Page 1 of 2 12 LastLast
Results 1 to 25 of 39
    Jul 2014
    Mint Hill, NC
    Default ACE 1330 Oil Change Without Filter Change
    Here's the given as I understand it: For an SE6 oil and filter change we should use 4.7 L or an even 5 Qt. For those of you who are doing an oil change at less than 9,300 miles and are not changing the oil filter, how much less oil are you refilling with to compensate for the unchanged filter and the amount of oil that will remain in the filter housing?
    OR, are you changing the filter every time you change oil regardless of interval?
    I'm not being cheap, just figure if BRP says a filter can go 9,300 why not replace it at every other oil change.
    Thank you.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Nov 2012
    North Las Vegas, NV
    But if you want clean oil why not change all the oil and filter whatever the interval?
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Default Here's what you do..!!
    If you don't do the filter refill the oil as you should. Capasities is not the way to do it. Refill a quart low, start the egine bring it to operating temp and measure then top off. The draining process can vary and overfilling is harder to deal with. Filter will last much longer so you don't have to do it each time but I use kits and it's all there so why not do it...
    ​2012 RS sm5
    Default THIS QUESTION
    Thank you.
    ....I don't plan to change my filter either this year if I go past 5,000 miles but I will change the oil ( and I use Rotella full syn ). I would go with 4.5 Qts, take a ride then check it. The amount you are low will not have any adverse effect on the engine for this amount of time. Now you can get the exact amount you need to add without overfilling .....which I believe is a WORSE condition.........Mike
    Very Active Member Purple Guy's Avatar
    May 2013
    Edmonton Alberta, Canada
    Just me, for the price of the filter I change it with the oil...
    2014 RT-Ltd , Cognac
    Nov 2012
    North Las Vegas, NV
    Quote Originally Posted by Purple Guy View Post
    You said it better than I did.
    2016 F3 Limited
    2019 Ryker Rally
    2020 CSC TT 250
    Considering the price of a filter, I also replace the filter and the oil at each oil change.
    Remember the old saying? If you don't replace both, you new oil is contaminated by the glop that remains in the filter.
    Jun 2011
    Near Lexington, NC
    Thank you.
    Jay, I change the filter every other time and oil at 4000. It takes 5 qt nicely, either way. Filter doesn't seem to make a diff.
    Two Wheelers from 1963-2011
    Three Wheelers:
    2011 RT(Red)
    2014 RT(white)
    2016 F3T(red)
    2022 RT current ride(silver)
    __________________
    2016 Slingshot
    2018 Vanderhall
    2019 Slingshot
    ...And with both of them...
    If you want to save money; buy the Store-Brand Peanut Butter instead!
    Registered Users donkes's Avatar
    May 2015
    VA
    for the bike investment, oil w a filter change is a cheap investment.
    May 2013
    Indiana
    Default Think About It
    People spend hunderds/thousands of dollars on accessories(farkels) to make their Spyder look cool. Why are we even talking about the cost of an oil filter?????????????????????
    2021 Marsala Red Metallic RT Limited
    Very Active Member Orange Spyder Man's Avatar
    Sep 2014
    3rd ROCK FROM THE SUN !
    maybe its not the cost of a oil filter... it just may be because its so much trouble & time to get to the darn thing..
    osm
    Default OIL FILTER
    Quote Originally Posted by ulflyer View Post
    ......I don't see the need to change an OIL filter ( good for 9300 miles per BRP ) at 5000 miles ( I'm using Full Syn Oil )...When I change my Oil at 5000 miles, and may only go another 1 or 2 thousand more that year....... You have a lot of Owner's here going 9300 miles with BRP blended oil and filter change ...per BRP recommendations........Mike
    Invalid Emails murphybrown's Avatar
    May 2010
    Chelan, WA .. the dry side!!
    Default OK where do I send oil
    Have been reading many opinions on SLs about changing oil intervals on the 1330....I have been just following BRP recommendations...but I am getting ready for oil/filter change and by the time it occurs I will be at 10k miles...a little over. What I would like to do is send some of that oil to the "oil gods" and get all those facts about breaking down, etc. So gurus...where do I send?...how do I send?..cost for the analysis?
