Results 1 to 19 of 19
Thread: check engine
    Active Member gozzillaman's Avatar
    May 2011
    italy
    Default check engine
    Hi guys, this year it seems that the problems did not want to leave today Glowing engine with "check engine" after turning off / on again the engine a few times disappears. with warning light on the engine runs well seems almost an electrical disturbance. What advice should I check
    Jul 2011
    Mitchell, Ontario, Canada
    Engine light on solid with "Check Engine" message means there is a problem with one of the engine management components.
    When and if the warning comes back check for active codes. If you're RS is 2013 or newer press "Hold" + "Set" + "Turn Signal Cancel". If you're RS/GS is 2012 or older the procedure is different and more complicated. Let us now and someone will come up with the procedure.
    2018 F3 LIMITED
    May 2011
    italy
    I have a 2009 Spyder GS SE5 anyone knows explain the procedure thanks
    Very Active Member oldgoat's Avatar
    DDO, Montreal Island
    Quote Originally Posted by gozzillaman View Post
    I have this method saved in case I need it. I just tried it & it works
    FAULT CODE PULL UP (2008 GS)
    With ignition switch on (or engine running) press MODE button (the one on the dash) repeatedly until "engine hours" (total hours) shows on display.
    Press and hold MODE button down (the one on the dash) while pushing the "flash high beams"button five times within 2 seconds.
    If there are no active faults "No Active Fault Code" will bedisplayed.
    If there is an active fault, an alphanumeric code will be displayed. This canbe looked up in the shop manual (available on CD) or you can ask onSpyderLovers and someone will look it up for you.
    If there is more than one active code, you may press MODE to cycle through them
    2008 GS SM5, Full Moon Silver
    2007 Piaggio MP3 - 250cc
    Default Suggestion...
    if you have an android download free app "spyder codes" and if an apple "my spyder". You will find the proceedures and codes along with helpful information. Worth having wherever you go.... sometimes the key walk will clear the check engine...
    ​2012 RS sm5
    Very Active Member coz's Avatar
    May 2011
    cincinnati, ohio
    Default how to check codes
    it's in your owners manual.
    it was fun while it lasted.
    May 2011
    italy
    Code P0443 what it refers to what I have to check or replace you guys please help me also to find the part number
    Very Active Member Dudley's Avatar
    Dec 2008
    Jacumba, CA
    Have you tried riding it? Or did it just happen when you started it. I would ride it locally ans see what happens. Won't hurt the Spyder. It's the Evaporation Canister (purge valve), I believe.
    2008 GS SE5 in 2008
    Traded at 43,000 miles for a left over
    2010 RT SM5 in 2011
    Traded at 57,000 for a left over
    2014 RTS SE6 in 2015, which has 35,000 miles
    Oct 19th, 2017, totaled 2014 RT while killing a Javaline
    Dec 12th, 2017 drove a 2017 F3L home. What an awesome machine!
    Never had any breakdown stranded issues.
    May 2011
    italy
    the bike starts without light on the problem occurs walking but the engine runs well
    P0443: Evaporative emission system purge control valve
    This valve is on the rhs side on top of the evaporation canister.
    May 2011
    italy
    guys could you tell me the part number
    May 2011
    italy
    or just goes clean
    Dec 2008
    Jacumba, CA
    I would ride it. Nothing damaging to Spyder until it can be changed or it clears itself. which it might.
    2008 GS SE5 in 2008
    2010 RT SM5 in 2011
    Jul 2011
    Look at item number 18 Purge Valve 709000443 $48.99
    2018 F3 LIMITED
    Mar 2012
    NJ
    Just thinking out loud. ..wonder if a resistor would work as a bypass for those of us running with no canister...?
    Jul 2011
    Quote Originally Posted by DrewNJ View Post
    I would guess that should work.
    2018 F3 LIMITED
    May 2011
    italy
    friends sorry if I did not feel, but the canister valve has been slow to arrivare.Volevo as always thank you for your invaluable help was invaluable. Believe me without you and of this beautiful community do not know and I could not manage my spyder
    Active Member dickgi's Avatar
    Aug 2017
    Saskatoon
    Useful information. Is there an easy way to clear the codes on a 2013 RSS? My check engine light came on but it ran fine so I kept going home. I then read the repair manual and one of the cures listed was to simply turn the engine off, remove the key and then see if the light comes back on. It didn't in my case and has been fine for about the last 100 miles.
    Active Member R FUN's Avatar
    Apr 2013
    Rocanville Saskatchewan canada
    When I was at the 3-wheel ralleye in Deadwood last month my check engine lite came on. Took it to the dealer in Spearfish and it was the map
    censer vacuum hose. It was dried up and cracked and came out in pieces.A very easy fix for them
    Roger.
    2012 RT Limited
    Vertika Floor boards
    Painted rear fender & dash
    Carbon fiber panels
    Utopia back rest
    Baker air wings
    Elka shocks and relocaters
    CB radio
    ISO hand grips
    Tric LED fender light
    Turn signal lights in mirrors
