Page 1 of 2 12 LastLast
Results 1 to 25 of 32
    Invalid Emails
    Jul 2014
    NC
    Lightbulb Dumb question - accelerator
    Ok guys, time for a dumb question. Got the RT-S, so obviously I have cruise control. The problem is, hubby rides in front of me and has no ability to ride at a smooth pace, so the cruise control is USELESS when we're together. Soooo the question is, how do you keep your hand from hurting on long rides when not using cruise? We rode 4 hours total the other day - which wasn't a problem, except toward the end I started having trouble with my hand getting tired. I was fidgeting a bit due to back issues too - but that's another story. I'm working that one out and have an idea how to fix that. But the hand - I'm at a loss. Any ideas?
    Very Active Member GunDoctor's Avatar
    Sep 2014
    Los Angeles
    There have been many threads here in the forum about options. I have seen some inexpensive lock down throttle clamps.
    Another Day To Be My Kid's Dad [emoji379]
    2015 F3-S. And Another Day To Be My Kids Dad
    Default Here's what I did..!!
    they call them cramp busters or palm cruise... helps a lot on the long roads... slips on the throttle under ten bucks...
    ​2012 RS sm5
    Feb 2012
    Spring City,Utah
    years ago before the "Fiddle Gummit" got involved motorcycles came with a throttle drag that you could set and with a light pressure hold the throttle at any position but you did have to consciously roll it closed.Now a days there are throttle locks which you can use to lock the throttle in position but unlock with a flip of your thumb.Throttle Meister also makes a lock that releases just by starting to close then once released it will act as a normal throttle.I have used a throttle lock with a cruise for years and been very happy with it. I set mine loose so just hold the position but when I let go or need to close the throttle it does so.
    Very Active Member garb55's Avatar
    Coolidge Arizona
    Tell your old man he had his chance and blew it
    You ride in front
    Now 2014 RT Limited Cognac
    Was 2008 GS SM5
    Don Garbarino
    Cup Holder
    GPS locking holder
    Mud flap
    Modified KNOTT grill
    Phone holder and charger
    Trailer hitch
    Dual air horn
    Auxiliary fuse box with relays
    Heated clothing controller
    volt/oil pressure gauge
    Sequential signals in mirror
    Tri Axis Handle bars
    Baja Ron anti sway bar/heim links
    shorty antenna
    And many more
    Vermont
    Quote Originally Posted by garb55 View Post
    You ride in front
    you got the 1330 Ace engine you got the power! Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Very Active Member spydaman60's Avatar
    May 2012
    sussex, nj and tug hill, ny (west turin)
    the best solution has been suggested, you take the lead and let him worry about his hand!!! ladies first!!!
    Dec 2014
    Lee's Summit, MO
    Tell Mr. I can't run at a constant speed, to get behind you and ride for awhile or forever.
    Very Active Member bruiser's Avatar
    Eastern North Carolina
    Try wiredux on the sponsor page. He has a cramp buster at a very good price. Both of us have them on our RTs.
    USAF '69-'89 E7
    Thailand/Vietnam 1972
    Invalid Emails
    Jul 2014
    NC
    Default LOL I'd let him ride behind... except
    Then I'd have to pay attention to make sure I don't lose him. Either way, I've got no where to go but.. well you get the idea.
    hubby has one of those cramp buster like things on his bike. I didn't know if they worked as well on the can-am, so I will be happy to try one. Thanks for the input.
    western Colorado
    Quote Originally Posted by TeresaR View Post
    If he Has a cramp buster he should have no problem keep a good steady speed! Just set a place you will stop ahead of time & ryde at your own place
    Active Member mclaw44's Avatar
    Aug 2009
    Ohio
    CRAMP BUSTER! Works great and cheap! This is the only way I ride my 2009 RS.
    Open up your Mind and let your Fantasies Unwind!
    Very Active Member retread's Avatar
    May 2008
    Bargersville, IN
    Every Cramp Buster I've had has gradually reached the point it slips. I now use a Throttle Rocker, it has been on for 2 years with no problem.
    john
    Very Active Member Dudley's Avatar
    Dec 2008
    Jacumba, CA
    With you having cruse control, explain to him the problems you are having and ask him to let you lead. If he still wants to lead...
