Page 1 of 2 12 LastLast
Results 1 to 25 of 26
Thread: A crazy idea
    Invalid Emails
    May 2011
    Tulsa Oklahoma
    Default A crazy idea
    The 998cc Spyder engine has around 100hp, the RSV Millie with the same engine has around 146hp, if it is the exact same engine, how will the Spyder react with it? I wonder if they will interchange? it is very tempting to try find out
    Default Not so crazy...!!
    So when will you be doing this..??'ing to see the reviews...does sound interesting and fun...
    I'm watching.
    Invalid Emails
    May 2011
    Tulsa Oklahoma
    You forgot to mention expensive, i will do some research but it will be long time before i can atempt something like that, hope somebody beats me to it and i can copy him
    Default WELLLLLLLLLLLLLLLLLL
    COMPUTERS ...COMPUTERS ....COMPUTERS /..............Need I say more ?????...........Mike
    Will you be able to convert the output from the new engine, to the belt drive of the Spyder?
    Mar 2012
    NJ
    Yes, it works. We have a local who has already done one and currently making some improvements. I also picked up a wrecked rsvr from a friend who is scared of it with the intent of doing one as well. However, cheap unwrecked spyders are hard to come by and I'm not at the point of ripping my 12' apart.
    There are a few different ways to approach it. The one I rode he swapped out the gears in the trans so he had 6 speeds but no reverse. Runs the Aprilia electronics. No nanny, no abs, etc etc. Aprilia cluster.
    I've also been told that you can leave the hard parts in place and swap electronics. Again losing all the nanny abs etc.
    Aprilia cluster has to be modded to fit but looked nice.
    The ride is unbelievable!
    I was waiting for you to get to this party...
    Is the Spyder converted to chain drive?
    Please; tell us more!
    Jul 2010
    Las Vegas, NV
    Default Engine mods
    I imagine the Spyder (Rotax) engine could be easily upgraded with higher compression Pistons, head work, cams and larger injectors to add 30 or 40 horsepower. A free flow air cleaner and exhaust, and the whole project comes in at $4K. We need some baseline dyno numbers, then go from there. I am in talks with MACSHACK, an engineering concern out of Utah. A set of upgrade kits, in stages, is the concept. Stay tuned! Joe
    Joe Meyer
    Very Active Member CanAmChris's Avatar
    Feb 2011
    Near Philly, PA - USA
    Quote Originally Posted by cptjam View Post
    I would be curious to know how much extra stress that would put on the transmission. If you behaved yourself I'm sure it could handle it, but I tend to misbehave on occasion.
    Mar 2012
    NJ
    Nope, using the stock belt drive. From what I understand the output shaft he either swapped or he had a splined adapter fabbed up with the stock front pulley. I know he was talking about both but I honestly don't know which way he went.
    My plan if I did one was to swap the spyder trans internals to the Aprilia case.
    this thread is bringing out the best of the backyard engineers...
    Invalid Emails
    May 2011
    Tulsa Oklahoma
    I knew there was somebody crazier than me out there!!
    May 2015
    VA
    interesting
    Quote Originally Posted by Mexican View Post
    You probably should grab Drew by the ears; ask him about a zillion questions and take notes about everything that he says...
    He's already done a bunch of research on this type of project...
    Sep 2014
    3rd ROCK FROM THE SUN !
    osm
    Mar 2012
    NJ
    Its not mine and I didn't build it so I'm far from being knowledgeable on the build. I do know the owner real well and have ridden it a few times. I've picked his brain on a few aspects of the build because I'm casually considering it.
    He has built a lot of pretty wild custom machines over the years. Usually he builds for the fun of building it, rides it a bit, then either parts it out, or it goes into hiding in the back of his shop. He is NOT into the forum BS and really wants no part of the "community"......some of you would say he has a bad attitude.....[emoji57] BUT, if anyone is planning on building one he is a super nice guy and has no problem sharing what he knows.
    I can likely get some pics next time I'm down there, but other than seeing an Aprilia cluster recesses in the dash opening and a drag radial tire on the back you wouldn't think its any different than any other RS. Its a stealth built machine for sure.
    Apr 2008
    Default Been there, done that.
    I have a kit very similar to this in a 2008 GS Spyder. Bike halls ars... 140hp. No issues in 11,500 mls. Bike is currently for sale.
    http://minneapolis.craigslist.org/hn...028698581.html
    Jul 2010
    Las Vegas, NV
    Default Exactly!
    If I did not just buy a new bike Friday, I would be all over this! What a bargain and easily worth much more! Somebody grab this deal! JMHO, Joe
    Joe Meyer
    YOu should tell Ann about it... she needs a toy like this!
    Invalid Emails
    Oct 2007
    Gold Coast Australia
    Back in 2009 Evoluzione , who are now out of business, had been reworking the Aprilla for higher performance and did offer a number of "upgrades" for the V twin Spyder, since the motors are essentially the same. They were the first people to offer a stiffer sway bar and an O2 sensor for the Can Am Unfortunately as I said they went out of business
    Invalid Emails
    Oct 2007
    Very Active Member retread's Avatar
    May 2008
    Bargersville, IN
    The earlier Aprilia Tuono and RSV used the Rotax 998, in a higher state of tuning than the Spyder's version. The gearing is identical, except that the Spyder trans has the sixth gear replaced by reverse.
    In Europe, I've heard of lots of hot rod stuff for the 998, big bore kits, a 1200 cc stroker kit, and so forth. The one thing hat would concern me with a project like this would be the clutch, our Spyders are lots heavier than the Aprilias are, and can't absorb hard starts by lofting the front wheels.
    It's been a few years since I played with ideas like this, but I was always curious about what a 1340 cc twin would be capable of in a Spyder.
    john
    Quote Originally Posted by retread View Post
    I think that it would certainly be capable of draining a couple of bank accounts...
    May 2008
    Bargersville, IN
    Yeah, Bob, the stroker kit 5 years ago was over 5K, to get really serious with these engines takes cubic money!
    john
