View Poll Results: What is your downshifting method when approaching a stop sign at highway speeds?
- Voters
- 110. You may not vote on this poll
I use the engine to help slow the bike and downshift actively
I coast and let the nanny do some shifting as needed otherwise use the brakes?
I do option 1 if I remember otherwise option 2.
Why do I need to downshift
Downshifting when approaching a stop sign with the V-Twin 990/998
V-TWIN Motors only please (ALL RS/GS models, ST models and pre-1330 RT's).
What is the proper method for downshifting with the SE transmission when approaching a stop sign on the highway? Are you guys actively clicking through the gears on the way back down using the motor to help slow you and keeping the RPM's up or are you coasting and then clicking through the gears quickly as you slowly roll to a stop?
2017 Chevrolet Camaro SS convertible. 2017 GMC Sierra cc diesel. 2017 Arctic cat RR 137 ES
I just let it downshift by itself on my 2012 & 2013.
Cruzr Joe
I used to just about split the chores between my fingers, and the computer with the 2010 RT...
But on the new 1330; they've really improved the programming, and it just a great job all by itself!
I can't vote. I have a manual.
USAF '69-'89 E7
Thailand/Vietnam 1972
I usually down-shift manually instead of letting the Spyder down-shift. I just like to be in the right gear in case I have to move in an emergency. I think either way is ok.
Tony
2017 Red F3T
Mods
Lamonster RIP Floorboards
Lamonster H4 LED headlights
Lamonster LED Fog Lights
Lamonster LED White and Amber Fog Ring
Lamonster Show Chrome Fender kit
Lamonster Drink holder
Lamonster Dual Power Plate with large X-Grip
Lamonster F3 Driver Back Rest
Lamonster Lid Lock
Baker Air Wings Luggage Rack
What is "proper" can be added to the debates of what oil to use.
But coming from and also having a two wheeler, I like using the engine breaking to slow me down when approaching a stop, plus having the added plus of already being in a lower gear if the light changes or I got to get out of the way in a hurry.
When I had the 2013 stl, I did the downshifting.
with the rts, I still do the downshifting.
i like the engine braking.
this posting has been vetted, scrubbed and endorsed by the committee for postings
Tony
Me too
2015 RTS Special Series
Russell Day Long seat
F4 Customs windshield
Sena 20s
Yes
by that I mean I do both depending on the situation/my mood.
Ed
They told me not to give up on my dreams, so I went back to sleep.
Champagne 2017 RTS SE6
Quantum Blue 2012 RTS-SE5 "Bluebell, Bell for short" - Traded 09/2017
When the RPM drops to about 4,000 I down shift.
2018 F3 LIMITED
If you put the RT into trailer mode, the bike will do the downshifting for you. Just below 4000 each gear.
If I come up to a stop sign or exit off the freeway I downshift manually to help bleed speed off fast. If I try to down shift from too high of speed it will not shift until it is safe to do so, so no worries about overreving. I ride the chuchanut, a beatiful but very winding road with lots of blind corners and rocks on the road. I love to push the limit down the straights then use the gears and breaks to reduce speed in the corners, then back hard on the throttle and run through the gears.
I always downshift. As said before just like to be in the correct gear. You never know when you need to quickly accelerate.
2016 Spyder F3 Limited Steel Black Metallic
Lamonster approved LED Headlights
Lamonsters LED Fog lights
BRP Driver & Passenger backrest
BRP Trailer Hitch
Shamrock Black & Polished
Signature light
Elka front shock's
Rolo Laser Alignment
Dual Power outlets
Garmin 590 GPS
Using the engine to downshift puts excessive wear and tear on the engine, brake pads are a lot less expensive. Let nanny do her job.
2021 Sea to Sky, 2013 RT Ltd, 2005 Bombardier Outlander ATV
Personally know i have bad habit rarely down shift unless bad traffic. But mostly because in town im always a gear lower 2 or 3 max anything under 60mph to keep rpm up. Hard to train myself for the difference from old bike. (Americanized shifting)
2013 STL SE5 BLACK CURRANT
SpyderPop's: LED bumpskid
minispyder dash toy
Lid lox
KradelLock
Pakitrack
FLO (Frunk Lid Organizer)
BRP fog lights, trailer hitch
SENA 20S EVO
Depends on how lazy I feel that particular day. When carving corners, I manually downshift so as to power through the corner.
Also, I have for 50 years of riding motorcycles been a firm believer that the engine is used to make the machine go. The brakes are put there to make the machine stop.
The RT SE will downshift automatically when it is not in trailer mode as well. It kicks down at approximately 2,250 rpm when not in that mode and when in trailer mode it holds until about 3,200 rpm.
Penny and Rick have owned many motorcycles starting in 1974 with Hondas, then to Suzukis, Gold Wings and ultimately Spyders.
74 Honda 360T (pair); 78 Suzuki GS 1000 (pair); 82 Honda Aspencade; 84 Honda 400; 87 Yamaha 1100; 99 Honda Valkyrie; 01 Suzuki Burgman(triked); 02 Honda GL 1800(triked); 10 Spyder RTSE; 11 Spyder RTSM; 12 Spyder RTSL (pair); 20 Spyder RTL (current)
Manually downshift to make sure the machine is in its optimal configuration at any time in case I need to move or stop in a hurry.
SL #7026
VBA #652
HOG #3935417
2011 Viper-Red Spyder RT SE5 & Trailer
2017 HD Ultra Limited
Former Rides: 2014 HD Ultra Limited; '04 Kawa Nomad; '09 HD Ultra-Classic; and many Hondas through the years.
Spyder Newbies Do's & Do Not's: http://www.spyderlovers.com/forums/s...-Spyder-owners
I downshift myself the same as if I was on a bike with a manual.
Phil
I may be old, but I got to see all the cool bands.
2011 Spyder RT-AC
Originally Posted by Double Trouble
The RT SE will downshift automatically when it is not in trailer mode as well. It kicks down at approximately 3,750 rpm when not in that mode and when in trailer mode it holds until about 4,200 rpm.
I did not respond to this right away because I wanted to observe the conditions again first hand to make sure I was remembering correctly. But, mine does not work as you describe. With trailer mode off, RPMs drop down to about 2500 before the downshift occurs automatically. With the trailer mode on (where we always keep ours). It downshifts when rpms drop to about 38 or 3900 rpm.
If I am carving corners or mountain riding I will force a downshift sooner rather than ride the brakes. Otherwise we leave them in trailer mode and let nanny downshift on our behalf.
You are right. I corrected my earlier post. Fat fingers on the keys I guess.
I always let my Spyder downshift by itself. But might try to downshift to see which one I prefer
I honestly wish that I could switch my spyder between fully automatic mode and toggle shift. It'd be nice just to twist the throttle and go without worrying about shifting at all.