    2008 GS SE5 in 2008
    Traded at 43,000 miles for a left over
    2010 RT SM5 in 2011
    Traded at 57,000 for a left over
    2014 RTS SE6 in 2015, which has 35,000 miles
    Oct 19th, 2017, totaled 2014 RT while killing a Javaline
    Dec 12th, 2017 drove a 2017 F3L home. What an awesome machine!
    Never had any breakdown stranded issues.
    Active Member aeroshots's Avatar
    Mar 2015
    NW Florida
    Default throttle technique
    Far be it for me to give a woman hand techniques, but here you go. If you are grabbing the throttle with your entire hand, i.e. fingers and thumb try a change of technique. Try sliding your hand back a little to where just your fingers and upper part of your palm is in contact with the throttle. In other words your thumb is barely touching it. If you are white knuckling it you can even induce back, shoulder, and neck pain. Relax your grip. JMHO
    Invalid Emails
    Jul 2014
    NC
    Quote Originally Posted by aeroshots View Post
    That fear you feel at giving women ideas... well, that's the special ops part of you talking. You know when you're in trouble. LOL Kidding. Seriously though, yes I do have the problem of holding on a bit tight, still. No matter how hard I try I still end up with the not quite white knuckling. With my left hand if I'm doing that I can relax and remove my hand and just stretch out. Harder to do on the throttle side. But I will definitely practice your idea and see if it helps. I don't really WANT to have to buy something to help with throttle when I have a freakin' cruise control, but unless I take the lead and then listen to hubby complain about my every move, the best bet is for me to stay in the rear. Yes, he's a control freak, but then that's what we AF people tend to be, right?
    TSgt, USAF Retired. Married to
    MSgt, USAF Retired
    Mar 2015
    Kansas
    Have him ride behind you.
    Dec 2013
    Default What about....
    setting your cruise control at a speed that's a little slower than his average speed, so that when you set & run on the cruise you'll slowly drop back; then every now and then without turning the cruise off, just add a little twist to the throttle & catch up again. All the time you are running only on the cruise, you can relax your hand, & you only need to twist tighter every now & then. That not only eases any cramps, but the on/off grip pattern exercises your hand and helps avoid them in the first place as well as strengthening your grip over time.
    Me, I have a prosthetic joint in my thumb/wrist on my right hand, so I use have the cruise on & use a cramp buster pretty much all the time just to make the spyder go - works brilliantly!!
    SoFlo
    I did not see it mentioned, but assume your husband is on two wheels.
    The recommendation to relax your grip is a huge bit of advice.
    Realize also, that as was mentioned to set the CC a bit slow and then catch up is solid info also.
    You might also try to use the CC speed increase / decrease by flicking the lever up or down will be good enough unless your partner is really up and down on the speeds.
    Simply relax the grip to idle, then use the CC switch to dial in or control speed changes. Ensure though that you wind the grip back up a bit before disengaging the CC.
    Some other considerations, ensure the mechanics of your RTs are good. Simple things like front end alignment, front wheel balance, seating position, or anything else that may be having you hanging on too tight.
    All the best.
    PK
    May 2015
    North Augusta, SC
    I use the cramp buster. It works great. The cost was less than $10
    Invalid Emails
    Oct 2013
    Dardenne Prairie, MO
    There are "wrist savers", $10 +/-. Not throttle lock but eases the strain on the wrist by using your palm.
    2014 RTSS , Cogna/ black
    Jun 2014
    ny
    what you need to do is find a place you can put your hands while riding behind him that neither of you will mind
    You need to have a talk with him about his riding habits...
    Either that; or have him ride on your passenger seat!
    Very Active Member OverHillAndDale's Avatar
    Sep 2014
    United States
    If you are acquiescing and staying in the back consider this. I have a thumb problem and if I hold a throttle too long my thumb loses all feeling except pain, and the skinny grips on the Spyders don't help.
    I got the Kuryakyn clamshell grips that go OVER the existing grips. They're very fat and allow me to grab the grips "mitten" style with my thumb on top of the grip.
    2020- RT Limited
    Chalk White, Can-Am rear passenger armrests, Comfort Seat, Grip puppies, RAM Cup Holders, Providence RAM Mount
    FOBO2 TPMS
    Aluma MCTXL trailer
    BRP hitch
    Big Bike Parts wiring harness
    Permanent Smile!!!
    Central Oklahoma
    Default was going to recommend that.
    Yep. some of my Harley friends use those. very inexpensive on Amazon.
    2020 RT Limited , Petrol Metallic Dark
