Results 1 to 12 of 12
    Invalid Emails
    Feb 2015
    Wichita, KS
    Default Do I Need a Special Tool?
    I noticed the side panels on my 2014 RTL were loose. I took out my tool pouch to find the right Torx bit to tighten them. Lo and behold, I discover the screws have a "nipple" down in there preventing the Torx bit from entering. Whassup with that? I stopped by my local dealership and asked one of the guys about it. He told me there was no special bit (with a hole in the end to go over the nipple). That just a regular Torx bit would work. Well, I can't get it. Was he mis-informed? Am I just not doing it right? Is there REALLY a special Torx bit with a hole in the end? Inquiring minds would like to know. Thanks.
    Aug 2007
    Greeneville, TN
    They are called 'Safety' Bits.
    Bryant, Arkansas
    DO NOT TAKE THESE OUT
    These are pop outs do not unscrew them.
    they have hooks on the other side that are designed to pop out, not unscrew.
    Cruzr joe
    Invalid Emails
    Feb 2015
    Wichita, KS
    OK, so why wouldn't my tool kit have one of those bits? Why would my dealership (admittedly, I talked to a salesperson and not a mechanic) basically say I didn't need that? Where can I find those special bits? Thanks.
    Invalid Emails
    Feb 2015
    Wichita, KS
    OK, so I shouldn't take them out. What about the loose panels? Do I still need one of those special "safety" bits to tighten them up or just let them flop?
    Jul 2011
    Mitchell, Ontario, Canada
    Quote Originally Posted by etaoin View Post
    Grab the panel and pull it off. Then you will see why getting the tool would be useless. Also you will see why it is loose.
    2018 F3 LIMITED
    Bryant, Arkansas
    you will have to unscrew the other screws that hold this panel, but the two with the nipple do not screw out, they pop out.
    Cruzr Joe
    Aug 2007
    Greeneville, TN
    Usually you will find these in places were it is not in your best interest to remove them (as mentioned). That is why they are made this way because few people have the correct tool. It keeps you from messing something up.
    Jun 2010
    Las Vegas
    If your panel is loose it is most likely because the rubber grommet has been pushed through. The posts point in two directions and you have to bend the plastic to get the second post in.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    ...And don't worry; you're not the first person to notice that you don't have this tool available...
    ...And you won't be the last!
    May 2015
    Barryville NY
    Default Name of tool
    These are called tamper proof torx bits and are made that way so the common person does not try to take them out. They are used a lot in electronics. The bits can be bought at most places that sell tools.
    [QUOTE=beast68;995598]The bits can be bought at most places that sell tools.[/QUOT
    ...But don't...
