Well I tried the extension bracket trick with my Blue Ridge Windshield. The windshield certainly works better than it did, but it's still not great. I'm 6'2". With the bracket extension trick, the wind still hits me in the head, so I've ordered a Madstad windshield and found out it shipped today. In talking with the Madstad people when I ordered the windshield I was told the 20" windshield should be perfect. When it comes in, I'll write a review on mounting.
I am also 6'2" and the 20" Madstad works perfectly for me.
I'm curious could you share some photo's of your shield.
My friend and I are both 6'2 and he had a Madstad and sent it back. I tried it and didn't like it either. I'd rather ride without a shield which I do insthe ead of the Madstad. Since your the same height as us I was just wondering. We spent days and hours trying but nothing work for either of us. Thanks for any input!
I've been riding for over a month with my new Madstad and guarantee you will love it. I'm 6'1" and went with the 18". At it's lowest setting I am looking over the top of the screen by about 3-4 inches. By the sounds of it the 20" should be perfect for you.
I will take some pics tomorrow and can email them to you. Never have posted any pics. PM me your email.
Chris
Sorry for the bad poetry, but I LOOVE the 20" Madstad winshield! It has really increased my enjoyment of my F3. Next is belt tensioner. You will love the Madstad!
I have the Madstad setup on my 2008 GS and love it, I also have one on my Honda ST1100
both are the 24inch shields I will not change they are simply the best on the market...
the amount of adjustment up-down forward and back is unmatched....
I will now step down from my soap box...
Thank You
Dave
I am 5' 8" and installed a 18" Madstad.
What I got out of the box and put on the bike was either a misprint or completely un-usable.
First the pros:
Base plate design and fit to the bike looks great.
Now the cons:
Rear mounting brackets are extremely flimsy, allowing lots of vertical flex. The upper windshield bracket bolts dig into the dash cluster and the windshield flops in the wind.
Position of the windshield is way to high. In the lowest position is a wide gap between the cowl and the bottom of the windshield. Air coming over the cowl goes under the windshield and mixes with air going over it causing a lot of turbulence behind it causing the visor on my modular helmet to flutter violently. No matter what adjustment I make. That was a scary test ride.
I undid the screws and lined the upper holes in the windshield with the lower mounting points in the brackets and what an improvement. Now I can raise and tilt the windshield where it needs to be. I drilled 2 holes to match the upper bracket nuts and now the windshield stays put.
Final verdict:
What I got sucks. Mounting brackets need improvement, bolt holes in the windshield are in the wrong place and rubber foam wedges between the base plate and the dash cluster were not included. Was this thing ever road tested?
I am 5 foot 9 and I have the 18 inch Madstad shield, it works fantastically. I don't have any of the problems you have. I wonder if you received all the right parts. I'd call Madstad and tell them your complaints
. . . . . that just doesn't match my experience either. Something is wrong.
With my 18" shield, and me being 5'8", at the lowest setting, the top of the shield is about even with my upper lip. I have it adjusted to about even with my eyebrows. It is stable and gives great protection.
First the pros:
Now the cons:
Final verdict:
Thank You!
By all other accounts was beginning to think had done something wrong. At least now someone else has a problem and complaint about the Great Madstad shield just sayin
I am only 5 ' 10" and have the 20" but I love it.. with the taller windshield I can get as much protection as I get on my RT or I can slide it all the way up and let some air flow come underneath the shield to cool me like a vented windshield does. Mine installed with no trouble and works GREAT! With this windshield in place I will be taking the F3 on a Saddlesore 1000 ride later this year.
My installation looked similar at first what your pictures show. Does not work for me. That huge gap below the windshield had to go and the wobbling and flopping was unbearable even at 40 mph. And it still goes 3" higher. What for?
Here are some pictures what I wound up with and like. Smooth air around my chest and head and no more neck strain. And I see the road surface over top 30-40' in front.
