Help on 622 trailer key
Ok found out yesterday that BRP no longer has the matched tumbler for the trailer with the 2015 spyder (must save BRP like 50 cents.) Our dealer says to keep one of the 13 keys and he will get another to go with the machine. Is there another way? I hear about a key without the chip. Will it work?
Traded 2013 rt s se5 for pearl white 2015 RTS se6 .
Gloryder hubs
622 trailer
bumpskid
Wife and I have been a couple since 1980
32 years of wedded bliss
yes can be done.
The lock tumbler for the trailer as long as the key for the bike is the same keyway the wafers can be changed so they configure to the bike key.
I have to include that it may be possible BUT , the correct wafer kit and someone that has done this would be recommended ie a locksmith.
I have a different key for my trailer, it has red on it where the Spyder key is silver. I have the extra tumbler from my 14 but to me it isn't worth the bother to change it. I have a keychain that has the trailer key on it along with a spare key for my husband's bike and my trailer padlock key so I carry this when traveling.
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
14 RT-S , Stock Large brake pedal White Pearl
2015 BMW R1200R LC
2014 RTL SE6 Pearl White
2012 RT-622 trailer viper red
2011 Polaris Ranger green
2016 Can Am Maverick
Originally Posted by jaherbst
Don't think this key will work on the 2014 or 2015. Complete key change for these years. Also different chips for programing. Just went through all of this when the dealer lost my keys and gave me some 2013 blanks to cut at the locksmith. Did not work and had to order new 2014 keys from the factory. We did find a 2014 tumbler that came with the bike to install on my 2012 trailer.
Jack
Many have reported they work just fine for 2014/15. Key profile is still the same (S1). It was a chip technology change. Went from fixed transponder code 2013 and earlier to a rolling code transponder starting in 2014.
Since these don't have a transponder they will work exactly the same.
My 15 RTL came with the tumbler for my 622 trailer, or at least they told me it would work in my Rt622, but I have not changed it out yet
cruzr Joe
My '14 RT Limited came with a tumbler for my 622 trailer. I changed it out and it works fine.
Joe, how was your vacation?
cruzr Joe
Let your dealer do it. It is a PITA.
Jack
2015 BMW R1200R LC
Yes
As it turned out the tumbler was in the machine. Dealer was surprised. Now need to take trailer down and have replaced or find directions on line.
Gloryder hubs
622 trailer
bumpskid
My 15 came with a keyed tumbler & I removed latch system. Under $3 at locksmith got it done. Just make sure you don't loose spring/small ball when removing tumbler plate on back of latch. Ann I bet Joe could have it done in under a hr.
Still on on vacation for about 5 more days, having a good time. In Kissimmee fl. Right now
cruzr Joe
I have the directions and how to change the lock set on the RT 662, PM me your email address and I'll send it to you. If there's a lock already on 662 you'll need the key that fits that lock to change it out.
ToM
Life is Great
Be Safe
