Page 1 of 2 12 LastLast
Results 1 to 25 of 31
    Very Active Member bmwlarry's Avatar
    Mar 2012
    Beaverton, Oregon
    Default Terrible front end shimmy …….
    My 2011 RT has developed a terrible front end shimmy from 41 mph thru 49 mph.
    What could be causing it?
    Laser alignment done
    all front end suspension components tight and good
    tires have ride-on sealant/balancer installed (two years ago - does it go bad)
    BajaRon sway bar
    Shock relocators
    Tires correct air pressure (18)
    Tire wear even
    2015 an Am Spyder RT Limited
    2013 Yamaha WR250R - Sold
    2011 Can Am Spyder RT-S SE5 Limited - Sold
    2011 Aspen Sentry Trailer
    2003 BMW K1200LT - Sold
    2007 Unigo Trailer - Sold
    2001 BMW K1200LT - Sold
    2001 Honda 750 NightHawk - sold
    2015 RT Ltd , Canamspyderaccessories Brake pedal ext. Red
    Could a separated belt make it shimmy like that?
    Can you jack up the front end of the bike, and spin the tires? Check to make sure that they are still actually round...
    Good Luck!
    Active Member kyspyder's Avatar
    Aug 2007
    Shelbyville, KY
    Default Terrible Front end shimmy
    What brand of tires are on the front end?
    If they are the stock tires I would recommend starting there.
    I had exact same condition, as have many others, and new tires fixed the problem.
    kyspyder
    Invalid Emails
    Oct 2013
    Dardenne Prairie, MO
    I have heard that Ride On tends to settle when the bike sits for a while and takes a while to get redistributed when you start riding again. It is worse when the weathers is still cool.
    2014 RTSS , Cogna/ black
    Very Active Member SPYD3R's Avatar
    Apr 2011
    GREENVILLE, SC
    Default BALANCE WEIGHT
    DID YOU THROW A BALANCE WEIGHT OR TWO OFF THOSE WHEELS....????
    just say'n...
    Dan P
    SPYD3R F3-S
    Very Active Member garb55's Avatar
    Coolidge Arizona
    Quote Originally Posted by joebryanjr View Post
    I have Ride On in my tires and they take about a mile to settle down if its been sitting for awhile
    When it is really cold it takes a lot longer
    But I have found the solution to the problem
    Don't let it sit
    Now 2014 RT Limited Cognac
    Was 2008 GS SM5
    Don Garbarino
    Cup Holder
    GPS locking holder
    Mud flap
    Modified KNOTT grill
    Phone holder and charger
    Trailer hitch
    Dual air horn
    Auxiliary fuse box with relays
    Heated clothing controller
    volt/oil pressure gauge
    Sequential signals in mirror
    Tri Axis Handle bars
    Baja Ron anti sway bar/heim links
    shorty antenna
    And many more
    Aug 2007
    Greeneville, TN
    As mentioned. If the Spyder has been sitting for an extended period you may need to ride a few miles at 30/40 mph to get the Ride-On to distribute. But it should happen fairly quickly.
    Are you sure your A-Arm bushings are good? If they are worn they can give you this effect.
    Separated tire belt would definitely give you this problem.
    Bad tie rod ends (there are 4 of them) will do this.
    Loose lug nuts?
    Let us know what you find.
    Very Active Member Grandpot's Avatar
    Oct 2014
    Fort Mill, SC
    Default Balancing
    Take a look at this thread, it may help. http://www.spyderlovers.com/forums/s...227#post925227
    2011 RTS (Sold to a very nice lady)
    1998 Honda Valkyrie
    2006 Mustang GT. Varooooom!
    US Navy Veteran
    SC Law Enforcement Boat Captain
    CNC Machine Service Technician
    President: Rolling Thunder SC1
    Member: Disabled American Veterans, Rock Hill, SC
    Member: American Legion
    Experience is recognizing the same mistake every time you make it!
    Registered Users Deke's Avatar
    Jan 2013
    Marion, IA
    My 2012 RT would get a crazy shimmy as you describe at the same speed. It wasn't all the time, but when it happened it was crazy scary.
    I took it to Spyderfest last year, and it turned out it was worn out A-Arm bushings. Len's team replaced the bushings and I never had the problem again.
    Deke
    +Peace,
    Deke
    2105 RT-S SE5 Special Series (current)
    2012 RT A&C SE5 (previous)
    Mar 2012
    Beaverton, Oregon
    I will have the A Arm bushings checked!
    Ride on is not the problem. I went on a 250+ mile ride yesterday and it happened all day.
    It has stock tires on it. I will check tomorrow and see if on is out of round.
    The tires have rideon in them and yes, on has a lot of weight on it. It however, has always rode smooth with the weights. How could that change?
    Tie rod ends are tight.
    Lug nuts are tight.
    Mar 2012
    Beaverton, Oregon
    Quote Originally Posted by Deke View Post
    Deke
    How do you test the A Arms?
    If you leave the parking brake off, and just grab a tire...
