Page 1 of 2 12 LastLast
Results 1 to 25 of 39
    Apr 2015
    Default Has anyone experience a "DEATH WOBBLE" in the rain?
    [COLOR=rgba(0, 0, 0, 0.701961)]On a trip through Arkansas I experienced what I term "DEATH WOBBLE". I was cruising at highway speed with the cruise control on when it was raining. I came upon a slight incline when the rear end started whipping left and right several times. It happened so fast that I could not offer any counter steer at all. I was nearly thrown off my Spyder F3-S! By the grace of God the F3-S cruise control disengaged and the bike recovered itself. This happened a second time a few hours later at slower speed and not as violently. I also had a few incidences where I could feel the back tire loose traction without the cruise control on in the same rain storm. However after that first "DEATH WOBBLE" experience I became keenly aware of the onset of the Spyder F3's weakness in the rain.[/COLOR][COLOR=rgba(0, 0, 0, 0.701961)]
    [/COLOR]
    Very Active Member hawkiii's Avatar
    Apr 2008
    Northern California
    Default Cruise control in rain
    You might try an Internet search for 'cruise control in rain'. Not a good idea in your cage or on your Spyder. IMHO.
    Very Happy Spyder Guy
    The 2015 F3 has over 46,000 miles
    Have Spyder...Will Travel
    Invalid Emails
    Aug 2010
    Guelph,Ontario,Canada
    I never use cruise control in the rain. I feel that I have more control over the spyder If I accelerate and not the cruise control.
    I was in a very violent rain storm once and the spyder hydroplaned a little before I could safely pullover. Not a great feeling and the Nanny did her job.
    Default Scary..!!
    All of the above when ryding in the rain. The F3 has great torque and if you hit a oil slick the cruise will compensate as the wheel breaks loose. This is easy to do if you ryde in the center of the lane where oil and debris tend to collect (rain makes it slick). Even without cruise this will happen but you can better handle it. Keep your traction wheel on the clean surface...
    ​2012 RS sm5
    Registered Users Tom in NM's Avatar
    Apr 2009
    New Mexico
    Default Sounds extreme . . . .
    . . . . . No, I have not experienced anything like what you describe. But, I don't use cruise control in slippery conditions - rain, ice/snow or sand/gravel. I've had the F3 in all these conditions multiple times.
    Sometimes on sharp corners at 25 mph+, the rear wheel will 'drift' as I increase speed ( gun it ) and there is oil on the road surface. But, this is nothing like the wobble you describe.
    Tom
    2008 GS SE5 -> 2013 STS SE5 -> 2015 F3-S SE6 . . . Still riding & smiling.
    Riding in the rain seems to be a good clue here. My owners manual states that the is prone to hydroplaning in rain.
    Riding at 50 mph + through water will cause the to hydroplane. Have had it happen to me twice. Nanny actually kicked in to help me regain control.
    Add the cruise control and you have an even more dangerous situation.
    That wasn't a Death Wobble; that was just what hydroplaning looks and feels like...
    Jun 2014
    People's Republic of NY
    A rule to live by "no cruise controll in the wet" 2,3 or 4 or more wheels.
    committee for postings
    Very Active Member CanAmChris's Avatar
    Feb 2011
    Near Philly, PA - USA
    Default Never
    Never, never, never ever use cruise control in slippery conditions. Ever. Cruise control is a simple computer program that will adjust the throttle to maintain a constant speed. If the drive wheel breaks loose, the program will do what ever it's limited programming tells it to do to keep the speed constant.
    So... You have your cruise control set at 50mph. You hit a rain or ice spot. The drive tire breaks loose. Your forward speed drops and the cruise control does what it is programmed to do... Speed up to get back to 50 MPH. Bad things can and will happen when you give more throttle to a drifting drive tire.
    You are lucky. Please do not use cruise control in the rain. We like you, and want you to be around for many more rides and posts on the forum.
    Nov 2012
    North Las Vegas, NV
    Don't forget they (BRP) backed down the nanny so you could get a little more "fun" out of the F3. Ride accordingly.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Invalid Emails
    Mar 2011
    Hudsonville, MI
    That is my thought too. Unfortunately I get caught in rain way too much.
