F3-S Lateral Service Cover alignment
Question. In the owners manual, they make it looks as-if the lateral covers (L & R) would almost be a flush mount
when secured. I see no way for that to happen considering where the twist-lock and mounting tabs are. Both somewhat
fixed postion. (Am I seeing this wrong?) The covers are above the other material when locked in.
One for the F3 guys...
If the panels are buttoned down securely you should be fine. Sounds like outside of moving the mounts not much can be done. The F3 guys will know more about it than I do...
2012 RS sm5
It would help to know . . . .
. . . . what page are you looking at?
Tom
2008 GS SE5 -> 2013 STS SE5 -> 2015 F3-S SE6 . . . Still riding & smiling.
Tom
Pages 28 & 29. If you look at their pic, the panel would lay flat with a small
"space" between the panel and body. Or, basically lay flat and flush. (And I can see
no way that is even possible considering where the twist latch would go.
(Just picked her up yesterday, and, love it BTW. Red-Orangish F-3S SE6 with the BlueRidge
windscreen, mid-back passenger rest, and passenger floorboard).
Congratulations on getting your F3!
Originally Posted by kaamacat
Pages 28 & 29. If you look at their pic, the panel would lay flat with a small "space" between the panel and body. Or, basically lay flat and flush. (And I can see
Your original assessment was right, the panel is not flush-fitting. The illustration does not highlight the bevel on that end of the panel ( where the latch is ) very well.
Tom
Tom
So looks like the book is not accurate. (Or better put, yours is like mine?)
2015 F3-S SE6 (Rorange)w/BlueRidge windscreen, +2 UFIT, pass backrest, pass floorboard, CrossCountry Saddlebags, BajaRon sway w/links, BANDC 12v under seat, BANDC USB left of key plug, GripPups, x-Creen Sport, 2-Up Rear
2008->
Victory Vision Tour Premium
Ducati 900 SS Full-Fairing
BMW F650GS
Pre-1979
Suzuki GS1000-E (1st Tri-State Area)
Suzuki GS750
Suzuki RM125
Suzuki GT550 (3Cyl 2-stroke Street)
Honda CL175
Honda SL125
Honda Trail 70 (1st year of hand clutch model)
Honda Mini-Trail 50
Yes . . .
. . . putting it better, mine is like yours - the manual is not inaccurate, it is difficult to show where the tabs go uner the body panels, where the cover goes over the panel and where it meshes with the cowling.
Easy once you you have done it, difficult to describe & illustrate.
Tom
Tom
Operator error on my part..... OK..... when I fit the panel on more from the rear 1st then align
forward sliding the tabs in LAST, that panel will fit flush with the cowl wrap-around section, and
it is just a tad offset. But it now is riding on the 1/8" ridge from the cowl panel. (if that makes sense).
So net-net is, I was placing the tabs up and in 1st, then lowering the panel, which then made it
sit on top of the unit. (Live and learn).....Sorry for any confusion entered here on my part.
2008->
BMW F650GS
Pre-1979
Suzuki GS750
Suzuki RM125
Honda CL175
Honda SL125
Honda Mini-Trail 50
No problem . . . .
Operator error on my part..... OK So net-net is, I was placing the tabs up and in 1st, then lowering the panel, which then made it
. . . . I am used to being confused. You should have seen me changing the wiper blades on my Chevy SSR yesterday ( for the first time ). ONLY after an hour of struggling, I suddenly figured it out and what I was doing wrong and was done with both of them 1 minute later.
I had the same problem with the panel when I took one out for a demo ride - so did the sales-guys. And we all "know" Spyders. As you say, live and learn.
Tom
Allignment
So....are you saying you got the covers to sit flat and not sitting up on the other part of the plastic ?
Correct. When I got mine (probably from removal...etc) it was sitting on-top, which had me
thinking why would they allow the panel to (at some point) damage the lower piece from vibration.
But yes, the panel will lay flat so you'd see a "channel" between the 10pm position on the panel and
the upper cowling part that comes down and around.
Check out those pages in the book I mentioned in a previous post and they show the checkmark=good
and X=bad pics.
Every time (well in my 24hrs of ownership) if I place the panel with tabs in first, then lower the panel,
it rides on-top of the other bodywork. If I go "low" and then the tabs last....sort of....it works.
2008->
BMW F650GS
Pre-1979
Suzuki GS750
Suzuki RM125
Honda CL175
Honda SL125
Honda Mini-Trail 50
Allignment
Wow thanks,I'll try it tomorrow.i could never figure out why that would not lay flat,it just didn't make sense it would sit on top and vibrate and scratch.
thanks again,
Gene T
Allignment
Well you were right ,it fits like it should once you get down and look at it and slid the cover in,thank you so much for your input.
Gene
I am a little happy
I did mine BEFORE I read this thread (LOL).
Doug Barnes
James 4:17
all on two wheels. More on four or more. Guess I may need to start multi-coloring for three wheels.
