hydraulic jack works fine with the Spyder.
    www.sasspyders.com
    2016 F3T
    BRP Cannonball Seat
    BRP F3 Idler Pully
    FOBO TPMS
    LidLox (dual)
    Garmin 660LM GPS
    F3T Top Case
    Custom Frunk Wrap
    Sep 2014
    USA
    just dont take off one of the front wheels the bike will tip other than that those jacks work great??
    RT-S PE#0031 MarkLawson's Avatar
    Jun 2009
    Snellville, GA USA
    The Pitbull lift has tie down points to secure your bike or Spyder. If used, it shouldn't be a problem.
    I have the foot pump style Pitbull, which I bought many years ago. Love it. I now also have a table lift (air), which does a great job too. Had to add 9" width to the 48" standard width to accommodate the wider front wheels of the Spyder. now I have to back the Spyders onto it, but I can do that! It was originally designed for standard trikes.
    Mark & Mary Lou Lawson
    Snellville, GA USA
    '10 RT-S PE #0031
    '10 RT-622 Trailer
    '08 Yellow SM5 #2332
    '01 Black GL1800A Goldwing #0930
    "Remember in the darkness what you have learned in the light." - Joe Bayly
    Registered Users ursamajor35126's Avatar
    USA, Alabama, Leeds
    Quote Originally Posted by KJWEB View Post
    Model #, cost please
    TIA
    2014 RT Ltd Black Currant, Bump Skid, TricLed 3rd, 4th and 5th Brake Light with Modulator, TricLed Safety Bundle Led's and Reflectors with flasher option, TricLed Vader lights, JT's dash mount and USB outlet. Baker Wings belt tensioner and Drivers cup holder. Lamonster's FFP highway pegs and IPS, BRP Trailer hitch with Bushtec pin and 2007 Bushtec Roadster GT trailer. Volt Meter. Baja Ron Sway Bar. Doc Humphry's spring spacers
    Mike
    Nov 2013
    Oro Valley Arizona
    ​Those same Jacks are yellow at Sears and blue at Harbor freight. Pit Bull does not manufacture them. They do use them. Just to clarify for the Newbies.
    Jack
    Even old "square Joe" uses one.
    2015 BMW R1200R LC
    2014 RTL SE6 Pearl White
    2012 RT-622 trailer viper red
    2011 Polaris Ranger green
    2016 Can Am Maverick
    USA, Alabama, Leeds
    Thanks Joe.
    Mike
    Active Member Dragonfly's Avatar
    Apr 2013
    Atkins, Arkansas
    Regardless of what you use o jack up the Spyder, USE floor stands before working on your Spyder.
    Jul 2015
    Danville, KY
    Quote Originally Posted by ursamajor35126 View Post
    TIA
    http://stores.pitbullbikershop.com/
