starting problem
12 RT SE 5
In gear
Did the normal step on brake pedal. No start.
Yesterday I shut it off in Accessory mode. Had radio playing then turn off by 4 way flasher button.
Any suggestions
Yes I already ck
Wondering if should disconnect either negative or position side of battery
One thing you can check..
...make sure transmission is in neutral. Manual shows how to do this - from under the bike. (once had to do this on my 2010 RT)
Another suggestion for future use. When you shut the bike down, place transmission in Neutral first - set brake - turn key off. Now when you want to start the bike, you no longer need to press the brake petal -- you can start the bike from either side of it as well.
Don
Did own: 2008, Red, SE5 - and 2010, Black, RT-S Premiere Edition Number 670
Now Own: 2014 Black RT-S SE6
Does the display come up when you turn the key on?
if not, battery may have drained.
SE 5
Stuck in gear.
Yes all is powered up radio lights. Just disconnect both terminal on battery let sit for a while.
Notice not getting safety warning screen on ,. Went on about 120 mile ride yesterday no problem.
I think something with way it was turn off in Accessory mode.
SE 5
Stuck in gear.
How to put in natural on se 5
Little checking..!!
what happens when you hit the starter button..? Do you get a click..? Do the dash light fade or go out..? It is sounding like you have a low battery. Try hooking a jumper battery to yours and see if it starts up. How you turn it of should not be an issue. The computers reset when off. You may not have actually turned the acc off and drained the battery some...
Gene and Ilana De Laney
Mt. Helix, California
2012 RS sm5
As clearly stated in the owners manual. A SE5 model will start in gear. In fact I made a video showing my SE5 starting in fifth gear. There should be no need to put it in neutral manually first as long as everything is working properly. This myth just does not want to go away. As long as your foot is pressing on the brake pedal hard enough to make the brake light come it does not matter if it is in gear.
So everything lights up. Your foot is on the brake pedal. ( the brake lights are on.) The run switch is in the on position. What exactly happens when the starter button is pushed?
Video staring in gear.
Video showing my Spyder being started in 5th gear and shifting to neutral on it's own after starting.
Finally
I was able to get it started.
Finally got it to shift to neutral. Then started.
Thanks for all the input.
Tell us what you did! Inquiring minds want to know!
2014 RT Ltd Black Currant, Bump Skid, TricLed 3rd, 4th and 5th Brake Light with Modulator, TricLed Safety Bundle Led's and Reflectors with flasher option, TricLed Vader lights, JT's dash mount and USB outlet. Baker Wings belt tensioner and Drivers cup holder. Lamonster's FFP highway pegs and IPS, BRP Trailer hitch with Bushtec pin and 2007 Bushtec Roadster GT trailer. Volt Meter. Baja Ron Sway Bar. Doc Humphry's spring spacers
Mike
Solution
I re ck oil level and added some , then it shifted into neutral, and was able to start.
Solution
Thanks for the info. Just in case mine want to do the same thing one day..
2012 Spyder RT Limited Lava Bronze (Psalm 27:1;Luke 12:4,5)
A 998 engine SE5 Spyder will start in any gear.
All 998 engines will start no matter how much oil is in them.
A 998 engine SE5 Spyder may not shift to neutral after starting if it does not have enough oil, but will start.
Adding oil because it is low when it has not been run recently runs a high risk overfilling it.
The bottom line is I don't know why the OP Spyder did not not start, but it has nothing to do with the oil level.
It was a little overfilled , and i siphon some out. I know the oil level shouldn't be a factor. But that what I did add oil, rock the bike and step on brake pedal. Still not 100% sure on why it didn't start. No problem since.
Glad you got it fired up. Too bad you did not find the root cause. I just wanted to head off any misconceptions that could delay a fix for others experiencing something similar.
