Reservoir Coolant Level
With engine cold and parked on level survace should I fill the coolant reservoir to the MAX level mark on reservoir tank?
Jim
coolant
Jim
Jim fill no higher than half way between Min and Max...If you fill to Max as engine heats up it will blow out excess thru overflow...
Freebob....
Depends..!
I run it just below the max mark. Never had a problem and do ryde a lot of hot weather. Temp usually 5 bars or below. Prefer to spit a bit out than run out...
Gene and Ilana De Laney
Mt. Helix, California
2012 RS sm5
It's not overly critical. As long as there is coolant in the reservoir your fine. To much coolant and it will "self adjust"....lol
