Results 1 to 12 of 12
    Apr 2015
    northern ontario
    Default First oil change, metal on clutch cover magnetic plug
    2000 miles on so I did the first oil change today. Very easy to do but takes a long time to drain the left (engine) drain. Both plugs are magnetic and only the clutch cover drain had filings. Filter looks good also. I'm going to bring the oil,filter and metal filings to the dealer tomorrow. It may be normal for this motor but who knows. If this was an aircraft chip detector, it would be grounded!!!!! LOL
    Sep 2012
    Flushing , Michigan
    It don't look normal to me. It's a good thing you change the oil at 2000 miles.
    ToM
    Life is Great
    Be Safe
    Jul 2014
    Mint Hill, NC
    I don't think what you found is abnormal. There is always some initial wear evidence found by magnetic plugs. Without the magnets you would have simply dumped them out with the waste oil. I did my first oil change on my RT-S, 4,400 or so past dealer 3K service. Good news was there were only two very, very tiny metal slivers on the transmission plug magnet. Leads me to assume that at worst the 3K change got the majority. With luck you'll probably be home free from here on.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Mar 2012
    NJ
    Likely assembly debris. To make sure do another change in 1k.
    Aug 2013
    Apache Junction, Arizona
    Default jacking up your spyder
    Quote Originally Posted by 1blackbeauty View Post
    could you please tell me where you jacked up the rear on your f3. i couldn't tell by the picture, possibly the frame rail ?
    Apr 2015
    northern ontario
    Quote Originally Posted by arizona spyder View Post
    Jack is under the lower fender mount where the tube attaches to the swing arm. I will post a pic tomorrow.
    with Drew...
    A little bit of that stuff almost has to be expected...
    But that's more than just a little bit!
    Aug 2007
    Greeneville, TN
    That is quite a bit of stuff. I'd be concerned. Looks to be more than just assembly debris. And you're only catching the ferrous components. Copper, aluminum, stainless, plastic are not going to show up here. So keeping the filter is also a very good idea.
    Still, it isn't necessarily a problem. You can pretty much figure if the dealer had done this oil change you'd never know.
    I agree with pulling the plugs again at 1k and seeing what you have then.
    Jan 2009
    Northwest Arkansas
    I just did my first F3 oil and filter change at 525 miles. There was a little bit of filings on the magnetic plug, but nothing like what you got. I agree with another poster that it was initial assembly remnants
    and I am not concerned about it. I replaced the drain plug with one that has a much stronger magnet and more surface area to retain any future filings.
    For those doing their own F3 oil and filter changes, the brake reservoir can be moved out of the way without tools, it releases from the bracket.
    2015 F3 SE6 , White - The fastest color!
    Apr 2015
    northern ontario
    Put 50 miles on today and it shifts better for sure, also a little quieter. Royal Purple Max Cycle 10-40.
    Active Member RPM's Avatar
    Jan 2015
    Folsom, CA
    Can you post that pic please? Thanks!
    2022 Spyder RT SEA-TO-SKY Mystery Blue... (bought new May 2023, a work in progress...)
    2015 Can-Am Red F3-S, SE6
    CalSci shield, Elka stage 5 rear shock, stage 4 front shocks, Akrapovic silencer, BajaRon Bar, Roadster Renovations vibration dampener, Tricled LED headlights and auxiliary lights, driver floorboard, driver and passenger backrests, Tricled Safety Led package, Shad BRP/SH36 side cases, Baker built luggage rack, Tricled Rear run/brake/turn signal led, Tricled LED piezo brake bullet strobe, JDM Astar LED bulbs for rear and front lights, Airhawk seat pad, USB power outlet
    Apr 2015
    northern ontario
    Quote Originally Posted by RPM View Post
    Sorry, here it is.
