Red & Blue Flashing Headlight
We bought an RT Limited in mid February at dealer 100 miles from home. To bring it home we put the dog in the truck and made a day of it. On the way home, my wife riding her new motorcycle, I noticed a couple of times that the headlights would appear to be flashing red and blue for a while then go back to normal. I figured it was sunlight and sun glasses causing an optical illusion. This was viewed in the mirrors of the truck. Yesterday we were riding and she was following me on our TriGlide. I noticed the flashing lights again. I raised my tinted visor, took off my sunlight glasses etc., trying to figure this out. They would still flash red and blue. The right one would flash blue on and off alternately with the left one flashing red. The lights appear to be yellow normally but when they flash there is no yellow visible. This will go on for several seconds then they return to normal. This scenario will repeat for several minutes, the flashing for a while then back to normal then the flashing again. Yesterday this condition lasted for approximately 10 minutes. Long enough to view with naked eyes, no glasses of tinted visors. The mirror was the only between my eyes and the lights. The first time we were going south, yesterday we were traveling north. We have been on several rides but this is the only times that I have witnessed this. I was wishing I had a camera that I could record it with.
Any ideas as to the cause?
=bob=
Unless the bulbs were changed they aren't red & blue ...............What you are noticing is the LOW beam shutter bouncing up & down .....it is common to all Spyders except European models ( they have a different system ).........Just leave the HIGH BEAMS on in the daytime .....it solves the problem and no one will notice the Highs are even on........Mike
Relax. .!!
this is normal. When RT's are behind me I notice the same effect. The shutter system is strange and the ST's now apparently have the dual filament bulbs and no shutters but the others are all still the same...like Mike said.....run your highs/shutters wide open during the day...
Gene and Ilana De Laney
Mt. Helix, California
2012 RS sm5
Red and Blue flashing headlight
The flashes seem very well timed. Bouncing shutter, to me, would indicate random timing. I am glad to hear that it is a common thing as would hate to be accused of impersonating law enforcement. My wife said she rides with the HI beams and fog lights on all the time. While it was occurring the other day, I had her try HI and LO beams with the fog lights on and off. It didn't make a difference to the flashing. Then they just go back to normal.
=bob=
It is normal sort of. The very fat headlight lens acts like a prism and splits the white light into it's different color parts. Visible at the edges of the beam like the horizontal cut off line on low beam. So as the Spyder travels over the dips, dives and potholes and because the wheelbase is so short. The headlight angle keeps changing so it looks like the lights are flashing and you will see color changes where the white light is split.
If it is real bad it could be a sign that the headlights are aimed too high. A slight adjustment will greatly reduce this effect. Only a small adjust may be necessary. Also it can be a good idea the run with high beams during the day and will eliminate the issue during the daylight hours.
The bouncing shutter thing I think somebody made up one day and IMHO has no basis in fact. Well at least no one has offer any proof this is true.
Originally Posted by brerrabbit
Thanks for the ideas. I find no reference to the shutters in the '14 RT manual supplement. They are mentioned in the '13 shop manual. No doubt here as to shutter ideas and the refraction being involved. But....
What would cause the shutters to alternate, one down and one up. It is always the same thing. Blue light from right side, left side off then Red light from left side and right side off. It doesn't flicker. The lights alternate on-off with a perceived 'on' time of about 1/2 to one second interval. It looks very much like the red and blue light from a law enforcement vehicle. This will go on for several seconds possibly a minute, then it goes back to normal for a while. Then it will start again.
It is possible that all these ideas contribute to the phenomena. Separation distance may also be involved. Next time I see them I will try to test these theories.
I must be really bored.
=bob=
Forget about the shutters. Has nothing to do with it. If both headlights are not aimed exactly the same they will look like different colors.
I know you're bored but turn your attention to something more important.
P.S. This topic of discussion has been going on since 2008.
Ok, at this point we have shutter flutter, light refraction and possible Doppler effect. In late '08 and early '09 I was working in Dulce NM. So as ancient astronaut theorists would suggest...............
=bob=
Originally Posted by akspyderman
A lot of us are running the high beams all the time to avoid the "shutter bounce" issue. Akspyderlady did not have her high beams on yesterdays first ride of the year. It appeared her headlights were flashing. We got the red/blue effect on our 2009 RS. High beams fixed it.
We don't do a lot of night driving--because there is no night here in summer. But high beams on all the time at night can be an issue. Daytime--not so much.
When cars start pulling over for you--time to go to high beams in the day time.
I do not doubt the theories I have received prior to this post including the ones I have come up with myself but they leave a few things unaccounted for. I believe billybovine had a good idea about turning my attention to something more important but that means I will have to stop procrastinating.
Unaccounted for:
- She runs with HI beam on all the time. Switching between HI and LO did not cause it to stop. It worked the same on both HI and LO.
- The timing of the flashes. They seem to be alternating on a timed cycle for several seconds at a time. Not blinking or fluttering on and off. It does not appear to be random time slots.
- Lack of normal headlight during the flash cycle. When the red is off, there is no light at all on the left side. Same with the blue on the right side when it is off.
- There is never a time when both sides are off at the same time. One is on or they are transitioning. I have watched them for several minutes (while riding, not parked, so I could have missed something).
- Blue and red light never alternate from one side to the other. In other words, blue never shows up where the red light has been.
- Refraction of the light would mean I would be able to see the colors at any time by raising or lowering my point of view. Squatting if you will. So far I have not been able to find the correct angle.
It appears there is no definitive answer at the moment. Maybe someone has a better explanation. She emailed BRP about it and got the response that basically asked why she would bother them with this as the dealer is all knowing. We may try the dealer but they will have to see it to test it, etc. and if there is something going on, it is intermittent so they will not see it therefore the diagnosis will be it is all in my mind.
Thanks,
=bob=
flashing lights
Why not have someone ride with you and make a video of it.Show it to your dealer
my 2 cents worth
It is not a problem .......................... just ride the bike and enjoy it.
Cruzr Joe
When all other explanations fail
I would say you are out running LEO
Now 2014 RT Limited Cognac
Was 2008 GS SM5
Don Garbarino
Cup Holder
GPS locking holder
Mud flap
Modified KNOTT grill
Phone holder and charger
Trailer hitch
Dual air horn
Auxiliary fuse box with relays
Heated clothing controller
volt/oil pressure gauge
Sequential signals in mirror
Tri Axis Handle bars
Baja Ron anti sway bar/heim links
shorty antenna
And many more
