Page 9 of 16 FirstFirst ... 5678910111213 ... LastLast
Results 201 to 225 of 378
  1. #201
    Edmond, Ok
    I think think you are right, this recall mod should reduce the heat even farther. I am thinking about mounting a fan somewhere in the engine compartment that I can turn on manually to pull heat out at low speed or in stop and go traffic. Any thoughts on this and on where to mount the fan?
    Quote Originally Posted by robmorg View Post
    I have done both of these mods as well. You should NOT have to re-install them. I agree that both of these mods together have mad a huge difference in the amount of heat coming up around the seat, as well as the heat on the fuel tank. Whatever ECM changes are part of this campaign should be compatible with both of these changes. They have had no effect on the ECM thus far, as you know. To the best of my knowledge, the only exhaust sensors that the ECM monitors are the oxygen probes up at the front of the headers near cylinders. Since nothing in the exhaust system is monitored aft of that point the ECM should be oblivious to both wrapped headers and the cat bypass.
    I think that those of us who have already wrapped the headers and removed the cat, should have the best of both worlds after the fix is done. The Spyder should exhibit even less heat than those without the mods, PLUS, as has been stated earlier in this thread, BRP may even reimburse us something, through a dealer credit, for the previous work.
  2. #202
    Very Active Member robmorg's Avatar
    Oct 2013
    Pottstown, PA
    Quote Originally Posted by R&L Limted View Post
    Did I understand BRP , that the trikes will be brought back to stock , then do the recall? does this mean cat- delete pipe wraps etc, work will be returned to stock?
    What BRP implied earlier in this thread is that these kinds of issues will be handled on a case-by-case basis in coordination with the dealer performing the recall. I'm assuming that there will be no reason that the recall cannot be satisfactorily performed on a bike with wrapped headers and a cat bypass. OTOH, if the fuel system, or possibly the intake system, has been modified there may have to be some additional considerations needed in order to perform the work, depending on what was done. I'm guessing the dealer would likely discuss this with BRP.
    There is no way that BRP can make a "blanket statement" that covers these issues because every case has the potential to be different. That is obviously why Steve said to work this out with the dealer doing the recall work.
    Here is what Steve said, specifically...
    i no longer have the stock air box on the bike but an aftermarket unit to improve air flow through the engine bay. Looking at the instructions, this should not have any effect on the repairs, actually saving the dealer considerable time. Will BRP allow the dealer to proceed?
    BRP generally recommends that vehicles be brought back to stock form before the update is performed, as it was tested under default conditions. Your dealer will discuss all the details with you before proceeding with the update.
    There are a great many 2013s out there with these and other engine bay heat reduction aids installed. Can we be assured BRP's intent is to work with the individual cases to get the updates done anyway while working with what is already done?
    Yes, see above.
    Rob
    2013 RT Limited
    My "Mods & Farkles" Link
    May ALL your roads be beautiful
    Greisemer's Mill Bridge, Oley, PA
    2013 RT Limited , Lava Bronze with Antler Brown Seat
  3. #203
    Edmond, Ok
    Rob,
    i think you are right. The mods the recall include do not have anything to do with the Cat bypass or heat wrapped headers. Fuel system mods may be a little different. Not everyone is going to be happy regardless and that's their right to feel that way. For me, I am going to make my wife's Can Am as comfortable and as safe as I can. I have made mods to every motorcycle I have owned taking into consideration safety and reliability with all of them.
    One thing I would suggest to dealers doing scoop mods is to smooth out the rough corners/ edges on the holes they are going to cut for the air scoops to help prevent potential cowling cracking.
    Jetmech
    QUOTE=robmorg;983945]What BRP implied earlier in this thread is that these kinds of issues will be handled on a case-by-case basis in coordination with the dealer performing the recall. I'm assuming that there will be no reason that the recall cannot be satisfactorily performed on a bike with wrapped headers and a cat bypass. OTOH, if the fuel system, or possibly the intake system, has been modified there may have to be some additional considerations needed in order to perform the work, depending on what was done. I'm guessing the dealer would likely discuss this with BRP.
    Yes, see above.
    [/QUOTE]
  4. #204
    Nov 2013
    Oro Valley Arizona
    Quote Originally Posted by Magdave View Post
    Ok is BRP
    going to refund the money I spent on the adjustable reflectors I bought?
    Yes Dave, they are going to refund the reflector cost. May not be able to ride a lot in the rain now without drowning the engine compartment but it will run cooler in the rain.
    Jack
    2015 BMW R1200R LC
    2014 RTL SE6 Pearl White
    2012 RT-622 trailer viper red
    2011 Polaris Ranger green
    2016 Can Am Maverick
  5. #205
    Nov 2013
    Oro Valley Arizona
    I believe that issue has been discussed.
    Unfortunately; I don't remember what the answer was!
    "The memory is the second thing to go; I forgot what the first one was!"
    I will let the Miss's tell you that Bob!
