Page 3 of 6 FirstFirst 123456 LastLast
Results 51 to 75 of 134
  1. #51
    Active Member Upstater's Avatar
    May 2015
    Upstate NY
    Default Does not apply
    Quote Originally Posted by finless View Post
    Thanks, Bob. But, this bulletin does not apply to older models and is causing more confusion. This bulletin is ONLY for 2013. The 2013 kit includes modifications to the fuel system and will cause more harm than good in 2010-2013 models.
    We are just looking for the Air Scoops here. The increased air circulation around the engine helps cool the seat area better.
    2012 Spyder RT SE5 Limited - Lava Bronze
    - Baja Ron Sway Bar - SmoothSpyder Belt Tensioner - Air Modification Kit - Motorcycle Dave's gel seat inserts
    - Rivco Floorboards - Show Chrome Trunk Rack - Bad Boy Wolo Air Horn
    - FZ-1 Fuzeblock - Hopnel Lid Nets - Monster Graphics
  2. #52
    May 2015
    Upstate NY
    Default Oops
    Quote Originally Posted by Upstater View Post
    Ooops, meant to say,"...will cause more harm than good in 2010-2012 models." My bad!
  3. #53
    Thinks out loud Jeriatric's Avatar
    Apr 2012
    "The Skillet" AKA..... La Quinta, Ca
    Arrow BRPcares
    If they did?
    They would take the guess work out of this and announce whether pre '13 owners will be provided the air flow upgrade.... or not.
    How difficult could that be?
    I mean.... Really!
  4. #54
    Very Active Member Oldmanzues's Avatar
    Mar 2009
    Beavercreek, Ohio
    I had serious heat problems with my 2010RT. At dealers now waiting for answers. Case opened
    Oldmanzues
    Very Happy Spyder Owner
  5. #55
    Jun 2011
    Manhattan, IL
    Default Publication #
    There is an publication concerning this topic. It is TST #112333. Technical Service Tips (TST). It must be searched for without the hyphen. Can-Am will cover parts and labor on units in the regular warranty period (the first two years). All other units must request a goodwill warranty coverage.
    2015 RT SE6 Limited
    Custom Dynamics Trunk LED Brake Light with flasher
    Corbin armrests
    BajaRon- shock adjusters
    Previous 2011 RT SE6
  6. #56
    Aug 2013
    Northern California
    Default Covered
    Quote Originally Posted by jascreek View Post
    We have had no fewer than 5 members of our SRA chapter that have had the scoops added to their 2011 and 2012 RTs with dramatic improvements in heat. This was done at no cost to the owners and picked up by BRP.
  7. #57
    GOS member (Girls On Spyders) pslawing's Avatar
    Jun 2012
    Kings Mountain, NC
    Lots of great information here! I love spyderlovers! Gonna take this info with me and talk to my dealer!
  8. #58
    Very Active Member Bam Bam and Pebbles's Avatar
    Nov 2014
    Rural Hall NC
    Until BRP and the dealers get their stories straight, I did a little work myself on my 2012 RT that has helped a little bit. I removed the acoustic panels along with the 2 small air deflectors underneath the mirrors. Removing the deflectors allows some of the airflow to go into the vents that the deflectors were blocking. Not a lot, but some. This isn't a replacement for having scoops force air into the vents, but until BRP decides what they are going to do for pre-2013 RT's, every little bit helps. I'm one of the shorts and flip-flop crowd, (yeah, I know, but I want to feel the air and the sun) and this has helped some. Now to get the 2014 right side grill and bottom block off plate unless I fashion something up myself. If I do it myself, I plan on using double sided Velcro twin stick so I can remove the block off plates in the winter.
    Current Ride
    2015 RT-S SM6 Cocaine
    Pearl White
    Diamond R Web Armrests
    Shorty Windshield
    Previous Ride
    2012 RT SM5 The Beast
    Pure Magnesium Metallic
  9. #59
    Jun 2014
    Lowrys SC
    I removed my acoustic panels also this past weekend. Helped a good bit with the heat coming up from the seat. Also removed the air deflectors. Next on the list will be to wrap the exhaust. At least the left side pipe. Wow that thing gets HOT!
    Dealer just doesn't want to help me with the scoops. Said they will not fit a 2010.
    2010 RT Audio and Convience SE5, wider vented windshield, XM radio, digital voltmeter, K&N filter, LED turn signal strips, ISCI floorboards, Lamonster LED Headlights and Fogs, Two Bros Black series
  10. #60
    Aug 2013
    Northern California
    Default Wow
    Quote Originally Posted by jroberts650 View Post
    Time to find a new dealer. The dealers in California are doing these as long as your bike is under warranty. You may want to reach out to BRP directly! Oh and they will fit! The body panels are them same on the 2010 as they are on the 2013.
  11. #61
    Jun 2014
    Lowrys SC
    I know they fit, you know they fit, we all know they fit. But I am continuously told this from the 4 dealers that are with in 120 miles of me. And as far as finding another dealer, thats out. Unless I go 2 states away. And BRP is just as bad. They don't want to deal with individuals, it's always "Take it to the dealer, they may be able to figure out a solution". "But you have to pay for the diagnosis charge"
    I'm just going to find my own ways to fix my heat problems.
    Quote Originally Posted by Pirate looks at -- View Post
  12. #62
    They'll fit; no problem!
    BRP doesn't want to deal directly with consumers, because they have a dealership network for that!