    Yep the oil "itch" needs scratched. Thanks..I will share results here.
    Have a great day..it is a wonderful day to be alive!!!
    My Motto Is:
    Live my life in such a way that when my feet hit the floor in the morning...Satan shudders & says "Oh, crap, SHE'S awake!"
    Red Stallion: 2016 F3t SE6 (from Pitbull PowerSports/ Springfield, MO)
    White Knight: 2014 RTS SE6 and matching 622 trailer (from Pitbull
    Ms Spydee: 2010 RT SE5
    Jul 2014
    Mint Hill, NC
    As I mentioned in the initial post, this is not at all an issue of the expense of the oil filter; the real question is with filter manufacturing technology is it really necessary to change the filter when doing a mid course oil change because some of us are concerned with viscosity breakdown well short of the 9,300 mile change interval. My operator's guide does say to change the filter each time the oil is changed and if a reader takes that direction along with the 9,300 interval I would definitely agree. I've not seen an automotive oil filter manufacturer, not long haul truck service, advertising filter life in excess of 15,000 miles. If someone wants to debate whether an oil filter's cleanliness impacts the viscosity breakdown of the oil itself I have neither the education nor the experience to participate in such a thread. The primary reason behind my original question was to ensure that if I were to not change the filter what would be a reasonable initial refill amount to ensure that I was not overfilling the engine because of the amount of oil remaining in the filter and canister after the crankcase and transmission were drained. We've seen elsewhere on SL the alleged reduction of engine power if the engine is overfilled.
    My main objective, in addition to satisfying my own uncertainty about viscosity breakdown, is to hopefully provide analysis reports of at least the first two types of oil I've fed the engine and, if I stay with Mobil 1 will compare two successive oil changes to see how consistently it performs.
    Considering the bucks we have invested in our machines, debate about the best way to protect those investments is good IMO.
    Cognac 2014 RT-S
    Sep 2014
    USA
    Its amazing what is inside your engine oil and filter..Stuff you cannot see..Anytime changing the oil a filter should be replaced...IMO..
    Quote Originally Posted by murphybrown View Post
    Perhaps someplace like this?
    http://www.blackstone-labs.com/free-test-kits.php
    Very Active Member bmwlarry's Avatar
    Mar 2012
    Beaverton, Oregon
    I have never done this for my spyder. I have used Blackstone labs many times when I raced my BMW E46 M3. They do great work and proved great information. I would like to see the results of the oil after BRP recommended service interval.
    2015 an Am Spyder RT Limited
    2013 Yamaha WR250R - Sold
    2011 Can Am Spyder RT-S SE5 Limited - Sold
    2011 Aspen Sentry Trailer
    2003 BMW K1200LT - Sold
    2007 Unigo Trailer - Sold
    2001 BMW K1200LT - Sold
    2001 Honda 750 NightHawk - sold
    2015 RT Ltd , Canamspyderaccessories Brake pedal ext. Red
    I know that there are lots of other places.
    I just "Googled-up "Engine oil analysis Kits", and they popped up!
    Jul 2014
    Mint Hill, NC
    I bought two kits, from Wix, through amazon.com for $37.70. Cost of kit includes analysis. Same kits are supposed to be available from Napa auto stores but the folks around here who run them are idiots who know nothing about how to get them for a customer.
    Cognac 2014 RT-S
    Sep 2014
    USA
    I know Grainger sells oil analysis kits
    Bryant, Arkansas
    Oct 2014
    Cumming Ga
    Just did a oil change on my better halfs rts yesterday.It really isn't that hard to pull the fairing. I know you are all in debate over the filter that was $15 but what about the three orings? I think they should be part of the filter but had to spend another $18 on them. It did only take 5 quarts. As for the debate my harley and her rt will get a complete oil change every 5000 miles.
    Default I'M TRYING THESE
    Quote Originally Posted by R.Blackurn View Post
    I switched to FIBER washers .....2000 miles and so far no leaks.......was told they will outlast rubber by a lot......and I paid $1 ea......Mike
