Results 1 to 2 of 2
Thread: leaking coolant
    Active Member ssmcclub's Avatar
    Apr 2013
    massapequa ny 11758
    Default leaking coolant
    Hi I have seen drops of coolant on my garage floor from time to time,thing it was a overflow problem, had it since I purchased the 2014 rss new last march 2014, like I said the drops got bigger so I pull off the right side panel covering the fan & radiator there I seen the only radiator hose with adjustable radiator clamp with a screw drive tip it was so loose it took 3 turn to tighten , the leak has stopped easy fix don't have to bring it in
    richie spyder
    Default Good to know..!!
    well known but always good to confirm that it is still a problem. It's the only adjustable clamp on the machine and it seems to get forgotten quite often..glad you found it and did not have to pay 50.00 a turn...
    ​2012 RS sm5