    Try to roll the bike back and forth by rolling the tire fore and aft...
    If there's any movement in the system; you'll se it!
    Very Active Member warp10's Avatar
    red oak, tx
    I had the same problem on a 2012. I had the dealership swap out the tire and rims with another bike, no shimmy. So I replaced the both front tires, problem gone. I think a belt shifted in one of the tires.
    2014 RT Limited Cognac ----- Wraps, skid plate, lights, Elkas
    2002 harley ultra classic
    2008 hayabusa
    Very Active Member Orange Spyder Man's Avatar
    Sep 2014
    3rd ROCK FROM THE SUN !
    my guess its the OEM tires... they are junk...
    osm
    Aug 2007
    Greeneville, TN
    And you can feel it also.
    Nov 2012
    North Las Vegas, NV
    Had my original front tires start the 45 mph shake at 14,000 miles. New General Altimax
    front tires fixed mine.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Very Active Member MikeinGA's Avatar
    Jul 2011
    Mount Airy,Ga.
    Quote Originally Posted by SPYD3R View Post
    just say'n...
    Dan P
    SPYD3R F3-S
    OR all the wheel weights have fallen off, I know how that feels.
    Mike
    Mar 2015
    forrest above Reno, Nv
    Default Mine also
    My 2014 RT-S was delivered to me and it also had a "shimmy" at about 50 mph. With less than 80 miles on the brand new vehical I returned to the stealership and they replaced both the tries and rims. They said the "tires were not round" The shimmy was gone but the handeling seemed "sloppy" i checked the air pressure only to fine 12 PSI in the front tires. Check the air pressure no matter what ( in fact I'm going out to the garage {no --- I don't keep the in the living room} and check the pressure right now).
    Kaos
    2014 RTS , Circuit Yellow
    Mar 2012
    Beaverton, Oregon
    so I have checked everything. the tires are out of round upo to 3 mm in one and 2 mm on the other..
    What next
    Active Member NorCalBud's Avatar
    Feb 2013
    Northern California
    Default This is happening to to my 12 RTL too...
    This "Shimmy" has just started to occur on my 12 RTL in the past few weeks. We just turned 12k miles on the original Kenda tires, but put on over 1000 in the last month. It only happens around 43mph and the front end begins to wobble side to side very quickly. It goes away if I speed up or slow down. I'm not feeling/seeing any bushing effects and don't have anything in the tires. I do have 17 weights on the right wheel and only 6 on the left. None seem to have been thrown.
    I've got to get my 12k maintenance so I'll have the dealer check it out.... Just strange (and good)that I find this thread right after it started...
    I'll let you know what is found.
    ~'12 RT Limited, Pearl White~
    BajaRon Anti-sway Bar
    Squared Away Laser Alignment
    Custom Dynamics HMT Brake Light, Front Fender Tips & Kit, Front Mud Flap LEDs, Amber & Red Brightsides, Tri-color Magicflex Channelz
    Lidlox Grip Tip Helmet Locks
    TricLED Mirror Signals, RGB Multi-color Halo Underground Effects Kit, LED Headlights
    Palmer Signs Custom "Captain America" frunk graphics
    Twisted Chrome Pinstripes
    Overland Australian Sheepskin Seat Cover
    Feb 2013
    UK
    Exclamation
    Quote Originally Posted by NorCalBud View Post
    Good grief!! 17 weights on one wheel!!! What was the guy who balanced the wheels thinking??!!
    The least I would expect is him to do is to remove the tire and check it for centricity and try another tire.
    Aug 2007
    Greeneville, TN
    6 weights are at the upper end of what I would consider 'Reasonable' or maybe more like tolerable. 17 is in the insane range. Something is very wrong for a wheel to need that much weight.
    Mar 2012
    Beaverton, Oregon
    Well, I fixed it!! I bought a 2015 RT LTD!. Really, I did, but it turned out to be the top shock bolt was loose!
    Feb 2013
    Northern California
    While I don't disagree with you one bit, that does seem crazy, I don't really think that is the direct problem. I've been using these tires like that for 2 years and only started feeling the "shimmy" for a few weeks. Unfortunately I never even noticed the amount of weights until just now.
    I also had the DPS/Limp Mode alert this past weekend while on a ryde. I've never had any alarm before. I pulled over and shut the tryke down. I pulled out the manual and checked what the alarm was about, I started it up and it was gone. I checked for active fault codes, but that was blank. I rode several hundred miles this weekend without that occurring again. Perhaps I was riding the break, but I'm usually pretty careful about that. But I can't say for sure.
    Coincidence...I hope so!
    Registered Users elkk's Avatar
    Feb 2015
    United States
    Default Check the Front Drive Sprocket
    I just went through this with a friends 2008 RS and found the front drive sprocket was loose causing front-end shimmy between 20 and 30 mph. The whole bike shook at certain speeds. Hopefully not your problem but certainly worth checking to be sure it is tight. Just Saying....
    2005 Suzuki Burgman 650AN
    2008 Can Am Spyder RS SM5
    2014 Mustang GT
