2012 RTS runs like S***
I am taking bike to dealer this week. Any ideas before I get there? Bike has 3800 miles. Rode it yesterday and it acts like it is only wanting to run on one cylinder. Then all of a sudden it will come to life and run fine. Very intermittent problem. Can't establish a pattern. Thought maybe some of this great gas we get today turned to water, so I siphoned what I could then let the bike run out of fuel. Put a couple of gallons of fresh 93 octane. Seemed to improve but still drops in and out.
Spark Plug, Injector, TPS? Any ideas appreciated!!
Thanks
Might try some gas stabilizer such as Sea Foam or Techtron (from Chevron)
2020 RTL SE6 Asphalt Grey
2014 RT SE6, Pearl White 57k (2014-2020)
2008 GS Premier 17k (2012-2014)
My thoughts, vacuum hose to the Throttle Body. With so few miles on a Spyder I am thinking the hose dried up and has a hair line crack.
2008 GS SE5 in 2008
Traded at 43,000 miles for a left over
2010 RT SM5 in 2011
Traded at 57,000 for a left over
2014 RTS SE6 in 2015, which has 35,000 miles
Oct 19th, 2017, totaled 2014 RT while killing a Javaline
Dec 12th, 2017 drove a 2017 F3L home. What an awesome machine!
Never had any breakdown stranded issues.
Agree with dry cracked lines. Had the same problem with RT
2012 RTS runs like S*** Update
Correct. Vacuum hoses and plug wires. Was all covered under EPA warranty. Thanks for all your input!
Big thanks...
Thank you or getting back to us with the good news... always good to find out we are helping...
2012 RS sm5
Same problem on 2012 RSS
Hi, fired up the bike yesterday, same problem, running on one cylinder on and off. Just moved from Florida to the great white north. Nearest dealer sixty miles away and no good way to get it there. Could you tell me where to look for these lines? Are they obvious or hidden somewhere? The bike has 15k miles of FL high temperatures so it's not surprising. Also, I'm at a much higher altitude, would it be wise to disconnect the battery for a while to let the computer reset? Or is this unnecessary? Thanks!
I have the vacuum tubing if your interested. I bought it for my 2012 RTS and never installed. Its made by Turbosmart and its the silicone vacuum tube 3mm. Its a 10 feet roll. $10.00 shipped to you.
2008 Triumph Rocket (SOLD)
2002 Honda VTX 1800 C ( SOLD)
Vacuum tubing
OK! I'm not sure how to send a pm on this site. Please email me at loonybinlodge@gmail.com Thank you, Art