    Jack
    2015 BMW R1200R LC
  6. #206
    Idaho
    Quote Originally Posted by jaherbst View Post
    From what Steve wrote don't plan on a cash refund. His wording made it sound like it most likely would be credit to be used for parts, service, whatever, at the dealer.
    2014 Copper RTS
  7. #207
    Active Member Dragonfly's Avatar
    Apr 2013
    Atkins, Arkansas
    I have the 14K service coming up, maybe my Dealer can combine the Service with the Recall and save me a few bucks. My heat mediation was just short of $500.00. Would be a nice trade off.
  8. #208
    Active Member ekfraz's Avatar
    houston,texas
    Default Heat
    I will be getting the recall handled this next week and I sure hope that this works, I would like to take longer rides like I did on my 2008 GS, I feel that they have this all worked out,we will see for sure. I will post pictures also.
  9. #209
    May 2013
    Stanton, ca
    I would say this topic has gone down hill and I would not be surprised if Steve from BRP gave up even reading this anymore.
    Sometimes I wonder what some people post is really in the best interests of us all when it comes to a thread like this where BRP is listening
    Bob
    2011 RT-S SM5 - Black
  10. #210
    Active Member KennW's Avatar
    Oct 2013
    Gold Coast QLD Australia
    Sure am looking forward to hearing about owners views once they have the modifications done. Unfortunately I feel it will be a few weeks yet before my RT gets the updates done as I live in Australia. On the plus we are currently running into winter so although living in Queensland and winter days are usually in the low to mid 20°C the heat issues aren't such a big deal as in summer. Am just hoping that owners give this modifying from BRP a fair trial and subjective review don't just go into "bitching" mode. Here's hoping BRP proves to be a winner. Regards to all from Down Under
  11. #211
    Oct 2013
    Pottstown, PA
    Quote Originally Posted by finless View Post
    Bob
    You make a good point Bob , but I wouldn't worry too much. I think by now Steve is probably familiar with all our "indiscretions".
    Rob
    2013 RT Limited
  12. #212
    Active Member BRPcare's Avatar
    Jun 2013
    Québec, Canada
    Default Couple more pics
    Hey all,
    I was able to sneak a couple more pics of the panel portion of the update to give you a better idea of the look:
    BRPcare
    Social Consumer Experience Team
  13. #213
    Aug 2013
    Quebec City, Quebec
    To all BRP guys and girls who works on this recall ---> GOOD JOB.
  14. #214
    They actually look pretty darn good on the yellow RT!
  15. #215
    Active Member condorflysu's Avatar
    Feb 2013
    Brampton, Ontario, Canada
  16. #216
    May 2013
    Stanton, ca
    Thanks Steve!
    I actually like them and I want them for my 2011!
    Will people be able to purchase them later? I assume they have to be made a spare part at some point?
    Bob
  17. #217
    Invalid Emails
    Oct 2013
    CLERMONT FL
    Default nice
    I really like the way they look. I have my appointment set for june 19th to get the recall done. Thanks brp...
  18. #218
    Oct 2013
    Pottstown, PA
    Thanks for the additional pictures, Steve. I like the way those scoops look as well. I'm glad you guys made them in gloss black. Better than the "plastic chrome" look, and I think they somewhat enhance the look of the RT. They should certainty enhance the ventilation to the engine compartment.
    Rob
    2013 RT Limited
  19. #219
    What's wrong with "plastic chrome"?
  20. #220
    Banged Up Member MouthPiece's Avatar
    Dec 2009
    Sanford, Florida
    They'll certainly look good on my yeller "13" RT-S.
    Chris
  21. #221
    USA, PA York
    I hope it looks that good on white.
    Traded in - 2013 RT SE5 Limited - Pearl White
    Mods Mods
    Tri Axis handlebars
    GPS mount for the Tri Axis handlebars
    Ultimate seat with driver backrest
    Driver cup holder
    3rd Brake light -truck
    Spyderpops bumpskid
    Bayaron swaybar with Heim links
    Lidlox
  22. #222
    Active Member scarecrow's Avatar
    Sep 2013
    largo, florida
    I'm with finless. I like the scoops. I'd like to try them on my 2014 rts. Still like to push more air at the engine. Those of you that have the adjustable air wings I would try to keep them many of us 14 drivers would like to have them at a reduced price.
    They put them on my 13rts durning the first heat reduction test, but kept them when I trade for the 14rts.
    2014 RTS , Cognac
  23. #223
    Invalid Emails
    Jan 2012
    Huntsville, Al.
    That will look really good on my yellow RTS.
    Bill C.
  24. #224
    I hope that BRP is listening... The scoops are getting some decent reviews, and interest from RT owners that don't even have to have them!
    (Put them in your accessories catalog!!)
  25. #225
    May 2013
    Stanton, ca
    I think the problem will be the jig and tool to cut the panel!
    But some of us good with a Dremel can probably handle it with the paper template
    Bob
