I want to add some Farkles but need an additional fuse block.
What are you using and where did you get it?
Take your pick.....Look here ....SUMMITRACING.COM.........Maybe not fancy , but they work fine..............I think the only issue may be the price ..........they aren't EXPENSIVE ....................Mike
4" Stubby antenna, Dual arm LEDs Fender LEDs, Back Rest, Luggage Rack, Run, Brake and Strobe for top case, Mirror LEDs,Back Off decal on mud flap, reciptal for Battery Tender and Heated Gear, mirror LEDs that stay on or work with blinkers, GPS, side bag red LEDs, Top cuff with Ram Ball phone holder And USB power, Top cuff with drink holder and passenger cup holder. Also grilles in front of radiators, also spyclops. Garmin 595 GPS, Freedom windshield. Also glove box console And trunk wrap in carbon fiber from wrap my spyder. BRP comfort seat. added garage opener with rocker switch in center console to match other switches. And I have added Elka stage 2 shocks.
This is just an example of what they have ....Go to SUMMITRACING.COM........# 900171------This is a weather tight 6 fuse @15 amp each Fuse block for $12.99........they have 100 or so others to choose from.....( Hella , Bussman etc )........Mike
There are numerous blocks available, depending on you requirements and budget , you will have no problem, make sure to get one that is going to suit your purpose tho. Number of circuits being added.
