Page 1 of 2 12 LastLast
Results 1 to 25 of 34
    Active Member Cleg's Avatar
    Apr 2012
    Queensbury, NY
    Default EZ Pass location
    Just received my EZ Pass transponder and am wondering if anyone out there has mounted it in the 'frunk'? I really don't want to add it to the windshield too ugly then. Seems to me I read somewhere that it could be done. Thanks.
    Dec 2008
    Syracuse, NY
    I've read a number threads here where they've mounted it to the underside of the trunk lid, and they say it works. Mine is low on the windshield.
    I'd go for underside of the trunk lid. If it doesn't work, it's only a few bucks for another 3M strip.
    Very Active Member robmorg's Avatar
    Oct 2013
    Pottstown, PA
    . I've seen the same posts, and there's no reason it shouldn't work well mounted in that position. I would mount it just inside of the top of the frunk lid, or on the frunk bulkhead near the same location.
    Rob
    2013 RT Limited
    My "Mods & Farkles" Link
    May ALL your roads be beautiful
    Greisemer's Mill Bridge, Oley, PA
    2013 RT Limited , Lava Bronze with Antler Brown Seat
    Nov 2012
    North Las Vegas, NV
    Just throw it in the frunk the next time you are headed for the tolls and you will know quickly if it works from there. It should.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    It doesn't work in the bottom of the frunk.
    I had mine mounted on top of the dash last season. This year; I'm trying it in the front storage netting area of the Frunk.
    Active Member Spyda98's Avatar
    Dec 2014
    Default inside frunk
    At first I added my plates to my EZ Pass account but I now have my transponder on the inside of my frunk. It is specifically located on the right center and no issues so far.
    The problem with mounting them on the underside of the frunklid...
    Closing it tends to knock them loose, and if your frunk is full; they are in the way!
    Sep 2014
    USA
    I leave mine in the back trunk and seems to work..
    Nov 2013
    Central Texas
    I mounted mine right near the latch under the frunk lid. Works every time.
    Very Active Member Lin's Avatar
    Apr 2013
    Somersworth, NH
    I have mine mounted in the frunk. Remember though, it has to face the correct direction. The label needs to be at the back and the "Velcro" has to be towards the front. At least that is what I was told by the EZ Pass clerk.
    2016 RT-S Special Series
    2016 RT-S Special , 2 tone black
    Mar 2015
    forrest above Reno, Nv
    Default Easy Pass??
    On my V-Max the easy pass is " drop a gear and dissapear" Guess it's the same on the RT----It can at least get out of its own shadow.
    Kaos
    2014 RTS , Circuit Yellow
    May 2013
    Stanton, ca
    Pop off the left or right front speaker grill.
    They are easy to pop off. Start with the uper inside corner.
    You will see there is a TON of space below the speaker. I would put it there below the speaker.
    No worries about it falling out anywhere either as that area is an enclosed box.
    It's out of the way and doesnt get in your way.
    Just an idea.
    Bob
    2011 RT-S SM5 - Black
    Dec 2008
    Syracuse, NY
    I'm not sure what kind of strips you use to mount yours, but I used the 3M's that came with it. I have a hard time to pull the EZ-Pass free when I want to remove it. Of course, if the EZ-Pass is not locked all the way in, it will come loose. I do agree they may be in the way, if you overpack.
    Jun 2014
    People's Republic of NY
    Works like a charm velcroed to the under side of the frunk lid.
    there's no way to knock it off the lid if your using the Velcro type stuff that
    comes with it.
    be sure to degrease the spot your going to use
    committee for postings
    Wylie,
    I tried using the Velcro that they supplied...
    While it stuck to the Frunklid and to the EZ-Pass; the Velcro itself just wouldn't stick together well-enough to keep it in place.
    Apr 2013
    Somersworth, NH
    Wylie,
    If is the same as I was given, it requires a solid push to interlock the two pieces.
    Very Active Member tofriendscreek's Avatar
    North Central Arkansas
    With my IPass, I keep it in the center console compartment when cruising in and around Chicago. Never had a problem with it failing to be read.
    2022 Plasma Red, F3 Limited, Special Series
    Jan 2015
    southern WI
    Sheesh....shame on all of you for riding your Spyders on the interstates. Get em on the back roads and smaller highways.....interstate sucks!! LOL. Yeah yeah, I know sometimes ya just gotta
    2016 RTS , Pearl White
    Central Oklahoma
    Default similar unit for Oklahoma
    Thats where my wife and I keep ours. We found that the side with the suction cups mounts had to be toward the front of the spyder.
    2020 RT Limited , Petrol Metallic Dark
    Very Active Member Dan McNally's Avatar
    Jun 2013
    Underside of the frunk lid, and it has never fallen off . . .
    "Topper" is my Pearl White 2013 RT-LTD
    Professional Retiree - liked it so much when I retired from the USAF, that I started another career so I could do it again!
    Happy to be a member of the Maryland Spyder Web - find us at
    http://www.meetup.com/MarylandSpyderWeb/
    Active Member Dragonfly's Avatar
    Apr 2013
    Atkins, Arkansas
    Left chest pocket, since I have three vehicles and one E-Z Pass I always know where it is.
    May 2013
    Stanton, ca
    I guess no one likes my under the speaker grill idea?
    FYI that is where I put my garage door opener!
    Bob
    Very Active Member 900Dave's Avatar
    Jun 2013
    Fleetwood, PA
    underside of the frunk lid. It has never fallen off. It is also easy to get too and remove as I use the same easy pass for all three of my vehicles.
    2016 Spyder F3 Limited Steel Black Metallic
    Lamonster approved LED Headlights
    Lamonsters LED Fog lights
    BRP Driver & Passenger backrest
    BRP Trailer Hitch
    Shamrock Black & Polished
    Signature light
    Elka front shock's
    Rolo Laser Alignment
    Dual Power outlets
    Garmin 590 GPS
    SoFlo
    FWIW, the Florida Sunpass comes with suction cups.
    On our RTs, I just stuff the Sunpass into the net on the back wall inside the frunk.
    So far so good.
    PK
    Jan 2011
    Titusville, Fl.
    Quote Originally Posted by Cleg View Post
    I also put mine in frunk. I don't know about your state, but in Fl. when you purchase your ez pass the license plate is also registered. If your pass does not register at the toll booth, a picture of your license plate is sent in. No fine for you if your plate is registered. I know this works because on toll booths with green/red lites sometimes my pass will not turn the lite green but no citations have been sent to me.