    MOgang Member Yazz's Avatar
    Nov 2009
    Cypress, Texas
    +50 for not using cruise control in the rain.
    What happened to you was "fish tailing." Back wheel wagging back and forth.
    It happened to me on the F3 a couple of times riding in the rain. Wasn't using cruise control, but making right angle turns at two-lane intersections. Slow sharp turns in the rain, back wheel slides to the outside of the curve. Kept the front wheels pointed where I wanted to go and Nanny very gently, without bruising my ego for drifting, got the rear wheel back in line.
    Nanny is toned down on the F3.
    Joy
    Very Happy Ryder...
    '09 Phantom and a '15 F3-S
    If you don't slow down, they can't catch you..
    ​If you don't give up, they can't win.
    What a long strange journey its been.
    Feb 2011
    [QUOTE=Yazz;966307...Kept the front wheels pointed where I wanted to go and Nanny very gently, without bruising my ego for drifting, got the rear wheel back in line.
    Nanny is toned down on the F3. [/QUOTE]
    Yes... this. Thank you Yazz
    Very Active Member Rogue Hawk's Avatar
    Apr 2015
    Chicago
    Sounds like hydroplaning.
    2019 Rally , Black
    Aug 2007
    Springfield, MO
    Quote Originally Posted by Rogue Hawk View Post
    Registered Users Robertsepolen's Avatar
    May 2012
    Milton-freewater, Oregon
    Been there. Done that. Bike did what it was supposed to do. You and I did not. Turn off cruise control on bike or in cage when roads are wet.
    2015 RT-S
    2015 SE6 RT-S
    Black/Red Special Edition.
    Aug 2008
    Maryland
    I haven't ridden my F3 yet in rain, but I found my 08' GS to be excellent in the rain - of course to much water can cause hydroplaning. I tend to ride slower, takes turns slower and definitely easy on the brakes.
    2020 RT Ride Frequent Stay Safe
    Aftermarket Aux Light, GPS mounting/wiring, Lamonster Garage Mirror Lock, Lamonster Garage Belt Tensioner
    Backrest Home Brew Mod
    2008 RS from 2008 through 4/2015, 2015 F3-S from 4/2015 through 9/2020
    May 2012
    The plus side is if you are tired this will surely wake you up!
    2015 RT-S
    2015 SE6 RT-S
    Active Member Mike Ard's Avatar
    Apr 2015
    Boise Idaho
    Owners manual for any vehicle that has cruise will state that it should not be used in rainy or slippery conditions for the reasons that many have stated above.
    Very Active Member grumpybob's Avatar
    Nov 2009
    Fulton NY
    Quote Originally Posted by vided View Post
    Totally agree no matter what vehicle you are operating. SNOW ALSO DON'T USE CRUISE.
    Very Active Member ABQSpyder's Avatar
    Jun 2013
    Green Valley AZ.
    Dilling
    Hasn't reappeared to read comments or Thank everybody for there input!
    Quote Originally Posted by ABQSpyder View Post
    Dilling
    Let's not call it that yet. It does fit a particular pattern though. First post, interesting subject...
    We have been surprised many times in the past, and they did have a real issue or question of concern...here...
    He may even have stopped by for a peek, and not signed in...
    Mar 2012
    NJ
    That's not even close to what death wobble really is. More common in lifted vehicles, Death wobble, when you truly have it feels like it's going to shake your vehicle apart and it doesn't stop until you get your vehicle at almost a complete standstill. There is no controlling it or stopping it once it starts.
    You can simulate it somewhat on a skateboard going down a hill with loose trucks. The death wobble stops when you stop.....or crash.
    Apr 2015
    Thank you all for your input! I am currently on the road riding my Spyder F3-S visiting both friends and family... especially my grandkids! I traded in my 2008 Spyder GS for the F3-S and was concerned because my GS was awesome in the rain, however it did not have cruise control. I have experienced hydroplaning before in a car but my Spyder incident left me thinking that there might be something wrong with my bike... but it does make sense what you folks are telling me! I love my new Spyder F3-S but in the rain I sure do miss my GS!
