Page 1 of 2 12 LastLast
Results 1 to 25 of 33
    Dec 2013
    wisconsin
    Cool NEW REAR TIRE AFTER ONLY 8002 MILES!
    Replaced my rear tire on my RT LIM. last week with a YOKOHOMA S-DRIVE from Discount Tire. Took wheel off of machine myself and took to POMP's tire,they could mount but not balance. So off to the SPYDER dealer I go. 4 hours later(when they could work me in) I'm $88.00 leaner(mt./bal./disposal/tax), so we will see what kind of mileage we can get out of it. Question- has anyone had any kind of bearing issues on the 2014 machines?? When I had wheel off, checked for roughness/end play,all seemed to roll smoothly.Did not notice anything unusual. Ride safe all!!
    Nov 2012
    North Las Vegas, NV
    Some of the rear tires on the 2014's only lasted 4,000 miles. You did well.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Bryant, Arkansas
    Yeah, you did great i barely got 5,000 out of my 14 Tire.
    Cruzr Joe
    Active Member cyclekid58's Avatar
    Sep 2014
    Post Falls Idaho
    Default Kenda Tires
    Cruzr Joe
    9,400 on my stock kenda's and they still look like new on my 2014 RT-S.
    Greetings from Idaho
    2014 RT-S,
    Barjaron swaybar, chome luggage rack, Ram Mount GPS, 12 volt dash outlet, spyderflap mudflap, Rivco flag mounts, drink2go and custom handlebar drink holders,Driver Backrest,Tri-Axis Handlebars, TRICLed turn signal lights. Custon Dynamic Magic Strobe Brake Modulator, Triple Dash Pouches, "Squared Away" Laser Alignment, Spyderpops Bumpskid, TricLed "Knightrider" LED
    2014 RT , White (Mine) Cognac (wifes)
    minnesota
    $88.00 to mount and balance when you already had it off the machine?
    Sep 2012
    Junction City, KS, USA
    I changed mine at about 7500 miles. Welcome to the Kenda tire club!
    PrairieSpyder (Patti)
    Very Active Member Deer Slayer's Avatar
    Mar 2015
    Advance, NC
    14 RS, just over 4 k and way over half gone with no burnouts! Crappy tyre!
    If I can't fix it, I will fix it so no one can fix it. Sypder Loco!
    5600 miles on mine, when it needed replacing.
    Bearings: I think that they used to say, 20,000 miles, and then replace them...
    But I don't remember the source of that tidbit...
    Default Just for balance...
    22,000 when I changed mine 6,000 on the second one and doing great...28,000 miles on the fronts...can't complain so won't...
    ​2012 RS sm5
    Jul 2014
    United States
    6,000 on the rear when I changed it. Fronts have 17,000 on them and are still fine. $88 was a bit much on a tire changeout. Guess that they figured if they couldn't sell you another crappy tire, they'd make it in labor. Still doesn't make it right though...
    Dec 2010
    Fountain Inn,SC
    Changing mine out @ 8500 miles no wear bars left in the middle. Going with Kumho this time
    Jul 2014
    Mint Hill, NC
    I got 6,800 on my first one; maybe could have gotten more as I saw some at Spyderfest that were worse than mine and I still had to get 900 more out of it to make it home. Perhaps overly cautions about hydroplaning risk, but it's my tail on the line.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Very Active Member Orange Spyder Man's Avatar
    Sep 2014
    3rd ROCK FROM THE SUN !
    $88.00 for mount, balance, disposal & tax is absurd... I would never step in that "stealership" again..
    osm
    Jun 2014
    ny
    i have over 5k on my rear & it still looks good, i expect 9-10k out of it
    May 2013
    Stanton, ca
    I got 12K out of my rear tire but it's a 2011 RTS so it was a older Kenda.
    I too went with the Yokohama S drive. Loving it so far!
    As for the bearings, 2014 I do not believe changed anything with the rear tire setup over other RT's. I also just did a feel and visual of my rear bearings and seals and all was good. Since I am sure you and I will both be getting more than 12K out of this Yoko, I am going to check my bearings again at 24K or maybe even earlier when I go to do the brakes.
