Page 1 of 2 12 LastLast
Results 1 to 25 of 27
    Apr 2015
    Corinth, TX
    Default Neoprene Motorcycle Grips vs Foam Grips
    Has anyone used these Neoprene Motorcycle Grips? They look like they'd work well.
    http://pirateslair.net/Gripbuddies.htm
    I've used them in the past; but not on my Spyders.
    They're much more durable, than foam grips!
    Jun 2010
    Memphis, TN
    I have used grip buddies for years and love them. The new ones have been comfortable and durable
    Invalid Emails
    Feb 2013
    Castle Rock, Co.
    Quote Originally Posted by IVSSpyder View Post
    Look cool I have the foam covers and they are breaking down looks like a good option jtpollock
    Mar 2011
    Hammond, Louisiana
    Talking
    I have used the old style grip buddies. On my 2010 rt. Liked the fatter bar feel. Just ordered the new style for my 2014. Here is the link for the owner/maker of these order from here and save a couple of bucks. http://www.originalbeemerbuddies.com/CanAm.html
    Default Not sure..!!
    about the new ones but when we used them back when they were hard to keep clean and tended to get tacky...but then the foam ones would packup and smooth out getting slippery. You could give them a try, not a great expense and you my find them very comfortable...
    Mar 2011
    Washington, D.C.
    I've had both, if I have a choice I'd go neoprene every time. The foam grips will tend to swell up and split when they get wet. Still usable, just not very pretty!
    Jun 2013
    I made set using some scrap wetsuit material I hand on hand, and neoprene adhesive . . . they work great, absorb vibrations, well, and, because wetsuit neoprene is closed cell, they don't soak up water . . .
    Sep 2014
    Grants Pass, OR
    How do they work with the heated grips? I would think they would insulate the the heat??? I have large hands so would like the grips to be larger.
    Very Active Member Vader's Avatar
    Jul 2014
    Hudson Valley
    Default What about theses?
    Found these on ebay:
    http://www.ebay.com/itm/Throttle-Art...f7c55b&vxp=mtr
    I ordered these based on my model and color..either one can be reversed for a solid black color if preferred. Less than $9 shipped.
    IT IS, WHAT IT IS...
    Mar 2011
    Hammond, Louisiana
    Quote Originally Posted by hognut View Post
    The grip buddies I had worked good.
    Apr 2015
    Corinth, TX
    Thank you everyone! I just ordered the Original Grip Buddies for the Can Am and will let you know how they are when I get them.
    Jan 2012
    Menlo, GA. 'Lookout Mountain'
    Thanks for reminding me! I have a pair of the originals and they are worn out. They improved on the sticky as mine kept rotating. I fixed them from doing that.
    I need to order some new ones as mine are ugly and worn.
    Very Active Member Pennyrick's Avatar
    Feb 2011
    Loganville, ga
    Used them for years. I go through a pair in about a year's worth of riding. Figure I get about 12-15,000 miles out of a set.
    Penny and Rick have owned many motorcycles starting in 1974 with Honda’s, then to Suzukis, Gold Wings and ultimately Spyders.
    ‘74 Honda 360T (pair); ‘78 Suzuki GS 1000 (pair); ‘’82 Honda Aspencade; ‘84 Honda 400; ‘87 Yamaha 1100; ‘99 Honda Valkyrie; ‘01 Suzuki Burgman(triked); ‘02 Honda GL 1800(triked); ‘10 Spyder RTSE; ‘11 Spyder RTSM; ‘12 Spyder RTSL (pair); ‘20 Spyder RTL (current)
    Sep 2013
    Mansfield Texas
    I have them on both my Spyders .
    They are very comfortable on my large hands and Arthritis.
    Oct 2008
    Kingsport, TN
    Grip Buddies, got'em, Love them!
    Jun 2013
    My heated grips still warm my hands . . . just takes a bit longer to start feeling the heat.
    Apr 2015
    Corinth, TX
    Default Wow
    I ordered these http://www.originalbeemerbuddies.com/CanAm.html and I can tell you they are great. They thicken the grips and are really padded.
    I noticed that there is no slipping feeling with them. Like if your wearing gloves and your hand slides around in them a little.
    These are solid!
    Thanks for the recommendation!
    Oct 2007
    Johnson City TN
    I have them on my F3 feel great on the hands
    Apr 2015
    Corinth, TX
    Quote Originally Posted by one2doo View Post
    They are much better than expected. My hands were sore using those small stock grips. These are thick and comfortable. Even on rough roads you don't feel any vibrations through them.
    Nov 2011
    Graham, TX
    Are they sold by the pair or individually?
    Oct 2007
    Johnson City TN
    Quote Originally Posted by godfatheroftek View Post
    Pair
    Very Active Member IGETAROUND's Avatar
    Oct 2011
    Kalamazoo, Mi
    Have a set on my RS, love them, much more comfortable than the stock grips.
    All the great movements in the world began with a cup of coffee!
    2018 F3-T
    My mods: Can am Trailer hitch, USB and 12 volt power outlets, Gustason windshield, Bead rider seat cushion, battery harness for electric gear and battery tender, Time out trailer.
    2018 F3-T , Pearl White
    Apr 2015
    Corinth, TX
    Yes, as a pair.
    Danbury Connecticut
    As others have posted, I have an old style set of Neoprene Grip Buddies.
    I had them on my 2010 RTS. I liked them so much I transferred them over to my new 2014 RTS.
    I disagree with one of the claims. The Grip Buddies act as insulation and definitely affect the performance of the grip heaters.
    For those without grip heaters, this is irrelevant.
    IBA #47122
    2020 RT Limited Asphalt Grey
