Hi I have seen drops of coolant on my garage floor from time to time,thing it was a overflow problem, had it since I purchased the 2014 rss new last march 2014, like I said the drops got bigger so I pull off the right side panel covering the fan & radiator there I seen the only radiator hose with adjustable radiator clamp with a screw drive tip it was so loose it took 3 turn to tighten , the leak has stopped easy fix don't have to bring it in
