Page 1 of 2 12 LastLast
Results 1 to 25 of 29
    Very Active Member Deer Slayer's Avatar
    Mar 2015
    Advance, NC
    Default front tyre pressure?
    I know this is like herding cats! My RS-S calls for 15 lbs front. My dealer put 22 and says tyre wear will be better. I did not like the way the front bounced about on mountain roads. So let me know what u run and where u ride. If you use nitrogen let me know as I have it on hand. Thanks in advance from Advance.
    If I can't fix it, I will fix it so no one can fix it. Sypder Loco!
    Linden, CA
    Default AIR
    I have tried everything from 8 lbs to 30 lbs for me I find that 18 seems best
    Ride Safe
    Dave
    Very Active Member Pennyrick's Avatar
    Feb 2011
    Loganville, ga
    Quote Originally Posted by Deer Slayer View Post
    Since front tire wear doesn't appear to be a major problem on Spyders I would ignore the dealer and go slightly over the manufacturer's recommendation at 17-18 psi. I think 22 is too high. That would be 47% higher than the factory recommends which leads me to believe whoever told you this doesn't know &&^%#%&( about Spyders.
    Penny and Rick have owned many motorcycles starting in 1974 with Honda’s, then to Suzukis, Gold Wings and ultimately Spyders.
    ‘74 Honda 360T (pair); ‘78 Suzuki GS 1000 (pair); ‘’82 Honda Aspencade; ‘84 Honda 400; ‘87 Yamaha 1100; ‘99 Honda Valkyrie; ‘01 Suzuki Burgman(triked); ‘02 Honda GL 1800(triked); ‘10 Spyder RTSE; ‘11 Spyder RTSM; ‘12 Spyder RTSL (pair); ‘20 Spyder RTL (current)
    Very Active Member Vader's Avatar
    Jul 2014
    Hudson Valley
    Default My 2 cents
    Just today, I checked the tyres on my 2008 GS..I raised the pressure to 18 psi in the frints, and 30 in the back..and used my Slime brand compact air compressor which worked perfectly. .
    IT IS, WHAT IT IS...
    Dec 2014
    Garland, Tx (near Dallas)
    I don't now if there is a difference in pressure in the RS, but for my 2014 RT I run with 20 in the front and 28 in the rear. I'm not sure if that's best, but it made sense to me.
    Oct 2013
    rome new york
    Ride Safe
    Dave
    I agree !!!!
    Active Member dginoregon's Avatar
    Sep 2013
    Grants Pass, Oregon
    I run 16.5 in the front and 28 in the back, regular air on my 2013 st L. I ride everywhere, mt. roads to city streets to hiway most every day.
    2013 ST L , Black Current
    Invalid Emails
    Mar 2011
    Hudsonville, MI
    Ran mine at 18. 22 made mine edgy!
    Very Active Member PistonBlown's Avatar
    Jan 2013
    Christchurch, New Zealand
    18 here as well - my goodness it's almost a consensus:-)
    Those bikes with 14" front tires seem to like pressures in the 17 to 19 psi range.
    The 15" front tires like a little bit more (20 to 21 psi), due to the shorter sidewalls...
    You DON'T want to catch a really bad bump, and run out of sidewall to soak it up!
    Bryant, Arkansas
    Ride Safe
    Dave
    Cruzr Joe
    Bryant, Arkansas
    21 starts to get bouncy for me, i really am comfortable with 18 - 19
    Cruzr Joe
    Aug 2012
    CO
    18/28 on our 2008 RS
    Sent from my SAMSUNG-SGH-I747 using Xparent Skyblue Tapatalk 2
    JLohPhotos
    2008 GS , Millennium Yellow
    Default Depends..!
    I have narrowed it down to 17 lbs. This gives me some lean, kills the bounce and keeps the steering light. But I do ryde an RS with Kenda tires. This will vary when on an RT, ST, F3 or RSS and who's ryding and what your carrying. Not to mention weather, type of tire and road conditions... thats why we each have to find our own best pressure...
    ​2012 RS sm5
    Very Active Member kep-up's Avatar
    Nov 2014
    Mountville, PA
    Quote Originally Posted by dginoregon View Post
    Good lookin' Aussie in the pic, BTW.
    Cruzr Joe
    I tend to run 21 psi up front until the potholes all get filled-in. Then; it's back to 20...
    And that single PSI difference is pretty noticeable!
    Jun 2014
    ny
    At most i would run 2 psi up & i run nitrogen
    Nov 2012
    North Las Vegas, NV
    2012 Rt here I run 20 psi front and 28 psi rear. Front tires are 185/60/14s.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Quote Originally Posted by SPECTACUALR SPIDERMAN View Post
    Well; the ride ought to be plenty cushy...
    I run 18 in the fronts and 28 in the rear tires.
    Sep 2013
    Mill Creek, WA
    Good point, it DOES matter whether you have 14" or 15" wheels so we should each specify, though the reader can probably tell if the year of the Spyder is mentioned.
    On our '14 ST-S I've found 20-22 lbs feels best for the fronts, and 28 in the rear. I prefer a bit more responsive steering, and don't like it to roll on the outside edge of the front tires when cornering hard.
    2019 Spyder F3-T, white
    Nov 2013
    Oro Valley Arizona
    2014 RT Limited--20 # in the front and 30 # in the rear with 15 inch tires. Works great for me.
    Running much lower pressure will cup your tires and increase wear. Besides they are easy numbers to remember.
    Jack
    2015 BMW R1200R LC
    2014 RTL SE6 Pearl White
    2012 RT-622 trailer viper red
    2011 Polaris Ranger green
    2016 Can Am Maverick
    Very Active Member coz's Avatar
    May 2011
    cincinnati, ohio
    Default Gs
    19 in the fronts. Plain old air.
    it was fun while it lasted.
    Plain old air?
    I use nitrogen... the cheep stuff; that's only about 78% pure!
    Mar 2015
    Advance, NC
    Thanks for all the inputs. I settled for 16 nitrogen in the fronts and 28 in the rear. I did 225 miles on the gap twisties near mm 220 PRP in VA today. My RS-S takes the curves like rails. I have been riding the same roads for years. I am happy I did not get the F3 with its forward controls. The RS-S was purpose bought to carve up curves. Only drawback in the Cheep ass BRP tyres. At 3000 miles the wear is evident. Again thanks to all.