  13. #63
    Jun 2012
    Kings Mountain, NC
    What are the acoustic panels?
  14. #64
    May 2015
    Upstate NY
    Default Will ship...
    I can order the kit and ship it to you. My dealer is just waiting to get it in and install on my RT first, to make sure it's correct. Hang tight, help is on the way!
  15. #65
    Very Active Member Magdave's Avatar
    Jun 2013
    NE South Carolina
    2013 Mag Silver SE5 RT BahaRon Sway bar & Sway bar links, Grip Puppies, Kuryakyn Helmet locks , Ultimate Seat w/Utopia Backrest, Dash power outlet, Spyderpops BumpSkid, Swagman Cup holders, Full size Brake Pedal, Seal DLX Floorboards, Freeway Blaster horns, Sylvania Super Bright fender LEDs, Scotchlite 680 Rear & Fender Reflectors, BRP Fog Light Kit, LED Mirror turn signal strips, 2014 RT grille mod. Outlaw Laser Alignment
  16. #66
    May 2015
    Upstate NY
    Default Install scheduled!
    Just got the call. The kit has arrived and I'm scheduled for this Friday.
  17. #67
    Aug 2013
    Northern California
    Default Excellent
    From what I have heard from other 2012 owners is this will really be awesome!
  18. #68
    Nov 2014
    Rural Hall NC
    Quote Originally Posted by pslawing View Post
    They are two large black panels underneath the side panels. They have some insulation on them to block sound, but they also allow some of the heat around the engine to build up and be contained. I removed mine and I can't tell any difference in noise level. Taking them off allows a little more air flow. Not a lot, but some. It has helped a little. Mind you, I am not complaining about the heat the Beast gives off, especially with my summer clothing choices, but my wife does complain about the hot air riding up on her right foot and leg. Just ordered the 2014 right side grill from BRP. We will see if that helps some when it arrives.
    Current Ride
    Pearl White
    Shorty Windshield
    Previous Ride
  19. #69
    May 2013
    Stanton, ca
    In part 1 of my tri-axis handlebar install video I show the acoustic panels and how to remove them.
    Bob
    2011 RT-S SM5 - Black
  20. #70
    Mar 2009
    Beavercreek, Ohio
    My dealer is in "Discussion" with BRP about the heat problem on my 2010 RT.
    Oldmanzues
  21. #71
    May 2009
    Connecticut
    The Kit is available at ALL dealers.
    I just ordered mine today after taking off the Acoustic Panels Yesterday.
    Its $67 for the kit and Since my dealer is 8 miles away I will bring in the 2 Panels and they will put the scoops on for probably 1/2 hour labor since they do not have to deal with the Spyder itself- Only the panels?
    If you have Not taken off both under panels on your 2010-2012 RT you should do ASAP as they are easy to take off with 2-3 10mm small bolts.
    With the Acoustic Panels Gone (Which Surround the Cylinder Heads) and the Bottom panels off And the Vents the air will flow in the vents then through the cylinder/Motor area and exit out the bottom and you should be a Happy Camper?
    Sea Doo GTI-SE 90 Jet Ski!!
  22. #72
    Nov 2014
    Rural Hall NC
    Quote Originally Posted by Sarge707 View Post
    Do you have a part number for the kit. $67 is a pretty good price for the scoops!
    Current Ride
    Pearl White
    Shorty Windshield
    Previous Ride
  23. #73
    Jun 2014
    Lowrys SC
    Yes, if you have part numbers, please provide them. My dealer still tells me they are unavailable to purchase right now.
  24. #74
    May 2009
    Connecticut
    I just printed Pages 18-22 of the recall notice posted earlier in the thread called "Adding Air Intake Scoops to the side panels." I showed it personally to my dealer and he ordered it right away and will be here Friday!
    Read the entire recall link posted earlier and you will see it.
    Its Not a question of if your dealer can order it - Its a question of whether they want to bother enough to help you after the sale?
    Mention TST#112333 and Kit # 219800388 as posted earlier in this thread.
  25. #75
    Very Active Member SpydermanCT's Avatar
    Nov 2010
    Connecticut
    I have a 2010 RTS with about 25K on it. I do have a Best warranty that expires November of this year.
    After reading this post early this morning I contacted my dealer by email. He responded at 9:30am via email stating he ordered parts for me and they could be installed next Wednesday at no cost to me. The invoice he emailed me said :
    Install Air Scoop Retrofit Kit on 2010-2012 RT Models as per TST61Y010S09
    Part Number 219800388 Air Scoop Kit
    Claim Type Goodwill
    Like Sarge said, I guess there are some dealerships willing to take care of there customers, and there are some that are not.
    BTW ~ it's good to hear from you Sarge !!
    SpydermanCT
    2010 RT-S SE5 Timeless Black PE # 794 ~ RT-622 Trailer ~ Can-Am Garmin 665 GPS ~ Elka Front Shocks ~ ESI Brightsides with Rips Kit ~ ESI RT Fender Tips Kit ~ Rear Brightsides ~ HMT Brake Light ~ Tricplate rear running / Brake LED's ~ ESI Mud Flap Lights ~ LED Day Runners ~ Right Side Inlet Covers ~ Street Magic Scuff Guards ~ IPS Key Cover ~ KewlMetal Kewlocks ~ Spyderpops Radiator Block Off Plate and Catalytic Converter Shield Set ~ Carbon Fiber Kit ~ Corbin Seat
