Flash pass garage opener
Anyone install a flash to pass garage door opener and have some tips? Looking to install on my 2015 RT SEA SS. I believe I need to locate the high beam wire for trigger.
Thanks for any assistance and love this forum!
Sent from my SM-P905V using Tapatalk
2015 SE6 SS
Elka Stage 2 front and rear shocks
Lamonster Web Pegs
General Altimax RT43 Rear Tire
Lamonster LED Headlights and Fog lights
Baker Wings
Bajarons Sway Bar & Links
Custom Dynamics Fender, Bright Sides and HMT Brake Lt
Zumo 590
CB
Spyder Mudflap
Lamonster drink holder
Foam Grips
Billet Axle Covers
Stebel Air Horn
SpyderPops Bumpskid
SpyderPops belt guard
SpyderPops Kotte Grills
TriCLED LED Driving lights
Magic Mirrors
garage opener
[QUOTE9;995419]Anyone install a flash to pass garage door opener and have some tips? Looking to install on my 2015 RT SEA SS. I believe I need to locate the high beam wire for trigger.
Sent from my SM-P905V using Tapatalk[/QUOTE]
I used industrial strength velcro and installed my regular opener under the pull out safety card.
I had mine installed at the dealer but they wired it to the 'passing' light. Toggle down from the low beam. It's a great addition to my spyder, we have it on all the bikes and works great. Penny
You don't need to wire it to the headlights. It is a whole lot easier to locate a 12vdc source then to a momentary weatherproof pushbutton switch. The other side of the switch goes to one of the flash to pass black wires and the other black on the flash to pass goes to ground.
By doing it this way you are saving wear and tear on the shutter system in the headlight.
Thanks for the suggestions!!
Great idea! Thanks!
Do you have one in hand? It looks like they are no longer available, not on home site nor three retailers I checked.
2014 Copper RTS
I have these on all my bikes, they work great with better range than the remote that came with the opener.
http://www.mo-door.com/
Try this. http://www.f2ptechnologies.com/products/
The buy button on the product page takes you to a 404 error page. Shopatron home and clients page doesn't show f2p either.
2014 Copper RTS
Already had.
I removed it from the wing before getting the Spyder.
I tied mine into the fog lights
I tied my opener (AutoSwitch garage door remote Activator AS-7G) in my fog lights. One toggle on/off and the door opens. Once in awhile it gets temperamental and I have to do the switch on/off a couple of times. Works well for me and eliminates the headlight shutter issue.
On my 2012, I just used an old remote wired to a momentary contact button - that works well and is less costly....lots of good options out there. Good luck!
Happy and safe rydin'
2014 Spyder RT Limited - January 2014, Cognac/Black Seat, #958, born on 1-8-14
I just got a small remote and velcroed on the side of the glove box on the inside. works great and takes almost no room.
Bill C.