    Bob
    2011 RT-S SM5 - Black
    Sep 2014
    Quote Originally Posted by finless View Post
    Bob
    Bob... what size Yokohama tire did you install on your Spyder.... I want to order one for my 2014 RT to have on hand when I need another tire..
    tia
    osm
    8900 on my first rear tire. 4600 on tire # 2 and it still looks new.
    Very Active Member Tango's Avatar
    Apr 2012
    Florida
    First rear tire, soft compound CRAPENDER changed at 3,000 miles. Might have been good for another 2,000. Kumho replacement, $139 installed by Netzley Tire. Stealer wanted $280 installed. Tom
    Baloo is my name. Spyders are my game. Well, it's a doo-bah-dee-doo, yes, it's a doo-bah-dee-doo, I mean a doo-bee, doo-bee, doo-bee, doo-bee, doo-bee-dee-doo. And, well, now. Ha ha! What have we here?
    2020 Petrol Blue Metallic RTL
    May 2013
    Stanton, ca
    Quote Originally Posted by Orange Spyder Man View Post
    tia
    osm
    Yokohama S-Drive 205/55-15
    Bob
    Very Active Member Firefly's Avatar
    Feb 2009
    Ceresco, Michigan
    I've never gotten over 7,000 off a rear tire.
    Any tire shop should be able to mount the rear.... No need to balance... Just out some Ride-On in it and it will self balance.
    Fronts do a bit better... Maybe 12-15k before replacing.
    Spyder #1 - 2008 GS SM5 Premier Edition #1977. RIP after 80,000 miles.
    Spyder #2 - 2012 RT SM5. Traded in after 24,000 miles.
    Spyder #3 - 2015 F3 SM6. Put 13,000 miles on and sold it.
    Spyder #4 - 2017 F3 SM6. Too good of a deal to pass up!
    Very Active Member 4 MARIE's Avatar
    Apr 2014
    Beloit Kansas
    8000 miles ! You one lucky dog.
    Flatlander, Navy Veteran, Widower
    Loved my 2014 RTS SE6 Pearl white
    but have a new love now,
    my 2017 RTS SE6 Champagne metallic (Champ)
    Dec 2013
    wisconsin
    Default REAR TIRE CHANGE
    Yes I thought $88.00 for the mount&bal.was high but I went to a dealer that was closer than the one I bought the machine from which would not mount a car tire on the rim even if I took it off the machine and took it to them,still wanted $75.00 +,sooooo I had to do as I did for now. The fronts, when they wear out will have Conti. procontacts on them which I bought at the same time as the rear, and POMP'S will be able to do the complete deal if I bring the weels to them at $17.00 ea. The fronts look about 1/2 wore so I hope to get the rest of the riding season out of them. My YOKO size was the 205/55R15 and it brought the speedo 1 mph closer to the GPS reading(GPS-60/speedo=61mph) The Conti's (155/60R15) are the same tread pattern that's on our '13 FORD Escape(quite abit wider on the car) and I feel that they work very well in wet weather,so I think all will be safe and that's the main thing. 95% of time the machine is riden 2-up and 20% of that was with a trailer. RIDE SAFE ALL!!
    Feb 2009
    Ceresco, Michigan
    Cracks me up how Spyder peeps complain about 'only' getting 8,000 miles off a rear tire. On many motorcycles that would be considered doing really well.
    Jun 2011
    Near Lexington, NC
    Default Flat rate labor charges
    I think $88-90 is about the standard flat rate for mounting & balancing a rear tire. That is what the shop I go to charges whether it takes an hour or half that. They also mount car tires.
    Two Wheelers from 1963-2011
    Three Wheelers:
    2011 RT(Red)
    2014 RT(white)
    2016 F3T(red)
    2022 RT current ride(silver)
    __________________
    2016 Slingshot
    2018 Vanderhall
    2019 Slingshot
    Sep 2014
    Quote Originally Posted by ulflyer View Post
    when I got rid of the "CrapKenda" that came on my 2014.. the tire shop I brought the wheel & tire charged me $15.00 to dismount the junkie tire, mount the new Khumo and balance it..
    osm
